Go to Post You are beautiful. - Joe Johnson [more]
Unread 23-02-2007, 15:55
Re: [FVC]: MPLab using two transmitters
PWM_in1 through 6 are from the first Vex receiver port
PWM_in7 through 12 are from the second Vex receiver port.
So...
// Driver Control - Rx1 preferably
  pwm03 = PWM_in1;  // Depends on what mode you select on the transmitter
pwm04 = PWM_in2;
//Arm Control - Rx2 preferably
pwm01 = PWM_in7; //- Arm raise/lower (on CH 1 of 2nd transmitter)
pwm02 = PWM_in9; //- Arm extend/retract (on CH 3 of 2nd transmitter)
pwm05 = PWM_in11; //- Servo to lock arm (on CH 5 of 2nd transmitter)
In ifi_aliases.h you'll see them:
 *---------- Aliases for R/C PWM IN connectors -------------------------------
 *  Below are aliases for the PWM inputs received from the radio-control receiver.
#define PWM_in1         rxdata.oi_analog01
#define PWM_in2         rxdata.oi_analog02
#define PWM_in3         rxdata.oi_analog03
#define PWM_in4         rxdata.oi_analog04
#define PWM_in5         rxdata.oi_analog05
#define PWM_in6         rxdata.oi_analog06
#define PWM_in7         rxdata.oi_analog07
#define PWM_in8         rxdata.oi_analog08
#define PWM_in9         rxdata.oi_analog09
#define PWM_in10        rxdata.oi_analog10
#define PWM_in11        rxdata.oi_analog11
#define PWM_in12        rxdata.oi_analog12
Using MPLAB SIM koenig3456 Programming 5 11-02-2008 14:39
Teams using MPLAB Ctrl Alt Delete FIRST Tech Challenge 4 22-09-2006 22:37
Problem using two transmitters jamesgecko FIRST Tech Challenge 9 12-05-2005 09:30
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
Using two Large PAPST Fans? SuperDave Electrical 9 17-02-2003 15:11
