Go to Post Do you know how, say, Native American cultures were kept? They had storytellers, sages, and the like. They passed on their legends and culture to the next generation. So will we. - EricH [more]
Go Back   Chief Delphi > Other > VEX
Unread 23-02-2007, 16:40
Miller's Avatar
Miller Miller is offline
Sticky
AKA: Jared Miller
FRC #1676 (Pascack Pi-oneers)
Team Role: Student
Miller is an unknown quantity at this point
Send a message via AIM to Miller
Indications from the controller
Is there a way to give some sort of indication, through the controller, when a limit switch has been pressed?
STICKY
Unread 23-02-2007, 16:43
ChaosParadeXi's Avatar
ChaosParadeXi ChaosParadeXi is offline
mentor
AKA: simon
FRC #0365 (Miracle Workerz)
ChaosParadeXi is on a distinguished road
Send a message via AIM to ChaosParadeXi Send a message via MSN to ChaosParadeXi Send a message via Yahoo to ChaosParadeXi
Re: Indications from the controller
is there a specific reason you want an indication because if a limit switch has been closed and setup correctly, the applicable motor/motion should just stop
nonother's Avatar
nonother nonother is offline
Founder
FTC #3053 (Occam's Engineers)
nonother will become famous soon enoughnonother will become famous soon enough
As far as I am aware the Vex command module is entirely incapable of transmitting signals and the Vex Controller is entirely incapable of receiving signals. For both of these reasons I believe it is not possible. However you could do something in programming to react to a limit switch being pressed down.
Unread 25-02-2007, 16:44
ManicMechanic ManicMechanic is offline
AKA: Yolande
VRC #0438 (Metal Gear)
ManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond repute
You can also get a reading on the switch using the Online Window (from the Build and Download menu). However, if you're trying to see whether a specific action of your program triggered the switch, nonother's suggestion is the way to go.
Programming Analog Input from 2004 Controller Danny Diaz Programming 8 30-01-2007 22:44
No PWM from controller ctshirk7 Control System 10 27-01-2006 18:55
jumper cabling from sensors to controller Gary Dillard Electrical 4 23-12-2005 07:42
Missing Xbox controller from San Diego lock-in... chaoticprout Off-Season Events 0 22-05-2005 20:38
