Go to Post After each match the pit crew gathers up the parts from the field and finds a new and interesting way to assemble them. - tsaksa [more]
Unread 20-02-2007, 16:31
aksimhal's Avatar
aksimhal aksimhal is offline
AKA: Anish
FRC #1123 (Autodidactic Intelligent Minors)
aksimhal is an unknown quantity at this point
Send a message via AIM to aksimhal
Firefox Problem
Hi,
I was wondering how to get my Firefox Browser back to normal? (Normal means how Firefox2 looks when it is first downloaded. I know I have a theme installed, but I lost the google toolbar, the bottom is to long, etc.)
Thanks, and attached is a screen shot.
Unread 20-02-2007, 17:59
Protronie's Avatar
Protronie Protronie is offline
Have big wrench...and will use it!
Protronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud of
Send a message via ICQ to Protronie Send a message via Yahoo to Protronie
Re: Firefox Problem
Right click on the toolbars ... you should see a list of the tool bars in use . Be sure the google one is checked and un-check the one you don't want.
Now for the theme... lleft click on tools and left click addons. You should see a themes tap. Click on it and select default and you will go back.
If that doesn't work or hold. Had the same problem with with an strange toolbar and the thing kept losing my custom set up.
Its a glitch in the first release of Firefox 2.0
All I did was uninstall the firefox, re-install and haven't had any problems since.
Hope this help you. Firefox itself has a good self-help section too.
Good luck!
Protronie rule 5 - When the big wrench starts swinging, get out of the way!
Unread 21-02-2007, 10:46
aksimhal's Avatar
AKA: Anish
Re: Firefox Problem
I tried uninstalling firefox, but I still get that huge bottom toolbar (or what ever it is) when I reinstalled it. Should I try again or what?
Thanks,
Unread 21-02-2007, 20:21
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Re: Firefox Problem
Try this:
TOOLS > ADD-ONS > THEMES > Click on Themes > Default Theme > Use Theme.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 23-02-2007, 18:14
aksimhal's Avatar
AKA: Anish
Re: Firefox Problem
Hi,
Thanks for the help. With all your advise, I think I got Firefox running again.
Thanks
Unread 23-02-2007, 18:32
ShaneP's Avatar
ShaneP ShaneP is offline
Lead Mentor
FRC #0330 (The Beach Bots)
ShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to behold
Re: Firefox Problem
If you are still having issues with Firefox, try the following:
After uninstalling Firefox, go to: My Computer --> C (or main disk) --> Documents and Settings --> (Your User Profile) --> Application Data --> Mozilla.
In folder Mozilla, delete the folder entitled Firefox to the Recycle Bin. All your Firefox settings are stored in this folder. If you delete this folder and then reinstall Firefox, you will start our fresh.
I recommend you hold on to the folder in Recycle Bin in case you want to roll back to your old settings. If you do, just restore the folder.
Unread 23-02-2007, 23:24
Grant Cox's Avatar
Grant Cox Grant Cox is offline
Back for more.
FRC #0148 (Robowranglers)
Team Role: Tactician
Grant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond repute
Re: Firefox Problem
In the future, I remember version of 1.0 had a "profiles" thing that you could access through the command line. I had a similar problem, and making a new profile fixed it for me. I haven't had to touch it in 2.0 though, so I have no idea if they still have that or not.
VEX Robotics Marketing Manager
ThunderChicken driver '07-'08
Robowrangler '13-present
FIRST in Michigan, VEX Worlds, and FIRST in Texas MC/Game Announcer '08-present
Unread 24-02-2007, 14:10
neo's Avatar
neo neo is offline
whoa.
AKA: Dan Murrow
FRC #0585 (THS CyberPenguin Robotics)
neo has a spectacular aura aboutneo has a spectacular aura about
Re: Firefox Problem
make sure firefox is closed.
Start > Run > type "firefox -profilemanager"
allows you to delete, create, etc.
Unread 06-03-2007, 19:23
ZeetherKID77's Avatar
ZeetherKID77 ZeetherKID77 is offline
TRULY EPIC LULZ
FRC #1523 (MARS)
Team Role: Animator
ZeetherKID77 is on a distinguished road
Re: Firefox Problem
"Firefox" and "Problem" just don't go in a sentence together
MEGA Awesome! MEGA Awesome! MEGA Awesome!
MEGA Awesome!
MEGA Awesome!
MEGA Awesome!
Are you annoyed yet?
Unread 06-03-2007, 19:37
Grant Cox's Avatar
Back for more.
Re: Firefox Problem
Unless, of course, that sentence includes the word RAM
Microsoft Firefox! SamC IT / Communications 14 05-12-2006 00:13
Firefox 2! thegathering Chit-Chat 16 26-10-2006 16:12
Firefox troubleshooting. Madison IT / Communications 11 17-09-2006 01:28
Firefox 1.0 Released! MikeDubreuil Chit-Chat 19 19-04-2005 00:23
Firefox 1.0 RC2! Ryan M. Chit-Chat 4 07-11-2004 18:12
