Go to Post If you have not had a positive experience in FIRST, please don't bring those that have down. - Jeff K. [more]
Unread 23-02-2007, 21:02
Best Available Data
FRC #1778 (Chill Out!)
Re: pic: 1276's 2007 3-Speed AM Gearboxes
Originally Posted by Billfred View Post
When they do get locked up, is it possible to unlock them? Then it quits being a bug and becomes a feature.
Like the mods--nice and clean!
It is very possible to unlock, just shift the third gear dog back into neutral. The only real problem is if you were cooking across the field at full speed and then locked them up you might do some damage.
EDIT (In response to Sean): Yep, that's what I figured too. It's just that if you engaged it while you were driving, you could hurt something.
Unread 23-02-2007, 21:05
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I think he was referring to intentionally locking them up to create a mechanical braking feature.
The biggest issue about using the dogs to lock up the shifters is what happens when it does fail. If you accidentally lock up the gears (which may happen if you have a lock on command feature), or you recieve a significant force to the gearbox when locked up (not sure what force this could be, most external forces this large would probably just cause the wheels to skid well before a failure in the drive) the failure would almost certainly be losing gear teeth. And that spells disaster in a transmission.
Unread 23-02-2007, 21:08
AdamHeard's Avatar
Lead Mentor
That is awesome then. Keep your code so you don't look them at high speed, but also put some code in that let's you lock it on command. It would be really useful for holding position on a ramp at the end of the match.
Unread 06-03-2007, 17:02
Best Available Data
In case anyone is wondering, these gearboxes held up perfectly through our regional. There was never any "bad shifting" causing a lockup or teeth stripping or anything of that sort. We found the extra high gear most useful in this years game to race around the rack to play defense and then return.
If there is any interest, we plan on creating a white paper before next season. (There, a deadline, now I'll have to follow it. )
pic: Outback system with modified Andy Mark gearboxes sam shawe Extra Discussion 5 21-02-2007 12:56
pic: Team 948 2-Speed Gearboxes jfelser Technical Discussion 10 08-02-2007 23:26
pic: 1276's Handouts Ian Curtis Extra Discussion 11 02-02-2007 17:03
pic: 1276's 2006 Robot Ian Curtis Extra Discussion 8 17-04-2006 21:30
pic: Team 1114 Gearboxes CD47-Bot Robot Showcase 16 19-02-2004 12:16
