Go to Post Don't be too distracted by the shiny robots, and the games they play. Enjoy them, but keep your eyes on the real prize(s). - gblake [more]
Unread 18-02-2007, 19:00
skibum2490 skibum2490 is offline
FRC #1541
skibum2490 is an unknown quantity at this point
P.I.D. Control for the arm
Hey guys I have a quick question I would like to ask.
We're using a linear potentionmeter to give us an analog value so we can set the arm position (high, mid, low) based on the flick of a switch. However, we're using P.I.D. control in order to get to where we need to be.
Now, the problem we have is the large amount of oscillation occuring after the switch is pressed, ex. the arm jumps way past the position, then comes back and hits the ground before re-adjusting to the right height. Our motor is geared down 21:1 which we're hoping to increase to 64:1. Basically, what is the best way to eliminate oscillations through P.I.D. control?
Thanks!
Unread 18-02-2007, 19:04
DonRotolo's Avatar
Back to humble
FRC #0832
Re: P.I.D. Control for the arm
Your P gain (multiplier) is too large. Reduce it until it gets there with little overshoot. (No overshoot is not as easy to compensate for as a little bit of overshoot)
There is an excellent whitepaper on how to tune a PID loop called PID without a PhD, look it up and it'll explain it very well.
Don
Unread 18-02-2007, 19:13
FRC #1541
Alright, I did try to decrement the P multipilier, but after I did that, it didn't seem like the motor was outputting enough power to raise the arm, I could try again however.
Unread 18-02-2007, 23:46
ace123's Avatar
ace123 ace123 is offline
AKA: Patrick Horn
FRC #0008 (Paly Robotics - http://robotics.paly.net/)
ace123 has a spectacular aura aboutace123 has a spectacular aura about
Send a message via AIM to ace123
The not outputting enough is a problem with the integral ("I") component being too low. You want to increase it (though small changes make a huge difference)
One trick we did to keep the I from building up too much is to set the integral error (the one that keeps adding each frame) to 0 when it has passed the target angle (you can clear it if it's within 5 or 10 ticks, depending on what works best and your tolerance)
-Patrick Horn, Paly Robotics
Check out the space simulator called Vega Strike, modelled after the space simulator games Elite and Wing Commander. It's Open Source too!
If you have ever played Wing Commander, or especially Privateer, and had a feeling of nostalga derived from the you will enjoy these two Vega Strike mods: Privateer Gemini Gold and Privateer Remake!
I'm working on adding multiplayer support this year...
Unread 18-02-2007, 23:50
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Shameless plug, the paper in my signature may be of some help, it explains tricks to get more precise control of the gains without using floats.
Matt Krass
Unread 23-02-2007, 22:01
JimGRobot JimGRobot is offline
AKA: Jim
FRC #1388 (Eagle Robotics)
JimGRobot is just really niceJimGRobot is just really niceJimGRobot is just really niceJimGRobot is just really nice
We had similar problems with our arm, and the main problem is that gravity makes this really two control problems, and one controller can't be tuned to do both well.
When the arm is moving up, gravity turns it into a self-regulating process, which is easy to control with straight proportional. When the arm is moving down, gravity turns it into a runaway process, which is harder to control. We ended up measuring the speed of the arm when moving down, and controlled it that way.
Jim
Unread 27-02-2007, 04:18
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
We chose a mechanical solution and counter balanced our arm with a bungee.
Unread 27-02-2007, 07:55
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
I might suggest you add a D term with a whole heck of a lot of gain... PD loops work surprisingly well...
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 27-02-2007, 11:21
Protronie's Avatar
Protronie Protronie is offline
Have big wrench...and will use it!
Protronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud of
Send a message via ICQ to Protronie Send a message via Yahoo to Protronie
You guys have the makings of a true Protronie...
Bungees... 1,001 uses and counting
Protronie rule 5 - When the big wrench starts swinging, get out of the way!
What's the best solution for a homebuilt robot arm? Chriszuma Chit-Chat 11 25-06-2006 01:55
Slave Control Arm aaronD341 Control System 1 26-04-2005 17:13
2-Segment Arm Control Orborde Programming 1 20-01-2005 01:40
Neural Control of Robot Arm Leo M Math and Science 2 29-03-2004 13:46
RoboStars 'Mini-Arm' Control Device archiver 2000 5 23-06-2002 22:28
