Go to Post Am I the only one who thinks robots are the main attraction of a regional, and there isn't a need for more distraction? - Adam Richards [more]
Unread 23-02-2007, 19:18
norfsprang norfsprang is offline
norfsprang is an unknown quantity at this point
[FVC]: Servo motor fix
Hi!
we are really new to all of this and are in great need of some assitance!! Our competition is fast approaching and we need to figure out how to convert our servo motor into a continuous motor. We've already taken out the geared brake in the servo, but the motor is continuously spinning afterwards and fully uncontrollable by our remote. It just keeps spinning!! Is there anyway to solve this!!
Please help!!
Unread 23-02-2007, 20:55
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
Re: [FVC]: Servo motor fix
Even if you can work out a way to do this, I don't think it's FVC legal. Your best bet is to purchase another motor. If you need to sense the position of the motor, then use an optical shaft encoder.
I suggest http://www.vexlabs.com for vex parts.
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Unread 23-02-2007, 21:46
nonother's Avatar
nonother nonother is offline
Founder
FTC #3053 (Occam's Engineers)
nonother will become famous soon enoughnonother will become famous soon enough
11Ed71 is right, modifying an electrical component (such as a servo) in any way is a violation of FVC rules. If you need another motor, you'll have to buy one. If you don't need continous spin but just more degrees of rotation you could use gearing to accomplish that.
Unread 23-02-2007, 23:10
joshsmithers's Avatar
joshsmithers joshsmithers is offline
go team 4910! get that FLL!
AKA: username-ers=myname
FRC #0587 (Hedgehogs)
joshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of light
chances are the pot is stuck in one direction, causing it to continuously spin in that direction.
did you take out the pot? i'm aware of the fact that after fixing the servo mechanically-or removing the plastic stub piece that sticks out of one gear- you should replace the potentiometer with two 2.2k resistors.
the potentiometer has 3 pins. remove the wires from each pin(desoldering probably) and replace the outer pins with said resistors to the outer wires and the other ends of each resistor to the middle pin.
i may be a bit vague, but thats how I do it. i would just go with a normal motor if i were your team though, just to be safe.
Genius is 1 percent inspiration and 99% perspiration, which is why engineers sometimes smell really bad.
[FVC]: Can you change a vex servo to motor? Marcel FIRST Tech Challenge 6 02-02-2007 14:41
698's Fisher Price Motor Fix Alex698 Motors 10 13-10-2006 19:55
FVC 2005 in Servo Magazine syraweb FIRST Tech Challenge 0 16-02-2006 15:11
Motor to Servo itzrobz Programming 8 02-02-2006 16:11
Defective clutch on motor/servo? jeffmorris FIRST Tech Challenge 3 04-10-2005 14:49
