Go to Post We have donut eating contests to see who has the best legs. We paint our pigs. We argue about which time zone we are in. About 400,000 of us gather together to watch cars go around in a circle. We also build robots.Yep, our cultural norm is a bit different. - Andy Baker [more]
Unread 23-02-2007, 15:09
emmell's Avatar
emmell emmell is offline
Murphy was an Optimist!
AKA: Mannie Lowe
no team (Radbotics, RoboKnights, CircuitRunners, Oscar, and more...)
emmell is just really niceemmell is just really niceemmell is just really niceemmell is just really niceemmell is just really nice
[FVC]: MPLab using two transmitters
Okay, I looked and looked and can't find example code to do the following: One transmitter drives the bot. The other transmitter handles the arm and servos. I see how to do it with EasyC, but how do you do it in MPLab. Do I have access to two RxData/TxData data structures. Where?
* Driver Control - Rx1 preferably
* pwm03 - left side drive
* pwm04 - right side drive (reverse it)
* Arm Control - Rx2 preferably
* pwm01 - Arm raise/lower
* pwm02 - Arm extend/retract
* pwm05 - Servo to lock arm
Thank you!
Mannie Lowe
Mannie Lowe
FIRST Program Manager - Center for Mathematics and Science Education - University of Mississippi
Mississippi FIRST Tech Challenge Affiliate Partner
Unread 23-02-2007, 15:55
Re: [FVC]: MPLab using two transmitters
PWM_in1 through 6 are from the first Vex receiver port
PWM_in7 through 12 are from the second Vex receiver port.
So...
// Driver Control - Rx1 preferably
  pwm03 = PWM_in1;  // Depends on what mode you select on the transmitter
pwm04 = PWM_in2;
//Arm Control - Rx2 preferably
pwm01 = PWM_in7; //- Arm raise/lower (on CH 1 of 2nd transmitter)
pwm02 = PWM_in9; //- Arm extend/retract (on CH 3 of 2nd transmitter)
pwm05 = PWM_in11; //- Servo to lock arm (on CH 5 of 2nd transmitter)
In ifi_aliases.h you'll see them:
 *---------- Aliases for R/C PWM IN connectors -------------------------------
 *  Below are aliases for the PWM inputs received from the radio-control receiver.
#define PWM_in1         rxdata.oi_analog01
#define PWM_in2         rxdata.oi_analog02
#define PWM_in3         rxdata.oi_analog03
#define PWM_in4         rxdata.oi_analog04
#define PWM_in5         rxdata.oi_analog05
#define PWM_in6         rxdata.oi_analog06
#define PWM_in7         rxdata.oi_analog07
#define PWM_in8         rxdata.oi_analog08
#define PWM_in9         rxdata.oi_analog09
#define PWM_in10        rxdata.oi_analog10
#define PWM_in11        rxdata.oi_analog11
#define PWM_in12        rxdata.oi_analog12
Unread 24-02-2007, 00:33
emmell's Avatar
AKA: Mannie Lowe
Mark:
Thank you. Thank you. I knew that. I just had a brain freeze these past three days trying to get ready for the tournament that I'm running on 2/24 (Georgia FVC) and mentoring my team at the same time.
I coded it right after I got your reply and it worked like a charm. Chimera #832 thanks you very much.
Mannie
Mannie Lowe
Using MPLAB SIM koenig3456 Programming 5 11-02-2008 14:39
Teams using MPLAB Ctrl Alt Delete FIRST Tech Challenge 4 22-09-2006 22:37
Problem using two transmitters jamesgecko FIRST Tech Challenge 9 12-05-2005 09:30
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
Using two Large PAPST Fans? SuperDave Electrical 9 17-02-2003 15:11
