Go to Post Geez, now I'm like some all-knowing all-seeing FIRST sage who lives in the moutains waiting for students to venture upwards to my home to ask me if there will ever be a water game....:rolleyes: - Koko Ed [more]
Unread 24-02-2007, 10:51
evan_wilson's Avatar
evan_wilson evan_wilson is offline
QUARK
AKA: Evan Wilson
FRC #2172 (Street Legal)
evan_wilson is an unknown quantity at this point
Send a message via AIM to evan_wilson Send a message via Yahoo to evan_wilson
Unhappy Re: Real time clocks, out of the question?
Well, the problem is that I don't have any. Without EasyC, I just have the arm calculating based on loop counting. Multiples of 26.2 ms. There's no way I can switch to EasyC this year. I guess that would be a logical solution for next year.
Is there anyone here who has ever written a timer and interrupt routine for a real time clock? That's really the only thing I could worry about anyways. Otherwise I'll just have to stick with loop counting.
Unread 24-02-2007, 11:21
Timers are simple to use, no soldering required.
IFI has a white paper on coding timers that goes into the bits and bytes of it all:
http://www.ifirobotics.com/docs/time...004-jan-14.pdf
For a description of the timer library calls see the MPLAB-C18-Libraries.pdf manual under C:\mcc18\doc.
Here's a sample using the timer libraries:
// In user_routines.c
#include <timers.h>
#define CLOCKOFFSET 60535  //Set timer for 4ms
  // Maximum for 16-bit timer 65535 - 5000 (4ms) = 60535
/* Use Timer3 (16-bits) to control our clock */
/* timer set to 4 ms */
// Call from User_Initialization()
  OpenTimer3(TIMER_INT_ON &
             T3_16BIT_RW &
             T3_SOURCE_INT &
             T3_PS_1_8
  WriteTimer3(CLOCKOFFSET);  /* Preload timer to overflow after 4ms */
  // In user_routines_fast.c
  #include <timers.h>
  // globals declared as extern wherever else they are used
  volatile unsigned long Clockms=0; // 1 millisecond clock
  volatile unsigned int Clockds=0; // 1/10 second
  volatile unsigned int Clocksec=0; // 1 second clock
  //etc.
// In InterruptHandlerLow()
  if (PIR2bits.TMR3IF) /* TIMER 3 INTERRUPT */
    /** This provides us with a clock for timing events **/
    PIR2bits.TMR3IF = 0; /* Clear Timer interrupt flag */
    WriteTimer3(CLOCKOFFSET);  /* Reset Timer to overflow in 4ms */
    Clockms += 4; /* milliseconds */
    Clockds = Clockms / 100;
    Clocksec = Clockms / 1000;
    // etc.
Unread 24-02-2007, 11:29
QUARK
AKA: Evan Wilson
Talking Re: Real time clocks, out of the question?
Thank you very much. I hope my assembly serves me well.
I think I can dig up the differences in the new controller.
Want to be a mentor...
just kidding.
Unread 26-02-2007, 21:12
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Setting up just a realtime clock isn't that hard. I was thinking of doing it myself. I just have to figure out how to configure which timer to achieve something reasonable.
Unread 26-02-2007, 22:27
Mike Bortfeldt Mike Bortfeldt is offline
FRC #1126 (& 1511)
Mike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud of
Here is the code we used for a "clock". It uses Timer 2 and has a number of options for flexibility. It is not a "real time clock" in the sense that it doesn't compute hour/minute/second but works off clock "ticks", which for a 2 minute match, or a 15 second autonomous, works fine for us. By default, it's configured to count milliseconds (1 tick = 1 millisecond), but has 2 other predefined options for increased accuracy.
Mike
Unread 27-02-2007, 09:29
In teaching timers I use a demonstration program to calculate all the possible timer prescaler/postscaler combinations for a given Hertz or time period. It's an easy beginner exercise to write such a program for the PIC (or VB), and also can be used to teach them about maintaining the Master processor communication leading to an easy elimination of the Master handshake.
Here's a sample output calculating 2400 Hz used with an LCD display off a digital output.
Networkable real-time game simulation for 'Aim High'! test it out now Bongle General Forum 11 19-03-2006 23:10
Real time photos from the buckeye regional Greg Needel Regional Competitions 4 25-03-2004 12:46
Robot motion after the time has run out. Randy Ai Rules/Strategy 1 06-01-2003 17:17
Real Time Scoring archiver 2000 2 24-06-2002 00:09
real time chat SharkBite CD Forum Support 4 07-02-2002 21:22
