Go to Post Secure your battery well, or it will fly like a fish. - Nate Laverdure [more]
Unread 24-02-2007, 12:07
Re: Help on MPlab
You'll need the C18 v2.4 compiler from either this year or last year's CBOT CD. There is no online or other legal source.
We're unfortunately dependent on an older version of the C18 compiler, and the lastest version (3.x) available for online trial is not compatable with the IFI libraries we use, and will not work.
You can only use the 2004 version (C18 v2.2) with an older robot controller.
If you are just trying to use it to find compile errors, then you might be able to get by. Try creating a new project (Project Wizard) using the IFI Default Code files.
MPLAB 7.20 Help please? groovy69 Programming 14 22-01-2007 02:00
Help with MPLAB burningpig Programming 9 17-01-2007 13:10
Please help; HUGE mplab problem brennerator Programming 5 09-01-2007 01:25
MPLAB IDE HELP Idaman323 Programming 2 16-02-2005 18:01
Need Mplab help ASAP !! L33T-meh- Programming 3 03-02-2004 21:39
