Go to Post If they need a place where they can get a chance to learn interpersonal skills (like a team), it might just help them to become well-adjusted adults, as opposed to pathologically antisocial engineers (who got good grades). - Tristan Lall [more]
Unread 24-02-2007, 12:53
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Vacuum cutoff solenoid
I haven't been able to figure out the answer to this one. On the side of the body of the SMC double solenoid valves are two small ports labled PE and PX (I think). Does anyone know what these are for? The reason I am asking is that we are considering mounting this solenoid in the vacuum line to "lock in" vacuum. The problem is that the solenoid valves are pilot actuated, requiring a minimum of around 20 psi to actuate. So in order to actuate the valve we need to apply a pilot pressure. So are the PE or PX ports for an external pilot pressure? The people want to know!
Vacuum Valve Andrew Blair Pneumatics 14 12-03-2007 19:49
Vacuum Generator Peter Matteson Technical Discussion 0 04-02-2005 15:58
Vacuum NoRemorse Rules/Strategy 25 22-01-2004 12:34
Vacuum nwagers Pneumatics 16 31-10-2003 15:57
thermal cutoff protection on VanDoor Motor archiver 2001 1 24-06-2002 01:02
