Go to Post It all depends on which box your trying to think outside. - ItsPat [more]
Unread 24-02-2007, 14:38
Dave K.'s Avatar
Dave K. Dave K. is offline
Engineer/Mentor
FRC #0930
Dave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to behold
Re: battery connector
Jeff,
It is a Molex connector and available through Digikey. They will also build custom battery packs to your specifications if you need something bigger than the 700ma Hr pack that is in the kit.
I was unable to find any Molex connector that was mechanically the same, perhaps you can reference Molex part numbers.
Dimensionally, the only connector I could find that mated to this is the Tyco (Amp) Mate-N-Lok series connector. I confirmed this using a caliper to measure the existing connectors and compare them against Tyco's drawings, as well as confirming that they mate properly with the IFI supplied connectors.
On these parts, and many others, Mouser is a bit cheaper than Digikey and if you just need a few dollars worth of stuff, won't hit you up for a minimum charge.
--Dave
Backup battery connector jgannon Electrical 2 16-04-2007 16:03
Best 6 Gauge Wire Battery Connector Alex698 Electrical 8 03-10-2006 23:45
where do tyou buy the battery connector and circuit breaker John Gutmann Electrical 16 14-06-2006 18:43
Legality of Different Battery Connector sanddrag Electrical 12 25-01-2004 19:22
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
