Go to Post It's easy to get so caught up in the intensity of build that we forget we need some down time to recharge and get a fresh head. Taking a day off will only happen if you make it a priority as important as any other team meeting. Long hours do not equate to productive hours. - Greg Hainsworth [more]
Unread 24-02-2007, 14:56
Mr MOE's Avatar Woodie Flowers Award
Mr MOE Mr MOE is offline
MOE 365 Team Coordinator
AKA: John Larock
None #0365 (Miracle Workerz)
Mr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond repute
Re: pic: MOE 2007 - MOEzilla
Thanks for the comments gang. It's great to see lotsa bot photos online to start examining designs and thought processes.
I can answer a few questions...
Our grabber does rotate about our vertical arm, about 180-degrees. The grabber does not pivot on it's horizontal axis. It is not that heavy - 5-6 lbs - and does not cause a problem being high in the air. No need for wheelie bars (this season, anyway).
We are not using Banebots.
Ramp Actuation - we have only run a few tests. Need to run more to determine best method.
MOEzilla loads tubes from the front. It appears to load from the side due to grabber position in the photo.
Ramp material -luan board with stiffening panels made of composite honeycomb sheets.
Can't wait to test MOEzilla in competition! See all of you headed to Rochester in two weeks. Best of luck to teams competing on Week 1!
MOE Celebrates 18 Years in FIRST this season!
2007 CMP Chairmans Award - thanks to all MOEboteers, past and present!
pic: MOE in Atlanta Steve Howland Extra Discussion 11 03-05-2006 17:02
pic: MOE cheering Carol Extra Discussion 1 04-04-2006 11:28
pic: EL - MOE Mr MOE Extra Discussion 3 19-09-2005 22:15
pic: MOE 365 Teaser CD47-Bot Robot Showcase 2 14-02-2004 17:24
pic: MOE stacking tubby CD47-Bot Extra Discussion 3 21-05-2003 21:44
