Go to Post So we can bring 6x more to the Lunar Regional than all other regionals? no fair to those not going! - BBray_T1296 [more]
Unread 24-02-2007, 19:51
technoL's Avatar
technoL technoL is offline
AKA: Noelle Manning
FRC #0108 (SigmaC@T)
technoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud of
Send a message via AIM to technoL
108 Scoring in Autonomous
108's 2007 Robot Revealed!
Here is a video of our robot scoring in autonomous mode: http://www.youtube.com/watch?v=b0plubOXnU8
Team Leader | Mechanical | Driver | SOAP | Anything
2008: NJ GM Industrial Design Award, 4th Seed | FL Rockwell Automation Innovation in Control Award, 1st Seed, Semifinalists
2007: FL Finalists | LV Xerox Creativity Award, Quarterfinalists | Mission Mayhem Champs
2006: FL Delphi's Driving Tomorrow's Technology | Curie Quarterfinalists
Unread 24-02-2007, 20:17
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Re: 108 Scoring in Autonomous
Looks great guys. What type of feedback are you using to drive to the proper position?
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 24-02-2007, 20:29
intellec7's Avatar
intellec7 intellec7 is offline
108 programmer
AKA: Gustavo
FRC #0108 (SigmaC@ts)
intellec7 is on a distinguished road
Send a message via AIM to intellec7 Send a message via MSN to intellec7
We are using two different feedback techniques.
For the linear "joint" (which is not used in the video) there are three stationary reed switches which detect when a magnet (located on the moving telescope section) are within a few millimeters proximity. Using a state machine, controlled motor direction, we infer 5 states of the telescoping arm position bottom, middle, top, and two states for any area between those two intervals. We can then find out where we currently are, and using another state machine, control the motor accordingly to become where we want to be.
The two rotational joints both have banebot encoders. We can infer relative angular position from starting positions (these will eventually be zeroed with limit switched). We implement a simple proportional feedback control. This is especially needed for the last joint (the wrist is what I think we agreed on calling it) because it moves extremely fast.
We saw no need to implement a full PID routine for these joints. We also felt no need to implement any form of mathematical control for the elevator due to the fact that it pretty much stops within very few milliseconds of commanding it to stop.
Unread 24-02-2007, 20:37
Sounds cool for controlling the arm postion. How about driving to the proper position?
Unread 24-02-2007, 21:05
intellec7's Avatar
108 programmer
AKA: Gustavo
We are relying solely on information from the camera. We do have encoders installed, but currently do not implement them since dead reckoning is not viable this year for the rack moves at every match.
We set positive velocities of both wheels until the tilt angle reaches a certain value and we offset that on both wheels for the pan angle. The result is that the robot drives toward the light while driving forward. We created a raw drive function that does basically the same thing as the one joystick arcade control found in the default code.
Unread 24-02-2007, 22:41
d.courtney's Avatar
d.courtney d.courtney is offline
AKA: David
FRC #0781 (Kinetic Knights)
d.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud of
will the arm go any quicker, was it that speed because of testing purposes? it seemed a bit slow...but maybe its just me. either way congrats on a successful autonomous and good luck at your regionals
Unread 24-02-2007, 22:45
bjimster1's Avatar
bjimster1 bjimster1 is offline
AKA: Jimmy Bourne
FRC #1029 (Wolvcats)
bjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nice
Send a message via AIM to bjimster1
looks good, glad to see you guys finally got it working.
-2006 UCF Quarterfinalists w/ 1345 & 21
-2005 Peachtree Quarterfinalists w/ 1180 & 462
-2005 UCF Quarterfinalists w/ 1694 & 348
CMU '11
Unread 24-02-2007, 23:00
evanisthat!'s Avatar
evanisthat! evanisthat! is offline
Captin' Kassof
AKA: Evan Kassof
FRC #1902 (Exploding Bacon)
evanisthat! is just really niceevanisthat! is just really niceevanisthat! is just really niceevanisthat! is just really nice
Send a message via AIM to evanisthat!
Thanks
The arm goes that fast because it is powered by a globe motor with a 30:1 worm gear reduction. We couldn't use a larger motor or a chain and sprocket system because the entire transmission needed to fit into a very small space (it fits into a 3"x3.25"x3.5" box). If it were any larger we would lose telescoping height to fit the extra size in the 4 foot height. Alas, the telescoping part (not used in the video) is very fast, so with that and the arm, we can reach the top level in about 5 seconds.
-Evan
108!!!
2007 Las Vegas Xerox Creativity Award winners!
2007 Las Vegas Quarter Finalists, only alliance to challenge the champs!
2007 UCF Finalists... thanks to 1902, 179, and 386 for the crazy jump in!
2005 UCF regional quarter finalist...
2005 Midwest regional quarter finalist...
2005 UCF Website Winner
2005 Midwest "Delphi Driving Tomorrow's Technology" Award.
2005 Championship Curie Division Champions. (thanks to team 175 and team 33).
Unread 25-02-2007, 12:49
freestylemotox's Avatar
freestylemotox freestylemotox is offline
Matt Tucker
AKA: M Tuck
FRC #0302 (Dragons)
Team Role: Driver
freestylemotox is a glorious beacon of lightfreestylemotox is a glorious beacon of lightfreestylemotox is a glorious beacon of lightfreestylemotox is a glorious beacon of lightfreestylemotox is a glorious beacon of lightfreestylemotox is a glorious beacon of light
Send a message via AIM to freestylemotox
awsome job guys.....looking good
Unread 25-02-2007, 21:29
Barry Bonzack's Avatar
Barry Bonzack Barry Bonzack is offline
Impossible to rain on my parade.
Barry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond repute
Send a message via AIM to Barry Bonzack
Looking really good guys. Looks like you are bouncing back and are going to be a force again this year. Can't wait to see your team in 2 weeks!
Chair of Florida FIRST Alumni
Orlando Regional Planning Committee
FIRST Tech Challenge Florida Leadership Team
Program Planner on the Orion Spacecraft at the Kennedy Space Center
Twitter: @FL_FIRST_Alumni
Events I'm Emceeing/Game Announcing:
1/10/2015 FTC Jacksonville League Championship
1/11/2015 FTC Central FL Tesla League Championship
1/17/2015 FTC South Florida League Championship
1/24/2015 FTC Tampa/St. Pete League Championship
2/7/2015 FLL Orlando Regional
2/14/2015 FTC State Championship
2/26-2/28/15 FRC South Florida Regional
3/8/2015 FLL State Championship
3/12-3/14/15 FRC Orlando Regional
4/22-4/25/15 FIRST World Championship Event - FTC Franklin Field
Unread 26-02-2007, 08:05
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
I have to agree with Barry's post above this robot looks much better then the last couple of years robots. Evan the way you described your worm gear drive for the arm it sounds alot like the 04 setup on 108. One final thing what are you using to drive that beast of a chasis? Looking great can't wait for Florida regional.
-Drew
Team 1251 The TechTigers
"Inspiring future innovators, one stripe at a time"
2004 Rookie All Star Orlando Regional
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
2013 South Florida Regional Winner
Unread 26-02-2007, 10:30
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Very, very nicely executed. I hope we see a lot of this during the competitions!
-dave
Unread 26-02-2007, 12:03
technoL's Avatar
AKA: Noelle Manning
We are using the evil Banebots transmission from the kit with the adapter and 4 CIMs and 6 IFI wheels.
-No L
soap 108 EnemyWalksIn47 General Forum 4 10-02-2007 21:08
pic: 108 Arm/Scoring Prototype technoL Extra Discussion 1 18-01-2007 13:01
Autonomous Scoring positions Rohith Surampudi Rules/Strategy 4 13-01-2007 22:37
Autonomous scoring - How many? meaubry Rules/Strategy 17 09-01-2007 00:46
Scoring Corner Goals During Autonomous CronosPrime1 Programming 18 22-01-2006 18:04
