Go to Post Texas! Here we come! - Harrison [more]
Unread 24-02-2007, 21:09
Rapt0r9's Avatar
Rapt0r9 Rapt0r9 is offline
AKA: Tyler
FRC #0747 (Flight Crew)
Rapt0r9 will become famous soon enoughRapt0r9 will become famous soon enough
Team 869's Custom Controller
We've never really done anything in terms of custom controllers. We did make a really cool board two years ago with strobes, cathodes, and diamond plate, but we've always used the old joysticks. This year I was going to do some work with the Chicklet, but got tired of waiting to be able to order it. I decided to make a custom controller for the secondary driver. Once we finished preping the aluminum box, we mounted a handle, db15 connector, fuse, and a molex connector, for cathodes. Ironically, the only colors we could find for cathodes this small were purple or green and we picked green. Our larger cathodes in the joystick box are blue, so it looks nice together. We just finished writing all of the code for this Monday night, but haven't gotten around to taking pictures.
Basically, there are four leds, two red and two green, which are used to display twelve different bot statuses. Then there is another blue led to show when a switch on the box is on. There is also an led built into the red safety switch and we have it wired to turn on when the switch is engaged. There are also bi-directional leds by the connectors (db15 and molex) to show that the polarity of the connection is right.
ID:	5149  Click image for larger version
ID:	5150  Click image for larger version
ID:	5151  Click image for larger version
ID:	5152  Click image for larger version
Unread 24-02-2007, 21:23
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Re: Team 869's Custom Controller
Nice looking controller. I've got one of those switches with the red safety cover too. $5 at RadioShack- I just had to have one.
Are you planning to use that at competition because I'm pretty sure anything that's green is illegal to have. Last year we put lights in our OI and was told we had to turn them off.
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 24-02-2007, 21:31
Rapt0r9's Avatar
AKA: Tyler
From our experience with the joystick board, we found that we can't have cathodes on regardless of the color, they were blue, so we are going to leave the green cathodes off during the matches. Also, haveing them on could screw with the vision systems of the bots, so we wouldn't really want to use them during a match.
That safety switch must have been the most expensive thing in there (cathodes were donated), but it is just so cool. It really doesn't have much of a purpose either because it is just an overide.
I'll have to post pictures of our board along with the controller when I get back to school. The two together look pretty cool, kinda a cold metal look.
Unread 24-02-2007, 22:48
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
if your looking for cold cathodes. http://www.oznium.com/ they supplied FIRST with their cathodes and there the cheepest place i could find. like $6.50 for 2 x 12" CC's ive ordered some stuff from them and it worked fine.
/forest
Unread 24-02-2007, 23:08
Rapt0r9's Avatar
AKA: Tyler
Well for cold cathodes, we were able to get some donated by a car modification shop where a team member works. They are the tiniest cathodes I've ever seen. Like 6 inches in length with a half inch diameter.
The cool thing is that our cart had large cathodes on it, like 3 feet long, and it had some strobes. So, the cart, board and this would look really cool together, but this year we needed to build a new cart, so the cathodes went with it.
BS Information Technology - NJIT (2009 - )
Team 869 (2004 - 2008, 2011 -), Team 1811 (2010), Team 869 (2009), Team 613 (2009 - 2010)
"Nothing in this life worth having comes easy."
Unread 25-02-2007, 09:57
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
I get all my cathodes and other lights from http://www.xoxide.com (under Computer Lighting on the left)
2 12" cold cathodes are 6 bux. They also have sound controllers (very cool...)
Just a little FYI
Jacob
Unread 25-02-2007, 11:38
Jacob,
Just a heads up, the inspectors at your event will look very closely at your OI setup when going through inspection. External power will be one of the things that will have a much closer examination.
P.S. You did read the rule about shipping the OI with the robot right?
Unread 25-02-2007, 12:14
Rapt0r9's Avatar
AKA: Tyler
Al,
Actually, I wasn't aware that we need to ship the controller with the robot. I know we put the actual OI in the crate, so we currently have last year's on the board. I past years we always brought our controller because we either didn't want it to damage the robot (our controller weighs about 40 - 50 pounds). I'll look into it and see what type of issues we may run into.
Thanks for all of the cathode info. It is a bit too late for this year, but definatly something for next year.
Unread 25-02-2007, 12:24
Aidan F. Browne's Avatar Unsung FIRST Hero
Aidan F. Browne Aidan F. Browne is offline
Engineer
AKA: The Aidan-bot
Aidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond repute
Unhappy Re: Team 869's Custom Controller
Originally Posted by Manual Section 4.3.4 New: Required Crate Contents
Teams must include:
  • the Robot
  • the Operator Console
    • See section 8 for definition of Operator Console
    • If you use a computer as part of the Console, you do not have to ship the computer, but may not continue to program your dashboard
  • the two (2) Kit of Parts 12VDC batteries
Originally Posted by Manual Section 8.2 Definitions
OPERATOR CONSOLE – the Innovation First-provided Operator Interface unit and any associated equipment, control interfaces, display systems, structure, decorations, etc. used by the DRIVERS to operate the ROBOT.
'nuff said
Unread 25-02-2007, 12:27
hayakuneko's Avatar
hayakuneko hayakuneko is offline
AKA: Joshua
FRC #0696 (Circuit Breakers)
hayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of light
Send a message via AIM to hayakuneko
Originally Posted by Rapt0r9 View Post
Al,
whoa seriously?! your control board really weighs that much? how do you guys carry it around... i would think that control boards should be relatively light so its easier to carry... thats why i made this year's about 8lbs, but im not sure its exact weight cuz i fell asleep during the all nighter...
it's the black one ... the one behind it was last year's
2007 San Diego Regional Winners (w/ 330 & 835/1216)
2007 Los Angeles Regional Finalists (w/ 980 & 580)
Unread 25-02-2007, 12:30
Rapt0r9's Avatar
AKA: Tyler
Well, I suppose I'll pass this on to our engineers and mentors and see what they think we should do. I know the rules about programming and not doing it after build season, but the OI is new to me.
Thanks for the clarification.
Unread 25-02-2007, 12:33
Rapt0r9's Avatar
AKA: Tyler
That is a very nice board. We were thinking of doing something like that this year, but were short on time. The guys who built ours decided that style was better than practicality, so they built it our of 80/20 and covered that with diamond plate. Although this year it should be slightly lighter because we have eliminated two joysticks and replaced them with the box, but our drivers hate carrying it.
Unread 25-02-2007, 12:39
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Well, I suppose I'll pass this on to our engineers and mentors and see what they think we should do. I know the rules about programming and not doing it after competition, but the OI is new to me.
Ouch. This hurts. I would imagine that since you didn't ship your console and it is now illegal for you to bring it to competition you'll have to build a new one from scratch on Thursday at your first regional. Better ask some questions on the Q&A or contact FIRST and see what they say. Maybe they'll be lenient, but this rule is pretty clearly stated.
It really pays to read the manual cover-to-cover...
Unread 25-02-2007, 12:42
Rapt0r9's Avatar
AKA: Tyler
Well if we do have to rebuild, we can just use joysticks and a random piece of lexan for the board. It will look aboslutely hideous, but at least we can still compete.
Unread 25-02-2007, 12:52
rohit's Avatar
rohit rohit is offline
Inventor Person
FRC #0617 (The Springers)
rohit has a spectacular aura aboutrohit has a spectacular aura about
Send a message via AIM to rohit
nice: this is ours
http://www.chiefdelphi.com/media/img...6f696f5e_m.jpg
pic: Team 617 Controller rohit Extra Discussion 1 21-02-2007 13:08
pic: Team 865 custom 2-speed gearbox geo Technical Discussion 2 20-04-2006 18:13
pic: Team 521 Custom Frame Steve P Extra Discussion 9 01-02-2005 11:19
Using Custom Inputs on the Controller Board schenkin Programming 10 27-01-2005 10:26
Custom Mod Controller. Josh Hambright Electrical 9 17-01-2003 08:05
