Go to Post “I hope you all had a good weekend. If you didn’t you can try again in five days.” -Honors Debate teacher - Joe J. [more]
Unread 14-02-2007, 15:15
ntroup's Avatar
ntroup ntroup is offline
WildStang!
None #0111 (Wildstang)
ntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud of
Re: Radio cuts out, student's foot run over
Originally Posted by Eldarion View Post
(Our team ran through a testing procedure on almost all 40 channels; we have the results if anyone is interested.)
I am quite curious how you did this? By default, the OI will only allow the use of 6 channels.
From the OI Reference Guide (from ifirobotics.com)
Channel 40 is the default channel and will always be selected unless a different channel is selected by changing the MSB on the Team Number dipswitch. Channels 01, 04, 13, 22, 31, or 40 are available if the MSB Team Number dip switch is Open (see section 8 for details on team number positions).
The rest of the channels, to my understanding, are only available through the competition port, which is an undocumented protocol.
-Nate
Unread 14-02-2007, 15:24
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
A previously undocumented protocol. I figured it out over the summer last year.
So I now have a homebrew field controller!
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 14-02-2007, 15:32
ntroup's Avatar
WildStang!
Interesting. Does this involve talking to the OI through its competition port to set the channel number, or configuring the modems themselves?
I know there has been lots of discussion in years' past concerning the information going between the OI and the Arena Controller (through the Competition Port), but that conversation always led to discussions of how 'GP' it would be to reverse engineer that information.
-Nate
Unread 14-02-2007, 15:35
Eldarion's Avatar
Yes, I talk to the OI through the competition port (I emulate an Arena Controller). As I am not releasing any info on the protocols or pinouts, I think it is acceptable as far as GP goes.
-- Thomas Paine
-- Anonymous
Unread 14-02-2007, 22:22
Eldarion's Avatar
I guess they only tested 4 channels; sorry about that!
Here's the info anyway:
Channel 1 tested for 10 minutes, cut out 14 times.
Channel 14 tested for 5 minutes, cut out 6 times.
Channel 20 tested for 5 minutes, cut out 6 times.
Channel 38 tested for 5 minutes, cut out 4 times.
-- Thomas Paine
-- Anonymous
Unread 15-02-2007, 13:17
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
We have found a problem also that causes the robot to take off, when the dongle is switched from Autonomous/Kill, to Operator Control mode.
It seems the first value read from the joystick was 0 (which, when the value was copied to the Victor, made the motor go suddenly full-speed). After that the joystick values were read correctly. This was with Master Code V12, we have since upgraded to V13.
At first we put in a 1/2 second delay in Operator Control mode, before reading the joystick the first time. It seemed to work, but as code was being developed we had other accidents where motors were set to full-speed.
So we put the Victor output for left-side and right-side into two C procedures. The procedures check for legitimate PWM values 1-253. Joystick input procedures were similarly modified, to avoid the extreme values 0 or 254.
In this way, a 'glitch' or coding accident cannot send 0 or 254 to the Victors.
This has solved our problem.
Unread 15-02-2007, 16:55
Samara's Avatar
Samara Samara is offline
AKA: *~*Jackie*~*
FRC #1511 (Rolling Thunder)
Samara will become famous soon enoughSamara will become famous soon enough
Send a message via AIM to Samara Send a message via MSN to Samara Send a message via Yahoo to Samara
our team had a similar incident which was mentioned in another post but yeah scary stuff because it came at me, one of our mentors had to dive infront of it.
Tell me and I forget; show me and I remember; involve me and I understand.
-Anonymous
Unread 15-02-2007, 17:18
Also, from our experience, this problem will only get worse in competition mode, not better! Apparently, at lower channel numbers, the radios are worst. (Our team ran through a testing procedure on almost all 40 channels; we have the results if anyone is interested.)
Can you confirm that the radio was mounted per IFI's recommendations? http://www.ifirobotics.com/forum/vie....php?p=833#833. Specifically, team 179 found that the radios had to be 6-8" away from metal.
Unread 15-02-2007, 17:36
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
we too have had many problems with the V14 firmware, and some with the V13. We've had the robot continue for a full second after disabling with V13, and more than that with V14
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 16-02-2007, 15:49
grantf's Avatar
grantf grantf is offline
Software Engineering Mentor
FRC #4061 (SciBorgs)
grantf has a spectacular aura aboutgrantf has a spectacular aura about
The following is our compliance with the IFI radio recommendations.
You need to be running Master Code 13 when using the new 2007 Radios and a 2006 or 2007 OI.
We were running the v14 Master code when the robot took off.
We are using the 2007 OI and RC only.
As for intermittent stalls; make sure all power connections are tight, from the battery, through the circuit breaker panel and to all devices. Pull on all your power connections. Repair any that are loose or come free. It is best to solder all wire connections; a crimp connection can come free.
We are using quick connects (spade connectors) for all 20 amp lines.
These connectors are from this year's kit and fit very tightly.
All connections were checked.
A charged backup battery was in use.
A fresh main battery was installed only seconds before the incident.
Intermittent stalls can be from breakers tripping. If you have all green LEDs on the RC unit, you do not have a radio problem. If your motors are drawing too much current, the breakers will trip and the motors will be dead for a few seconds until the auto-resetting breaker has reset.
There were times when we only saw the Valid TX light on the OI go on.
Other times the No Data/Radio light was solid red.
If you see the RC’s Radio Modem LED flashing Red, the RC unit is not receiving radio data. This can be caused from Interference from another source, bad Radio Modem Cables, Radio Modems (OI or RC), or in rare cases the RC or OI unit.
Didn't really see this because we were busy chasing the robot.
For best radio reception, follows the guidelines: 1) the RC and OI Radio Modems should be mounted high and perpendicular to the playing field. 2) Both the Radio Modem Case and the moveable Antenna should be perpendicular to the playing field. 3) The Radio Modems and DB9 Radio Modem Cables should be kept as far as possible from any High Current Wiring, Motors, and Victors ….etc. 4) The Radio Antennas should not be touching any other surface. 5) The Radio Modem Case and Antennas should not be shielded by any metal structure. 6) There should be a “Clear Line-of Sight” between the RC and OI Radio Modems case and Antenna. 7) Interference from another radio source can be solved by changing to a different practice channel.
  1. Check
  2. Check
  3. Check
  4. Check
  5. Check, I think... the RC Radio Modem is mounted vertically, about 2 feet off the floor, very near 2 aluminum support colums (1 inch square AL tubing, about 3.5 feet long). However, the RC modem is not "sheilded" in a Faraday-Cage sense... most (90% or more) of the antenna's field of view is unobstructed.
  6. Check
  7. Check, but we haven't tried another channel yet.
I contacted IFI just the other day and reported this issue (robot taking off while apparently disabled).
They said that in 5000+ systems shipped, they have never once come across this issue.
IFI is waiting for us to reproduce the problem.
It would be great if other teams who are experiencing radio issues could try to produce this problem as well.
Thanks for all the feedback,
Grant
Unread 16-02-2007, 19:05
IFBen IFBen is offline
AKA: Ben Birrer
FRC #1566 (Ammo Knights)
IFBen is an unknown quantity at this point
This happened to me at our team sponsored dinner/fundraiser. Our battery got so low we went to turn it around and wheel it back to the front of the hall and it spazzed and ran me over!
Unread 16-02-2007, 20:50
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Grant
Did they really say that? That seems a bit like "You're making it up" to me..
..anyways, would it be possible to test this with older radios/firmwares from last season? Sorry if you already tried that and I missed it, I'm kind of in a rush here.
Matt Krass
Unread 17-02-2007, 11:00
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
Originally Posted by UlTiMaTeP View Post
He stated the radios were mounted correctly. The radios this year for many teams are defective. The radios need to get an RMA'ed and replaced chances are. You are not alone, the majority of the teams in my area are having the same radio cutting out problem.
We are having a similar problem. I started a thread including a poll (not many people saw it, but still...). It is here: http://www.chiefdelphi.com/forums/sh...ad.php?t=54106
I am getting SO frustrated with IFI. The very least they could do would be to acknowledge that there is a problem.
Anyway, hopefully we can find an easy fix for this (though that doesn't seem likely).
Paul
Unread 17-02-2007, 11:22
Eldarion's Avatar
We are using the 2006 radios on the 2007 RC with FW 13 with no problems.
-- Thomas Paine
-- Anonymous
Unread 25-02-2007, 00:43
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Yeah... We have a set of 2006 radios that work beautifully. The 2007 radios crap out all the time. And how do they expect you to mount your radio so it is '6-8"' completely away from metal? Do they want a foot long piece of plywood sticking out from the middle of your bot in a direction away from any other part of the bot that doesn't violate the height limit and in a place where the cord can't get caught in moving parts / get run over by robots climbing up your ramp?
Why do the old 06 radios which are RS-232 have no problem, while these new larger RS-422 radios have all sorts of problems.
Also, they wont let us use the old ones. WHY???
Originally Posted by www.ifirobotics.com/radio_modem.shtml
Note: These radios are new for 2007 and can not be used/interchanged with previous radios/modems.
Jacob
Controll over Radio? interfect Programming 10 16-01-2007 21:39
Student's Prize Is a Trip [To Atlanta for Natationals] Into Immigration Limbo Spikey FIRST In the News... 36 14-07-2006 21:24
need 2003 radio/help with old radio MaxM Technical Discussion 2 04-01-2004 15:31
Robot motion after the time has run out. Randy Ai Rules/Strategy 1 06-01-2003 17:17
Radio Cut-Out Dan 550 Technical Discussion 7 02-04-2002 08:14
