Go to Post "Recycle Rush? What's that, some sort of charity marathon?" - Chak [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 22-02-2007, 14:44
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Re: Attention Robot Inspectors:
Originally Posted by Rob View Post
Hi Guys,
After doing a bit of research on the 2 motors (9012 and 9003) and talking to FIRST, we are making much ado about nothing.
I hope those are your words, not FIRST's. If their's, I wonder why I called all over and drove 120 miles to get the right ones. If their's, I guess the FP service center guys had me pegged when they thought I was nuts for caring!
R27> Motors, pumps, and, Robot Controllers from previous robots can not be used in addition those provided in the 2007 Kit Of Parts. They may be used as direct one-to-one SPARE PARTS for those provided if the provided part fails or is damaged. They can only be used if they are identical to the part being replaced. Note that the Fisher-Price motor found in the 2007 Kit Of Parts (Part number 00968-9012) is different from the Fisher-Price motors used in most previous FIRST competitions. Only the Fisher-Price 00968-9012 motor may be used as a SPARE PART for the Fisher-Price motors provided in the 2007 Kit Of Parts.
Unread 22-02-2007, 14:48
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Those are my words, not anything from FIRST. As far as FIRST is concerned, the only FP motor that can be on your bot is the 9012 version.
The reason I was saying much ado about nothing is that I was worried all of the hours tuning our control loops for the arm would be brushed away if the motor performance was different after the swap. Since the motor performance is identical in our application (not near stall torque and low current) I have no concern that changing the motor will cause us to have to re-tune our system.
Thanks for the help.
RAZ
Unread 22-02-2007, 16:54
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
According to the guys at the service centers, some teams didn’t care if they had the right motor. Some even figured they could “get away with it” by swapping the sleeve with part number on it.
When we mechanically busted a FP (busted it up good!), we called our FP service center and they knew exactly what we needed. However, the gear box they had with the clearly marked correct part number had the wrong FP motor in it - a 9003 instead of a 9012. We were going to shrug our shoulders and just buy them because they were in the right gear box but our buddies in Kileen (Team #647 the CyberWolves) saved our butts and double-checked with FIRST and made sure we got the right motors.
And boy are we glad they did. While programming the robot arm one of the variables in the code wasn't quite right and we got to smell the sweet smell of a thermo cutoff switch burning off its factory coating. Fortunately for us once it cooled down the motor was as good as new! Having the 9012 versus the 9003 was a lifesaver!
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 22-02-2007, 17:30
Kymber's Avatar
Kymber Kymber is offline
Assistant Director, Lone Star
Kymber is a glorious beacon of lightKymber is a glorious beacon of lightKymber is a glorious beacon of lightKymber is a glorious beacon of lightKymber is a glorious beacon of lightKymber is a glorious beacon of light
Ok so I've been doing a little digging and found this in the FIRST Forums, it looks like FIRST is aware of the issue and has made some type of arrangement to correct it. http://forums.usfirst.org/showthread.php?t=3916
this was posted at the beginning of the month so I am not sure if this was just for build season or not but it's worth checking into. Hope it helps.
Kymber Weymouth
Assistant Regional Director/Judge Recruiter
Lone Star Regional
Unread 23-02-2007, 11:18
steveg's Avatar
steveg steveg is offline
Livin' the Dream
AKA: Stephen Guerrera
steveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to behold
Send a message via AIM to steveg
If by making arrangements to correct it you mean ignoring emails (at least in my personal experience), then yes.
Unread 25-02-2007, 11:53
FYI,
The current limit in this motor trips at well below stall current. In test we found the motor trips at about 24 amps. Since it is a thermal trip, each successive trip causes a much longer recovery.
Unread 25-02-2007, 13:16
Brandon Holley's Avatar
Re: FP 9003 vs 9012 (was Attention Robot Inspectors:)
We also got 9003s at the manchester kickoff. It took something to the tune of 5 weeks to get a response out of FIRST, but they did finally respond saying they were sending us the correct motors, which means we have to take apart the whole assembly at Boston to replace our motors. Not a fun situation.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 12-03-2007, 16:35
Lithium's Avatar
Lithium Lithium is offline
Engineering Mentor
AKA: Shea
FRC #2449 (Out of Orbit Robotics)
Lithium is an unknown quantity at this point
Well, hopefully we were the only team that got bit by this mistake. We used 9003s in our prototype design, not thinking there was a difference. The design worked great, and we were lifting 160 pound bots on our ramps with no problems in our lab. Thursday morning at the Phoenix Regional, a student reminded us we had to use the 9012s so we made a quick swap out on the bot, thinking there would be no big deal. After the first few matches of not being able to lift anyone we were going nuts trying to figure out what happened..?? After two days of trying to figure it out, we realized that the current limiter was cutting us off on any bot over about 100 pounds. That being said, our primary design/plan of lifting 2 bots per match securing 60 points, got us 0 bots per match. We were dead in the water and useless at the Phoenix regional because of it. Just a valuable lesson for anyone trying to lift bots or making any last minute switches on these motors.
~Shea~
Lithium (aka Shea)
www.team2449.com
Past teams: 1897, 1592, & 233
www.team1897.com 2006 AZ Champions (teams 1006 and 60) 2006 AZ Rookie All Star
www.team1592.com 2005 FL Champions (teams 233 and 179) 2005 FL Rookie All Star
www.thepinkteam.org
2004 NY Champions
Fisher Price Motor 9003 vs 9012 Mike Norton Motors 5 07-02-2007 19:27
So your original robot design was..... LightWaves1636 General Forum 23 05-02-2006 03:36
Other team inspectors uberchris General Forum 18 02-03-2003 11:24
Inspectors Jeff Waegelin Regional Competitions 5 28-02-2003 22:37
bribing the robot inspectors... archiver 2001 3 24-06-2002 00:11
