Re: Real time clocks, out of the question?
The way Kevin's code sets up the interrupt is the best. The other example code posted/referenced all appear to reload the Timer register each time the interrupt is serviced, and the interrupt service latency then becomes an additive value to the timer's period. To some extent, only reloading the upper byte will help avoid the problem, but its easy to avoid the problem all together by just configuring the timer differently. An added bonus is that a few instruction cycles are removed from the ISR by not having to reload the register each time.
Another thing to remember here is that this microcontroller does not have a divide instruction, so including divide operations in an interrupt routine is forcing the microcontroller to execute a lot of instructions on a frequent basis. Some of the examples provided utilize variables wider than 8 bits, but I didn't notice any cautionary notes for routines that access these variables outside of the interrupt service routine. Because this micrcontroller operates on 8 bits at a time, if a routine were testing a 16 or 32 bit variable and an interrupt occurred in the middle of such a test, the ISR will end up invalidating the foreground operation that it interrupted. No amount of 'volatile' declarations will fix that problem. If the timer value absolutely MUST be greater than 8 bits, then the foreground operations that access this variable must temporarily disable the relevant timer interrupt prior to accessing or manipulating the variable, then re-enable the interrupt after the operation is complete. I tend to use timers that count down to zero because most microcontrollers are able to test for a zero condition in a single instruction, whereas testing for a specific value tends to use two or more instructions... and this is something which is true for the PIC18. In other words: Code:
if (a) {
do_something();
if (a>59) {
do_something();
As such I tend to write timer ISR's this way: Code:
// 1ms timer tick ISR
if (Timer1ms) {
--Timer1ms;
if (!(--Timer10)) {
Timer10 = 10;
if (Timer10ms) {
--Timer10ms;
if (!(Timer100)) {
Timer100 = 10;
if (Timer100ms) {
--Timer100ms;
if (!(Timer1000)) {
Timer1000 = 10;
if (Timer1s) {
--Timer1s;
}// !Timer1000
} // !Timer100
} // !Timer10
Timer10ms = 100; // Start Timer, 100 * 10ms = 1 second
// elsewhere
if (!(Timer10ms)) { // if timer expired
do_something();
if (Timer) { // if timer is running
if (!(--Timer)) { // decrement, and if it hits zero
Event_Flag = 1; // set event flag
Event_Flag = 0; // make sure event flag is cleared
Timer = 100; // start timer
// elsewhere
if (Event_Flag) {
do_something();
I wrote some code that starts uses the timer mentioned above that turns on an LED 1:30 seconds into the operator controller part.
Our team has a "Heads up display" we used last year for shooting, we remade it this year but this was the only use we could come up with. |
Alright. I have another question about how the timer variables work in all of these. I've used storage classes/qualifiers occasionally but I don't understand the significance of using, say, extern and volatile to store the timer variables. Could anyone shed some light on this?
'volatile' tells the compiler that the variable may change on its own and to generate code as appropriate. For optimization purposes, a compiler may read a variable from memory into a temporary register, and subsequent read/write operations to that variable _may_ only occur to the register without updating the memory location. Telling the compiler that the variable is volatile causes the compiler to re-read the variable's memory location each time it is used, and to write it back to memory each time it is updated. 'volatile' would be used for things like hardware periphial registers, as well as things like variables that might change inside of an interrupt routine. Since the compiler can't know why you are telling it that the variable is volatile, it wouldn't generate additional instructions to disable interrupts during critical regions to ensure that a multi-byte variable read/write operation is performed without the potential for another interrupt routine corrupting the operation. Pre-emptive multi-tasking operating systems generally pose the same potential for corruption that an interrupt routine does. The 'static' qualifier allows variables to be declared within a local, rather than global, scope and simply tells the compiler to declare the variable in a memory location that is static, rather than allocating it on the stack frame (or emulated equivilent thereof) of the local function. Any variable declared outside of a function is normally considered a global variable, but unless other source files provide an 'extern' reference, the variable's use will remain limited to that source file, and is sometimes referred to as a 'local global'. The caveat here is that if you were to declare another 'local global' in another source file, the linker will (usually) have a problem with the duplicate declarations, and generate an error. Recognizing that Microchips documentation already presumes a certain familiarity with the "C" language and doesn't really get into all of the specifics, for those that already have a general grasp on the "C" language, two books that I would recommend are: The C Programming Language by Brian Kernighan and Dennis Ritchie, who are the origional authors of "C". A book on C by Al Kelly and Ira Pohl. K&R's book is very terse with minimal examples, but is the bible. The 2nd one is also a bit terse, and goes into depth more than K&R's book. I've included links to Amazon's website as a convienent reference, but retailers such as Barnes & Noble also generally carry these and other good reference books where you can browse before you buy. |
Strangely enough, K&R is sitting right here on my bookshelf. Somehow I hadn't remembered "volatile". I'll go reread through the data types/variables stuff again.
Not to seem pestery... but I've once again confused myself in this code. I read through the PIC's datasheet (timer section) and studied up on the registers. On the good side, I now completely understand all the scalers, clocks, and flags, but I could not seem to understand how the high and low byte registers worked/were needed. I don't see how an integer could go past 65,535, so why does the high byte happen to be able to have a value over that? I also could not find an equivalent for the PR2 register for Timer1. Is that simply not present and do I have to use conventional math to downscale further? Thanks again for the help. |
Timer's 2 & 4 are 8 bit wide timers and have the "PR" registers, the other timers are 16 bit. Timer 1 is a bit special and can be used for a low power, real time clock function. Without a specific reference, I'm not sure what you mean about the high byte having a value greater than 65535. My only guess would be that by setting a value to zero, you'll get an effective divide rate of 65536, but I don't immediately see that in the documentation. The reason that the 16 bit counter is split into two 8 bit registers is that the CPU only operates on data 8 bits at a time. So a 16 bit read/write operation requires two data bus operations to manipulate the 16 bit value. Does that help or did I miss one or more of the questions? |
#7
Ahhh, that explains things a bit. I should have thought about that. RD16 two bytes wide, duh.
Thanks for that tidbit. And the high and low bytes. In the wallclock code (http://www.chiefdelphi.com/forums/sh...t=wallclock.c), the high byte value is.... NEVER MIND Someone can't count their zeros. I still don't exactly understand what the purpose of the high and low bytes are. Is it like an loop condition? Above the max value for a 16bit number counts as an overflow and it resets, setting the flag with it? THANK YOU |
#8
One of the interrupt options is to interrupt on timer overflow, and that is how some of the other examples posted work. If you: - stop the timer - load a 16 bit value into the timer register - reset the interrupt flag - start the timer You will get an overflow interrupt in however many timer ticks it takes for the pre-load value to reach the point of overflow (0xffff -> 0x0000). Having the timer value available could also be useful for calculating the period between two events, such as a transition on an input pin that triggers an interrupt. The input interrupt could read the current timer value, and subtract the timer value of the last input transition to calculate the amount of time elapsed since the last input interrupt. Ideally, one would use something like the CCP module to time stamp an input transition, but in the case of IFI's RC, those pins aren't available as for user Digital I/O pins. As an example, for something like motor velocity control, at slow speeds, if a rotational speed slower than 1 pulse per sample period was desired, you could use period measurement to gain some additional resolution, and above a certain rotational speed, you could switch to counting the number of pulses per period method. Each microcontroller manufactuer has their own ideas on the degree's of flexibility that they make available. Microchip's 8 bit PIC family is pretty average. Some parts have less flexibility, others have quite a bit more. In this case, you have to do the best you can with what they give you... |
#9
I thought the WPI library had built in timers? What's the difference between those and "real time" timers?
Thanks, Nathan |
| Networkable real-time game simulation for 'Aim High'! test it out now | Bongle | General Forum | 11 | 19-03-2006 23:10 |
| Real time photos from the buckeye regional | Greg Needel | Regional Competitions | 4 | 25-03-2004 12:46 |
| Robot motion after the time has run out. | Randy Ai | Rules/Strategy | 1 | 06-01-2003 17:17 |
| Real Time Scoring | archiver | 2000 | 2 | 24-06-2002 00:09 |
| real time chat | SharkBite | CD Forum Support | 4 | 07-02-2002 21:22 |
