Go to Post Those chief delphi kids...they think they're so pimp... - Eugenia Gabrielov [more]
Unread 24-02-2007, 10:27
evan_wilson's Avatar
evan_wilson evan_wilson is offline
QUARK
AKA: Evan Wilson
FRC #2172 (Street Legal)
evan_wilson is an unknown quantity at this point
Send a message via AIM to evan_wilson Send a message via Yahoo to evan_wilson
Unhappy Real time clocks, out of the question?
Hullo everyone. I'm Evan Wilson, lead programmer for Team 2172, St. Edward High School.
Our robot is all crated and shipped off... with horrible loop-counting timekeeping. In the past, I've heard of creating a real time clock with the Timer1 module in the PIC controller.
Is it humanly possible to create such a program? I DO know some PIC assembly, and certainly C. I assume this would be intensively assembly. Also, is there actually a crystal in the controller already? When reading the datasheet for the chip, it almost made it sound as if I'd need to do some whacked out solder job...
I would like to have gotten this done for this year's competition, but seeing as we have no adult mentors (and I'm a junior with a bit of a tight schedule) we couldn't cram in the work for that.
Anyways, thanks to anyone who could help, give links, etc.
Unread 24-02-2007, 10:36
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
Re: Real time clocks, out of the question?
Hi, We too have had te same problem, in easyC there are a total of 6 timers, however, we haven't been able to get any of them to work, i believe timer 1 is used for the camera, but we cant seem to get any of the other timers to work. If any other teams have been able to get them to work, it would be extremely helpfull.
Thanks
Malhon
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
Unread 24-02-2007, 10:39
QUARK
AKA: Evan Wilson
Post Re: Real time clocks, out of the question?
Well, in my case, I've used MPLAB the whole way. But does easyC actually have timers? I dug into the datasheet and found the Timer0 and Timer1 modules in the microcontroller and wasn't sure how to use them.
http://users.tkk.fi/~jalapaav/Electr...ock/index.html
That seems a little helpful.
Unread 24-02-2007, 10:46
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
Yes, EasyC does have timers, six of them. I believe we have used up to three at once, and they all work fine.
What exactly isn't working for your? Could you post your code?
Thanks,
Nathan
Unread 24-02-2007, 10:51
QUARK
AKA: Evan Wilson
Unhappy Re: Real time clocks, out of the question?
Well, the problem is that I don't have any. Without EasyC, I just have the arm calculating based on loop counting. Multiples of 26.2 ms. There's no way I can switch to EasyC this year. I guess that would be a logical solution for next year.
Is there anyone here who has ever written a timer and interrupt routine for a real time clock? That's really the only thing I could worry about anyways. Otherwise I'll just have to stick with loop counting.
Unread 24-02-2007, 11:21
Timers are simple to use, no soldering required.
IFI has a white paper on coding timers that goes into the bits and bytes of it all:
http://www.ifirobotics.com/docs/time...004-jan-14.pdf
For a description of the timer library calls see the MPLAB-C18-Libraries.pdf manual under C:\mcc18\doc.
Here's a sample using the timer libraries:
// In user_routines.c
#include <timers.h>
#define CLOCKOFFSET 60535  //Set timer for 4ms
  // Maximum for 16-bit timer 65535 - 5000 (4ms) = 60535
/* Use Timer3 (16-bits) to control our clock */
/* timer set to 4 ms */
// Call from User_Initialization()
  OpenTimer3(TIMER_INT_ON &
             T3_16BIT_RW &
             T3_SOURCE_INT &
             T3_PS_1_8
  WriteTimer3(CLOCKOFFSET);  /* Preload timer to overflow after 4ms */
  // In user_routines_fast.c
  #include <timers.h>
  // globals declared as extern wherever else they are used
  volatile unsigned long Clockms=0; // 1 millisecond clock
  volatile unsigned int Clockds=0; // 1/10 second
  volatile unsigned int Clocksec=0; // 1 second clock
  //etc.
// In InterruptHandlerLow()
  if (PIR2bits.TMR3IF) /* TIMER 3 INTERRUPT */
    /** This provides us with a clock for timing events **/
    PIR2bits.TMR3IF = 0; /* Clear Timer interrupt flag */
    WriteTimer3(CLOCKOFFSET);  /* Reset Timer to overflow in 4ms */
    Clockms += 4; /* milliseconds */
    Clockds = Clockms / 100;
    Clocksec = Clockms / 1000;
    // etc.
Unread 24-02-2007, 11:29
QUARK
AKA: Evan Wilson
Talking Re: Real time clocks, out of the question?
Thank you very much. I hope my assembly serves me well.
I think I can dig up the differences in the new controller.
Want to be a mentor...
just kidding.
Unread 24-02-2007, 13:23
Kevin Watson's Avatar
La Caņada High School
FRC #2429
I wrote some real-time clock code for the EDU-RC a few years ago. Here's a link: http://kevin.org/frc/2005/edu_clock2.zip.
-Kevin
Kevin Watson
http://kevin.org
Unread 24-02-2007, 13:41
QUARK
AKA: Evan Wilson
Okay. Thanks very much Kevin and Mark. The last thing I need to make sure of is the value for the system clock. In the edu_clock code, it's specified as 10MHz. Does anyone know if there would be a difference in the PIC18F8722? I seem to remember reading something about 32.blablabla MHz somewhere. Or maybe it's changeable...
After this, I deserve to be put back into grade school if I can't do the math.
THANKS
Unread 24-02-2007, 16:28
It's the same 10MHz for the PIC18F8722 we use.
Unread 24-02-2007, 17:36
Stvn's Avatar
Stvn Stvn is offline
FIRST Competition Competer
AKA: Steven Rhodes
FRC #0100 (WHS/CHS - WildHats)
Stvn is an unknown quantity at this point
Send a message via AIM to Stvn
Lightbulb Re: Real time clocks, out of the question?
Originally Posted by SgtMillhouse648 View Post
Hi, We too have had the same problem, in easyC there are a total of 6 timers, however, we haven't been able to get any of them to work, i believe timer 1 is used for the camera, but we cant seem to get any of the other timers to work. If any other teams have been able to get them to work, it would be extremely helpful.
Thanks
Malhon
Remember to preset and start the timers before using them. Timers won't work if they aren't running.
Unread 25-02-2007, 10:32
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
There's a nice set of interface functions for using Timer1 here: http://www.chiefdelphi.com/forums/sh...ht=wallclock.c
Unread 25-02-2007, 13:41
Dave K.'s Avatar
Dave K. Dave K. is offline
Engineer/Mentor
FRC #0930
Dave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to behold
The way Kevin's code sets up the interrupt is the best. The other example code posted/referenced all appear to reload the Timer register each time the interrupt is serviced, and the interrupt service latency then becomes an additive value to the timer's period. To some extent, only reloading the upper byte will help avoid the problem, but its easy to avoid the problem all together by just configuring the timer differently. An added bonus is that a few instruction cycles are removed from the ISR by not having to reload the register each time.
Another thing to remember here is that this microcontroller does not have a divide instruction, so including divide operations in an interrupt routine is forcing the microcontroller to execute a lot of instructions on a frequent basis.
Some of the examples provided utilize variables wider than 8 bits, but I didn't notice any cautionary notes for routines that access these variables outside of the interrupt service routine. Because this micrcontroller operates on 8 bits at a time, if a routine were testing a 16 or 32 bit variable and an interrupt occurred in the middle of such a test, the ISR will end up invalidating the foreground operation that it interrupted. No amount of 'volatile' declarations will fix that problem. If the timer value absolutely MUST be greater than 8 bits, then the foreground operations that access this variable must temporarily disable the relevant timer interrupt prior to accessing or manipulating the variable, then re-enable the interrupt after the operation is complete.
I tend to use timers that count down to zero because most microcontrollers are able to test for a zero condition in a single instruction, whereas testing for a specific value tends to use two or more instructions... and this is something which is true for the PIC18.
In other words:
  if (a) {
     do_something();
Will generate fewer instructions than:
  if (a>59) {
    do_something();
As such I tend to write timer ISR's this way:
   // 1ms timer tick ISR
   if (Timer1ms) {
      --Timer1ms;
   if (!(--Timer10)) {
      Timer10 = 10;
      if (Timer10ms) {
         --Timer10ms;
     if (!(Timer100)) {
        Timer100 = 10;
        if (Timer100ms) {
           --Timer100ms;
        if (!(Timer1000)) {
           Timer1000 = 10;
           if (Timer1s) {
             --Timer1s;
       }// !Timer1000
     } // !Timer100
    } // !Timer10
In order to use these timers in the foreground code, it is as simple as:
    Timer10ms = 100;    // Start Timer, 100 * 10ms = 1 second
// elsewhere
    if (!(Timer10ms)) {   // if timer expired
       do_something();
Likewise, if you want the expiration of a timer to set an event flag, the ISR could be modified like this:
    if  (Timer) {              // if timer is running
       if (!(--Timer)) {      // decrement, and if it hits zero
          Event_Flag = 1;   // set event flag
So the foreground code could do something like this:
    Event_Flag = 0;  // make sure event flag is cleared
    Timer = 100;      // start timer
// elsewhere
    if (Event_Flag) {
       do_something();
Clearly individual timers can be declared as needed, at whatever the most appropriate resolution for a given function may be. In general, I have found that most timers can be designed to work within an 8 bit value... in other words, if I need a timer that normally needs to run for a 1 second period, that a 10ms resolution timer, loaded with 100 provides more than enough precision.
--Dave
Unread 25-02-2007, 14:19
AdamHeard's Avatar
Lead Mentor
I wrote some code that starts uses the timer mentioned above that turns on an LED 1:30 seconds into the operator controller part.
Our team has a "Heads up display" we used last year for shooting, we remade it this year but this was the only use we could come up with.
Unread 25-02-2007, 14:38
QUARK
AKA: Evan Wilson
Smile Re: Real time clocks, out of the question?
Alright. I have another question about how the timer variables work in all of these. I've used storage classes/qualifiers occasionally but I don't understand the significance of using, say, extern and volatile to store the timer variables. Could anyone shed some light on this?
Networkable real-time game simulation for 'Aim High'! test it out now Bongle General Forum 11 19-03-2006 23:10
Real time photos from the buckeye regional Greg Needel Regional Competitions 4 25-03-2004 12:46
Robot motion after the time has run out. Randy Ai Rules/Strategy 1 06-01-2003 17:17
Real Time Scoring archiver 2000 2 24-06-2002 00:09
real time chat SharkBite CD Forum Support 4 07-02-2002 21:22
