Go to Post ... the real mark of integrity is doing the right thing even when nobody is watching. - DonRotolo [more]
Unread 25-02-2007, 13:43
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: pic: Team 967's Robot
I assume you are using bumbers, otherwise your robot cannot compete under the "no wedge" rule.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 25-02-2007, 14:18
AdamHeard's Avatar
Lead Mentor
The bottommost portion of the wedge looks to be atleast 4-5 inches high. They probably won't consider it a wedge.
And even if the refs do, they can just bolt some vertical plates onto that extrusion.
Unread 25-02-2007, 17:24
Rick-906's Avatar
Rick-906 Rick-906 is offline
inventor of the hoverbot-2006
AKA: Richard
FRC #0296 (Loyola Northern Knights)
Team Role: Communications
Rick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to behold
This is a really cool design, i have seen this on electric wheelchairs because it provides great maneuverability in tight spaces. plus those big tires look awesome!
The knack of flying is learning how to throw yourself at the ground and miss.
--Hitchhikers Guide to the Galaxy
2006 Archimedes Divisional Champions
2006 Championship Winner
Unread 25-02-2007, 17:30
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
4-5" is not high enough. The external face of the robot must be no more than 10* off vertical from the floor to 8.5" above the floor, per rule R05
2001-2004: Team 100
2006-Present: Team 254
Unread 25-02-2007, 17:48
Zuhaib Ali's Avatar
Zuhaib Ali Zuhaib Ali is offline
AKA: Zboy
FRC #0188 (Blizzard)
Team Role: Tactician
Zuhaib Ali has a brilliant futureZuhaib Ali has a brilliant futureZuhaib Ali has a brilliant futureZuhaib Ali has a brilliant futureZuhaib Ali has a brilliant futureZuhaib Ali has a brilliant futureZuhaib Ali has a brilliant futureZuhaib Ali has a brilliant futureZuhaib Ali has a brilliant futureZuhaib Ali has a brilliant futureZuhaib Ali has a brilliant future
Send a message via MSN to Zuhaib Ali
Wow! Is that a bicycle Drive?
Unread 25-02-2007, 17:52
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
It doesn't violate the wedge rules.
<R05> "Wedge” ROBOTS are not allowed. ROBOTS must be designed so that interaction with opposing ROBOTS results in pushing rather than tipping or lifting. Neither offensive nor defensive wedges are allowed. All parts of a ROBOT between 0 and 8.5 inches from the ground (the top of the BUMPER ZONE) that are used to push against or interact with an opposing ROBOT must be within 10 degrees of vertical. Devices deployed outside the ROBOT footprint should be designed to avoid wedging. If a mechanism or an appendage (e.g. a harvester for retrieving GAME PIECES)becomes a wedge that interferes with other ROBOTS, penalties, disabling, or disqualification can occur depending on the severity of the infraction.
Becuase they have the flattened section that would contact other robots before the wedged section (therefor preventing the wedge from contacting other robots), there is no rule violation.
Unread 25-02-2007, 18:23
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Wow... what looks to be another great robot from an Iowa team... again.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 27-02-2007, 20:11
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
Those bumpers look awesome along with the robot.... Good luck at your regional!
pic: Team 469's Robot for 2006 pic 2 Don Wright Robot Showcase 10 26-02-2006 21:03
pic: Team 1595 Final Robot Rookie TEAM L@@K!!!! sgsdragons Robot Showcase 4 01-03-2005 16:21
pic: Team 237 Robot and Team Scott Shaw 237 Robot Showcase 3 23-02-2005 19:54
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
quick way to see 967's animation Brian Yip 3D Animation and Competition 2 27-04-2003 04:39
