Go to Post For me, this is the most powerful message of FIRST, that people can come together and work together to achieve so much, and leave old rivalries, grudges, and hard feelings behind. When people talk about culture change, this is what I hope for. - Aren Siekmeier [more]
Unread 25-02-2007, 17:39
adamdb adamdb is offline
adamdb has a spectacular aura aboutadamdb has a spectacular aura aboutadamdb has a spectacular aura about
Gyro PID User drive - How we did it
Thought I would share how we are using the Gyro and a PID routine to help drive our robot.
#include <stdio.h>
#include "ifi_aliases.h"
#include "ifi_default.h"
#include "ifi_utilities.h"
#include "rv_setup.h"
#include "timer.h"
#include "gyro.h"
#include "serial_ports.h"
extern int init_gyro( void );
extern void print_gyro( void );
static int left_out=127 , right_out=127;
static int counter = 0;
static char state = 0;
static int i = 0;
static int x_joy_adjust = 0;
static int y_joy_adjust = 0;
static int last_speed = 127;
int abs( int arg )
	if (arg >= 0)
		return (arg);
	else
		return(arg * -1);
int adjust_speed( int desired, int current )
	int diff;
	diff = desired - current;
	if ( abs(diff) <= 10 )
		if ( diff < 0 )
			diff = -1;
		else if ( diff > 0 )
			diff = 1;
	else
		diff /= 10;
	return(diff);
	PID_adjust()
	Adjusts motor outputs based on a slightly non-typical
	PID calculation.
	Full equation is:
	adjust = Kp * error - Kd * error + Ki * error
	For complete explanation of this PID routine see the
	excellent technical paper on Motion Control by
	Larry Barello at:
	http://www.barello.net/Papers/Motion_Control/index.htm
void PID_adjust( int heading, int speed )
	int current_heading;
	int temp_gyro_angle;
	float p_error = 0.0;
	float i_error = 0.0;
	float d_error = 0.0;
	static float prev_error = 0.0;
	int output;
	const float Kp = 0.05;
	const float Kd = 0.05;
	const float Ki = 0;
	// First copy the forward/back speed to BOTH outputs
	last_speed += adjust_speed( speed, last_speed );
	left_out = right_out = last_speed;
	// Get the current gyro angle
	temp_gyro_angle = Get_Gyro_Angle();
	p_error = (heading - temp_gyro_angle);
	d_error = p_error - prev_error;
//	i_error += p_error;
	output = ( Kp * p_error - Kd * d_error + Ki * i_error );
	prev_error = p_error;
	left_out -= output;
	right_out += output;
	// Make sure the output values don't exceed the limits
	if ( left_out < 0 )
		left_out = 0;
	else if ( left_out > 255 )
		left_out = 255;
	if ( right_out < 0 )
		right_out = 0;
	else if ( right_out > 255 )
		right_out = 255;
	printf( "left: %d  rght: %d\r\n", left_out, right_out );
	txdata.user_byte3 = left_out;
	txdata.user_byte4 = right_out;
	// Invert the right output and put them to the wheels
	OUT_PWM_LM = left_out;
	OUT_PWM_RM = 255 - right_out;
	new_drive()
	New scheme using gyro for heading stability.
	Y joystick controls speed of fore and aft
	movement
	X joystick controls the desired heading.
	Proportional part of PID loop adjusts x & y portion of
	motor output to adjust motors to turn to the desired
	heading.
void new_drive( void )
	int y_axis, x_axis;
	static int desired_heading = 0;
	y_axis = IN_PWM_Y;
	y_axis += y_joy_adjust;		// add in autotrim value
	// Now read the X axis
	x_axis = 255 - IN_PWM_X;
	x_axis -= 127;				// convert to range of -127 to +127
	x_axis -= x_joy_adjust;		// add in autotrim value
	desired_heading += x_axis / 5;
	// Limit it to reasonable values
	if ( desired_heading <= -3600 || desired_heading >= 3600 )
		Reset_Gyro_Angle();
	printf( "y: %d  x: %d   h: %d  ", y_axis, x_axis, desired_heading );
	PID_adjust( desired_heading, y_axis );
	This routine reads whatever the current "center" point
	of the X and Y axis on the joystick is and uses that as
	the center from now on.
void auto_trim( void )
	x_joy_adjust = IN_PWM_X;
	x_joy_adjust = 127 - x_joy_adjust;
	y_joy_adjust = IN_PWM_Y;
	y_joy_adjust = 127 - y_joy_adjust;
void normal_drive( void )
	static int state = 0;
	switch (state)
		case 0:		// initialize gyro
			auto_trim();
			if ( init_gyro() )
				state++;
			break;
		case 1:
			new_drive();
			break;
Some significant points:
We are using a single joystick to drive our robot. The Y axis controls the forward or reverse speed. The X axis sets the "desired" heading. The gyro and PID routines are used to turn the robot from the "current" heading to the "desired" heading.
Some significant routines:
normal_drive() - this is the entry point and would be called from user_routines.c
auto_trim() - this function reads the current values of the joysticks, subtracts them from 127 and uses this as the "center" value. It is called once when the user drive code starts. So no matter where the trims are when the robot starts, the motors start at "off". We were constantly fiddling with the trims to get the robot to not move when turned on. This adjustment eliminates this issue.
adjust_speed()
- this function takes the "desired" speed and the last_speed output to the motors and "ramps" the speed up and down rather than allowing instant changes. This helps to save the transmission from sudden direction changes.
new_drive() - this routine reads the X and Y axis from the joystick and sets the forward/backward speed based on the Y axis and modifies the "desired" heading based on the X axis reading.
PID_adjust() - this is where the magic happens. We are using a slightly non-standard PID calculation from Larry Barello (link in the code comments above). We are actually only using the P & D elements as this was sufficient for us. The additions for the I element are in the code, but commented out. This routine calculates the error between the "desired" heading and the current heading read from the gyro and calculates the value to be sent out to the motors.
Note This routine has not been optimized for size or speed. We do use floating point variables and calculations, but once you determine the constants to use for the Kx constants it would be fairly easy to modify to use integer variables and calculations.
I hope this of interest and welcome any feedback.
Adam Bryant
Programming Mentor
Team 1583
Ridge View Academy Rambotics
Unread 25-02-2007, 17:58
Re: Gyro PID User drive - How we did it
The algorithm and implementation look great. There's a bit of confusion in the comments, where it misrepresents the equation as being based only on the error and not on the derivative or integral, but the code does what I'd expect from a full PID controller. (Or it would, if you hadn't commented out the line doing the I accumulation. You should probably say something explicit about having removed it, in order not to confuse anyone.)
One other thing is completely unrelated to what the code is doing, and likely won't cause problems, but still ought to be corrected as soon as possible. You're treating 255 as the highest possible pwm value. In the IFI system, the maximum should instead be 254. Where you "invert" the right side output value, you similarly need to subtract from 254 instead of 255 -- that way, the 127 "neutral" value remains as it is.
Unread 25-02-2007, 21:24
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Looks great!
Hey Alan, is 254 really the max in the IFI setup? I always thought 255 was the max... I think I incorrectly corrected a few people if that is the case.
Unread 25-02-2007, 22:09
DonRotolo's Avatar
Back to humble
FRC #0832
I would be interested in a photo or description of your drive setup, so I can make better sense of the code.
Nontheless, I very much like your implementation - looks nice and clean, and hope to one day be able to make use of it as a teaching tool. Once I really understand it, that is...
Don
Unread 25-02-2007, 22:30
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Originally Posted by tdlrali View Post
Looks great!
255 can do some wierd stuff. Way back in 2003, I couldn't figure out why our robot wouldn't drive straight. Another team pointed out that 255 was some sort of null character. I changed it to 254, and the thing started driving perfectly.
Last year we found that our robot could massively out-spin the maximum rotation rate supported by the gyro. What do you do once the gyro reading goes 'beyond' the maximum/minimum of the chip?
Unread 25-02-2007, 23:04
Render Render is offline
AKA: Robert Udicious
FRC #1885 (Robocats)
Render will become famous soon enoughRender will become famous soon enough
one way you could improve your code is remove the floats since they are very expensive to the processor and replace them with a numerator and denominator. Then when doing your math you do everything for that portion and divide last.
ex.
char Kp = 5;
char kpDiv = 100;
pTerm = (Kp * p_error) / KpDiv;
You will lose the precision of having a floating point value in the end, but with PWM values I do not think that matters anyways
also I am wondering why your errors are floats?
Unread 25-02-2007, 23:28
Alan,
I did sort of say we weren't using the I component by saying we were using P&D, but should have been a little more clear. I took a pass through the comments, but as usual missed a few that no longer matched up with the code. Odd that you have had issues with 255, we have always used it without issues.
Don,
The drive setup is a typical setup with one motor on each side (facing opposite directions) that power the drive wheels on that side. As the motors face opposite directions we need to do the inversion for (in our case) the right side as shown in the bottom of the PID_adjust() routine.
I definitely urge you to play with the gyro and this code and the other available examples for driving the robot. We hadn't used a gyro in previous years because I didn't understand them or PID routines, but dug into it this year and did some reading and the result has been great.
Render,
As I mentioned in the original post the code was not optimized for size or speed and we will get rid of the floats in future revisions. The errors were made floats so it didn't have to add code to convert from an integer to floating point before it made the calculations.
Thanks all for the feedback!
Adam
Unread 26-02-2007, 09:03
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
your method is very neat indeed, but I still like my little PID engine better
output = pid_control(&part, error);
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 26-02-2007, 09:27
We did something cool with our PID stuff this year. We wanted to get an OOP type feel, but we're forced to use the next best thing, structures and private functions.
It pretty much consisted of making a PID structure which contained everything we needed to know about the system (gains, integral bounds, etc.). We would make a new instance of that structure, and pass a pointer of that struct into different functions to set the gains and compute the output values. I believe this is what Uberbots did.
Unread 26-02-2007, 10:19
Uberbots, Tom,
We only needed the PID for our drive system so we didn't go to the effort of making it generic and passing in all the relevant parameters (which is a VERY slick way to do it). I would love to see the code you used so we can learn from it. Have you posted it in another thread somewhere?
Thanks
Adam Bryant
Programming Mentor
Team 1583
Unread 26-02-2007, 10:22
Originally Posted by adamdb View Post
Uberbots, Tom,
Thanks
Nope, but I'll put it up later today. Off to class!
Unread 26-02-2007, 11:14
The proper maximum pwm output is indeed 254. Here is one bit of documentation to that effect:
Originally Posted by IFI Tech Support
In the Robot Controller program, a value of 0 corresponds to a 1ms pulse. A 1.5ms pulse means neutral, or a value of 127, while a 254 corresponds to a 2ms pulse.
See also this post on the IFI Technical Support forum, which shows the range 231-254 as "Full Forward" on a Victor.
The communication protocol between OI and RC uses a pair of 255 (0xFF) characters to synchronize frames of data. Back in the pre-C days, it might have been possible to confuse it by setting adjacent pwm values to 255. My experience is with the 2004 and later control system, which refuses to report a pwm value greater than 254. I don't know whether the limit is enforced on the actual pwm output or if it's just the dashboard data coming back from the RC that won't go that high.
Unread 26-02-2007, 15:29
Tom,
I saw your post of your PID code, thanks! Reviewing this with my programming students will be a great learning exercise as we haven't covered structures yet.
Alan,
Thanks for the info on the max value of 254. Looks like we need to go through our code and make some changes.
Adam Bryant
Programming Mentor
Team 1583
Unread 26-02-2007, 15:33
Tom,
That was Billy's from 1124. Either way, its a pretty good way to get into structures. It covers typedefs, local declarations, and pointers.
Unread 26-02-2007, 17:00
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Team 228 purchased an additional 300 degree/second gyro for use with PID control with our drivetrain, as this proved much more adequate for drive-train use than the Kit of Parts gyro. So we used the stock KoP gyro for PID control on our arm instead.
Art Dutra IV
世上无难事,只怕有心人.
PID cmd_drive can't drive straight? gnormhurst Programming 4 18-02-2005 01:54
Drive Straight C Code using Encoders without PID? Chris_Elston Programming 17 15-02-2005 23:41
How many drive motors did you use (per side) this year? Billfred Motors 19 16-10-2004 20:27
How did YOU drive your team nuts these six weeks? archiver 2001 10 24-06-2002 01:13
How did YOU drive your team nuts these past 6 weeks? Jessica Boucher Chit-Chat 35 16-03-2002 01:04
