Go to Post When mentors and students battle it's the team that loses. - Koko Ed [more]
Unread 12-02-2007, 18:25
bjimster1's Avatar
bjimster1 bjimster1 is offline
AKA: Jimmy Bourne
FRC #1029 (Wolvcats)
bjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nice
Send a message via AIM to bjimster1
Problems with Encoder Counting
We have a 56mm banebots encoder and it count the revolutions fine.But sometimes it misreads the direction.Its not mounted on a drive motor so it won't spin too fast.Any ideas or suggestions?the problem seems to be at its worst at low speeds
-2006 UCF Quarterfinalists w/ 1345 & 21
-2005 Peachtree Quarterfinalists w/ 1180 & 462
-2005 UCF Quarterfinalists w/ 1694 & 348
CMU '11
Unread 12-02-2007, 18:48
Jared Russell's Avatar
Taking a year (mostly) off
Re: Problems with Encoder Counting
Did you calibrate the encoder?
Unread 12-02-2007, 20:17
bjimster1's Avatar
AKA: Jimmy Bourne
how do we go about doing that?
CMU '11
Unread 12-02-2007, 20:24
Keo-san's Avatar
Keo-san Keo-san is offline
AKA: Victor Marmol
FRC #1029 (WolvCats)
Team Role: Driver
Keo-san is an unknown quantity at this point
How would you go about calibrating the encoder??
Team 1029
www.wolvcatrobotics.com
CMU '11
Michael DiRamio Michael DiRamio is offline
FRC #1114 (Simbotics)
Michael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond repute
The direction is determined by the B signal. If your wire is loose/not plugged in it would only count in one direction... try making sure the wire connections are good and plugged all the way into the RC.
Unread 12-02-2007, 20:30
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
If you could get your hands on an oscilloscope you'd be able to rule out the encoder.
http://www.mikesorrenti.com/
Unread 12-02-2007, 20:53
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Calibration instructions are in this document:
http://www.banebots.com/docs/EN-G0361-KT-Assembly.pdf
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 12-02-2007, 20:55
oddjob oddjob is offline
oddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to behold
We use the banebot encoders and had concerns with the mounting method and getting knocked out of calibration if the robot gets bumped. So we simply use only the pulsecount and ignore the direction signal. (meaning that you don't have to use the encoder board and can wire either encoder output directly to an FRC interrupt input)
Your code can assume the direction is the way you expected from the pwm setting to the motor. Use the Optical Encoder block in easyc rather than the Optical Quad Encoder block.
 if(pwm<127) encoder_count = -encoder_count;
This isn't quite as accurate as using the direction signal in circumstances where the wheel changes direction between successive passes through your timer loop. But it works well in practice.
Unread 13-02-2007, 16:47
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
It is not a given that your motor is always traveling in the direction commanded by the Victor. The Victor can instantaneously change its output. But unless someone changes the laws of physics the motor cannot. And remember the relationship of Victor output to velocity (of the wheel) is dependent on the torque curve of the motor, friction, traction, mass distrbution over the wheel, dynamic losses in the linkage etc. (thus the beauty of a servo that can determine direction and speed)
Unread 13-02-2007, 16:59
ChrisSanborn's Avatar
ChrisSanborn ChrisSanborn is offline
FRC #2936 (The Robonauts)
ChrisSanborn is a glorious beacon of lightChrisSanborn is a glorious beacon of lightChrisSanborn is a glorious beacon of lightChrisSanborn is a glorious beacon of lightChrisSanborn is a glorious beacon of lightChrisSanborn is a glorious beacon of light
Also be cautious to interrupt only on one side, A or B, do not trigger interrupt on both.
I suggest interrupt on A, and read the state of B, this will be your direction.
Unread 25-02-2007, 18:13
Hydra's Avatar
Hydra Hydra is offline
FRC #0909 (Junkyard Crew)
Hydra is an unknown quantity at this point
So, in the end is it worth it to buy encoders? Or is it better to program a counter?
Unread 25-02-2007, 18:53
Hydra's Avatar
Another question: How sensitive are the encoders to movement? Such as bumping or shaking the robot.
Unread 25-02-2007, 18:55
It depends on how precisely you need to control something. For driving a preprogrammed route, polling and counting a relatively coarse sensor works. For keeping drive motor speeds precisely synchronized on an omnidirectional drivebase, I think encoders and interrupts are more appropriate.
Unread 25-02-2007, 19:11
Hydra's Avatar
I just saw your post. Thank you for the advice and suggestions !
Unread 25-02-2007, 21:39
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
We use these encoders.
Initially, we used the direction portion of it with the Encoder card. The problem with this is that the encoder needs to calibrated VERY WELL. 2 of our wheels we couldnt get the signals at 90 degrees or even 80 degrees because there was not enough play on the mount. We decided just to wire one of the encoders on each wheel directly to the computer and not use the encoder cards. Our program figures out the direction.
Ironically, this procedure wound up frying our encoders (not through fault of the encoders themselves)... A 12V signal was *accidentally* applied to the 5V Digital I/O bus by a *non-electrical* member of the team. This fried the encoders. What's ironic about this, is that had we been using the encoder cards, this would not have broken the encoders.
Anyway, thats my opinion.
Jacob
--Remember, good rep is always nice for a useful post!
Encoder Problems bjimster1 Programming 2 10-02-2007 08:04
Encoder counting randomly off by x4 factor jgeorge Programming 5 02-02-2006 21:17
Encoder Output Problems Mike Electrical 5 25-11-2005 21:43
Problems counting encoder pulses bludstayne Programming 7 02-02-2004 23:07
