Go to Post Friends don't let friends drive mecanum. Enough said... - Botsup [more]
Unread 26-02-2007, 12:25
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Re: Shadow Register Problem
Originally Posted by The Lucas View Post
Do you consider macros more or less readable than what you have?
A macro for that statement off the top of my heads is
#define writeShadow(S,R)   while((S).CANMC.bit.CCR==0){(S).CANMC.all=(R).CANMC.all;};
Then you just say:
writeShadow(ECanaShadow,ECanaRegs)
I haven't tested that, but it should be close. I assume those are the structs that are going to change from statement to statement. Anyway it is a start if you like it.
Yes. This is exactly what Im thinking off. Thank you. It's exponentially much easier to read that than having two structures whose only difference is the name.
The two structures are going to be the same but both structures have multiple registers defined. So my macro is going to have the register defined and then the specific bit of the register.
#define writeShadow(S,R)   ECanaShadow.(S).bit.(R)
Unfortunately, its not working because the compiler is giving me an error that it's expecting a field name.
Unread 26-02-2007, 19:44
The Lucas's Avatar
CaMOElot, it is a silly place
Macros are very literal, so try it without the ().
#define writeShadow(STRCT, BITN)   ECanaShadow.STRCT.bit.BITN
Generally you always use () since you are usually doing math with them and the () keep the order of ops correct. But in this case I think they are messing up the variable name (you might want to print out a macro to test it). Also shouldn’t there be more to your statement than
like
ECanaShadow.STRCT.bit.BITN =
ECanaRegs.STRCT.bit.BITN
Robot Inspector
Shadow of the Colossus - Absolutly Amazing Zero-Bee Chit-Chat 0 07-01-2006 13:35
pic: The Shadow Claw bradleym1559 Robot Showcase 8 27-02-2005 15:10
pic: 1241 Robot - Shadow CD47-Bot Robot Showcase 2 11-04-2004 13:16
Shadow? Jack Chit-Chat 9 03-02-2003 20:28
How to register Jeremy Roberts General Forum 0 02-10-2002 01:09
