Go to Post FIRST is an organization where you leave lasting impressions on people you don't even know. - ATannahill [more]
Unread 26-02-2007, 13:42
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Generic PID control code
I was asked by Adamdb of team #1583 to post a code example of what we did to execute a PID loop. The two files, pid.c and pid.h are attached below.
in order to use a pid loop, you must do a couple of things. first, you create the data structure, for example:
PHP Code:
DT_PID arm
in some initialization code later, you need to initialize the constants
PHP Code:
init_pid(&arm10010101005);
(see the included file for the argument list)
then finally, you can execute the loop by doing this
PHP Code:
pwm03 pid_control(&armerrorValue);
It really isnt that bad, and if you notice a lack of comments/explanation, please make a note of it. Also, this code doesnt go into the theory behind it, it only executes the theory. so if you dont know what a proportional coefficient is, then i suggest that you read this: PID without a PhD
happy control-loop-ing.
Edit: i added the default code plus the PID code for those of you who are having trouble getting started.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Last edited by Uberbots : 26-02-2007 at 22:30. Reason: added default code + pid code
Unread 26-02-2007, 14:06
Re: Generic PID control code
I was going to post mine, but beside for some minor syntax differences, the drivers are identical.
Good work.
PS. It looks like the uberbots' programmers have come a long way since I last talked to you before eliminations at UTC last year.
Unread 26-02-2007, 16:32
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Again, nearly identical PID code. I constructed mine from the PID without a PhD article as well.
http://www.mikesorrenti.com/
Unread 26-02-2007, 16:59
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
I was about to make code from PID without a PhD, but then I saw this. It's always great to see teams post code for others to use.
Real programmers use vim.
Integral Window for PID Control phrontist Programming 2 16-02-2008 17:32
PID Control Chris Bright Programming 9 26-03-2005 19:44
(Experimental) PID Control System jdong Programming 14 18-06-2004 15:55
PID control loop/Encoder question Zee Programming 18 30-01-2004 23:14
PID Control Loops ttedrow Programming 7 05-12-2002 12:03
