Go to Post My brain is borderline mush, I don't have much of a voice, and I don't think I could be much happier. - Billfred [more]
Unread 26-02-2007, 15:21
Mona's Avatar
Mona Mona is offline
Spirit is my middle name
None #1620 (Robolution)
Mona is an unknown quantity at this point
important question
Hey, if anyone knows where the LED that indicates that the robot is functioning is suposed to go and how it should be connected to the main battery, could you please give a shout out over here.
Team 1620 Robolution
Unread 26-02-2007, 15:33
Re: important question
Are you referring to the panel signal device (formerly called the diagnostic signal light)?
Originally Posted by The Manual
<R16> ROBOTS must use the panel signal device provided in the Kit Of Parts. Field personnel will use the panel signal device during the matches for diagnostic purposes. It must be mounted on the ROBOT such that it is easily visible while standing three feet in front of the ROBOT in its’ STARTING CONFIGURATION. Instructions for connecting the panel signal device are provided on the FIRST website at www.usfirst.org/frc/2007/manual The Robot Controller directly powers and controls the panel signal device. The user has no control over the panel signal device and no programming is required.
Specifically, see the Robot Signal Light wiring diagram for how to connect it.
important question Mona Regional Competitions 2 22-02-2007 16:57
[OCCRA]: IMPORTANT QUESTION!!! drunkengamer117 OCCRA 8 15-09-2006 17:57
Important Question - Leadership BARKer Team Organization 20 30-06-2006 01:10
Important Question! anupalsingh Programming 1 21-02-2004 23:22
Important Question!!!! CyberDefender 3D Animation and Competition 5 25-07-2002 23:51
