Go to Post Forum Anonymity = Rampant Exaggeration, if not outright Blatant Lying. - dsm [more]
Unread 25-02-2007, 16:47
bobl bobl is offline
FRC #0058 (The Riot Crew)
bobl will become famous soon enough
pic: Team 58 deploying ramps - www.riotcrew.org for more
Unread 25-02-2007, 16:49
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Re: pic: Team 58 deploying ramps - www.riotcrew.org for more
Those ramps look great. As a ringer robot we look forward to having a team like you paired up with us.
Doug Leppard
Unread 25-02-2007, 17:15
We are also a ringer bot. We can place rings on all levels of the rack. The game should be a lot of fun this year. We're going to the BAE Granite State Regional and then on to the Championships. Hope to see you there.
Unread 25-02-2007, 20:00
Best Available Data
FRC #1778 (Chill Out!)
It looks very nice. Although, chances are the only time you might meet 1902 is in Atlanta, as they stick to more southern regionals than New Hampshire.
I was looking on your website, and saw you're using the FPs alone to drive your robot. What drove that decision, weight? Or do you use the CIMs in other places?
Unread 25-02-2007, 23:14
We have 2 drive systems. The FPs drive our low gear torque drive only. Our other drive system is powered by 4 CIMs and is used for high speed driving.
See you at the BAE Regional.
Unread 26-02-2007, 14:39
Nate Laverdure's Avatar
FRC #2363
We have 2 drive systems...
What are you using to engage/disengage the two different drive systems you are using? Is it a simple two-speed transmission, but with two separate inputs? Could you perhaps provide a picture?
Unread 26-02-2007, 15:57
The secondary drive is actuate by the trigger on the drivers joystick. This fires a pneumatic cylinder and engages the drive motor. As long as the driver keeps his finger on the trigger the "torque drive" will stay in contact with the carpet. When the secondary drive is active the main drive wheeks still operate but at half speed. When the trigger is released the cylinder lifts the drive back off the carpet and the motors disengage.
Unread 27-02-2007, 20:09
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
Very nice.... ramps look very simple and easy to get up... Definitly a bonus when you are in a hurry and don't have much time to work with. Good Luck, and have a good time at your regional.
www.usfirst.org Captain Rich General Forum 9 18-05-2005 13:37
www.usfirst.org in 1996 MattK General Forum 1 18-05-2004 00:43
www.beyondfirst.org Rich Kressly Career 5 02-01-2004 18:08
www.machvee.org iBob Website Design/Showcase 1 02-03-2003 11:22
