Go to Post Why aren't the kids who sit alongside the sidelines and observe as valued? Why are they looked upon as leeches, in it for a trip? - Madison [more]
Unread 26-02-2007, 02:25
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
GPS receiver
I was wondering if anybody had some suggestions for a GPS module I could use that has a feature where I can connect it to a microcontroller. I know I can go buy an OEM GPS. But I would prefer one with a screen on it that is like a standard GPS for people like hikers or hunters.
-John
Unread 26-02-2007, 08:09
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: GPS receiver
Check out sparkfun.com and see if they have what you are looking for.
Unread 26-02-2007, 09:15
Re: GPS receiver
The typical "standard GPS for people like hikers or hunters" has a serial data output. Look up the NMEA 0183 protocol.
Unread 26-02-2007, 10:22
karlcswanson's Avatar
karlcswanson karlcswanson is offline
karlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nice
Re: GPS receiver
I was able to get a used gps for $1 at a garage sale. If it is just regular GPS, you will need to convert the rs232 level serial signals to ttl level. You can use a max232 for this. If you are getting a regular gps and plan to use it with a micro controller, make sure it supports the NMEA protocol.
Unread 26-02-2007, 17:12
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: GPS receiver
Well, for the "standard" GPS I speak of is anything like a magellen, or etrex with a screen, something made for the general public, not made for microcontrollers. Is the output a constant output or is it only stuff that you can record then load to a computer.
Before I posted I was looking at this one from sparkfun,
http://www.sparkfun.com/commerce/pro...roducts_id=465
Can somebody help explain some aspects of the NMEA protocol to me? I was looking in this:
http://www.sparkfun.com/datasheets/G...%20Manual1.pdf
And a few other documents that are similar, it seems as though I just need the GGA protocol. But for some parts in it I don't understand the output. I don't understnad the output of the lat and long values.
Also what values from that string what would I need to to simply tell what the position is?
-John
Unread 26-02-2007, 17:44
Team 2021 Captain
AKA: Chris Davidson
Re: GPS receiver
-John
Here is some background info on NMEA. http://en.wikipedia.org/wiki/NMEA
I would say your could either use a commercial GPS with a screen, etc OR something meant for the hobby hardware guy. You probably want the latter as it would allow you to do exactly what you cant instead of trying to mess with reverse engineering a commercial product (like how there screen works) and it will save you from paying for something that has more features than you need.
Unread 26-02-2007, 17:49
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
Re: GPS receiver
-John
Biggest issue (if you want to use it indoors) is going to be signal strength.
http://ssd.itt.com/angel/
Something fun I get to work on that involves (basically) Gyros, DAA's, GPS, FLIR... no Sonar, but LIDAR is better
http://purduephotog.deviantart.com
Portrait Photography: "I used to say Immortalized in Silver, but now I say Captured and Squeezed by Electrons".
Unread 26-02-2007, 22:15
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Re: GPS receiver
-John
I'm been working on interface code for a SiRF III-based ET301 GPS module from Spark Fun Electronics.
-Kevin
Kevin Watson
http://kevin.org
Unread 26-02-2007, 22:28
haroony341's Avatar
haroony341 haroony341 is offline
FRC #0341 (Wissahickon HS & NMTCC) FRC#2234 (The Episcopal Academy)
haroony341 is an unknown quantity at this point
Send a message via AIM to haroony341
Re: GPS receiver
i find this GPS stuff really interesting. but im confused. what exactly does the chip do? what does it connect to? dont you need a satellite or something as a reference point? and how would you read the data? sorry for the questions, im just confused on a lot of its workings.
Drexel University Class of 2009 -- Computer Engineering
Team 341 Miss Daisy // Wissahickon High School @ NMTCC
http://www.team341.com
Team 2234 // The Episcopal Academy http://www.ea1785.org/robotics
Unread 26-02-2007, 22:39
Compnerd's Avatar
Compnerd Compnerd is offline
Self-Proclaimed Nerd
AKA: James H
FRC #1444 (Lightning Lancers)
Team Role: Webmaster
Compnerd has a spectacular aura aboutCompnerd has a spectacular aura about
Re: GPS receiver
GPS connects to at least 3 satelites, using trig. to triangulate your position. The more satelites you have, the more accurate the position. It shows your position on a map, and the Coordinates
James H. - Webmaster - Team 1444
http://www.first1444.com
If you need any website help send me a PM
Unread 26-02-2007, 22:55
Re: GPS receiver
The devices mentioned here are GPS receivers and decoders. They listen to signals from the orbiting GPS satellites and measure time delays to figure out how far from each satellite they are. With enough satellite signals being received, that lets them compute exactly where they are in latitude, longitude, and altitude.
The NMEA 0183 protocol is a serial data stream, containing lots of information, including position and time.
If you want to know more about how it all works, let Google be your guide.
Unread 27-02-2007, 00:28
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: GPS receiver
Well why would it have more features then I want if I am saying I want that one? I don't understnad what there would to be reverse engineer. From what I seen I would hvae to make a cable to plug into it then the rest is code.
Kevin, is the interface software difficult to write? I know it is a vague question, but what is the process your usingi n your code?
-John
Unread 27-02-2007, 08:34
Team 2021 Captain
AKA: Chris Davidson
Re: GPS receiver
Kevin, is the interface software difficult to write? I know it is a vague question, but what is the process your using your code?
-John
I meant that if you wanted to say, use the screen on a Garmin for something even just slightly different than what it was originally designed you cant do that. For example, bigger text, new features being displayed, etc. Without you giving more details its hard to know what exactly you are looking for.
Unread 27-02-2007, 21:26
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: GPS receiver
I said I am looking for a standard OTS GPS unit made for the general public that I can get live data from. I never said anything about using the screen for anything.
-John
Unread 28-02-2007, 00:14
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: GPS receiver
Not sure how closely it fits what you're looking for, but all recent Motorola iDEN phones (Nextel & BoostMobile) have GPS units built in. You can turn on NMEA 0183 output from these and access it over either serial or USB depending on which data cable you get. You might be able to find someone with an older i730 or something that they'd give you, or else you can find the Boost i415 for about $30 at places like Target & Wal-Mart. $10 will probably get you the data cable from eBay.
{edit} You don't need to have it activated to use the GPS, and the Boost i415 is a pre-paid so it can be bought w/o contract. {/edit}
IR Receiver zachriggle Electrical 7 09-02-2006 17:11
Car GPS Systems KTorak Chit-Chat 10 17-11-2005 04:12
Infrared sensor...receiver emayank Electrical 3 25-02-2005 19:54
InfraRed = gps ? nzj1 General Forum 17 11-01-2004 16:58
GPS Robot K. Skontrianos General Forum 3 11-05-2002 00:32
