Go to Post Gracious Professionalism is being embarrassed at an event by an underperforming catstrophe of a robot, yet standing and applauding for every award because you realize that as hard as you worked that season, the other team must have worked even harder to get their achievements. - Taylor [more]
Unread 26-02-2007, 16:10
TennBikeBerk TennBikeBerk is offline
FRC #1717
TennBikeBerk will become famous soon enough
Pre-Made Anderson Battery Cables
My team bought some of the new batteries that are approved for use this year (2007), and we need to attach some of the Anderson quick-connectors that come with 6 AWG wire, as supplied in the KOP. We are also getting an additional charger, so we will need the same Anderson quick-connector, but with smaller wire.
From what I have read so far, it seems that teams need to spec out the connectors themselves, order their own wires, and assemble them themselves. There is also some hardware required to get the ends of the wires securely attached to the battery terminals.
Is this really the case? Doesn't IFI or some other F.I.R.S.T associated distributor have these cables already pre-made? Or, does anybody have all of the parts spec'd out?
Thanks!
Unread 26-02-2007, 16:39
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Re: Pre-Made Anderson Battery Cables
Originally Posted by TennBikeBerk View Post
My team bought some of the new batteries that are approved for use this year (2007), and we need to attach some of the Anderson quick-connectors that come with 6 AWG wire, as supplied in the KOP. ...
From what I have read so far, it seems that teams need to spec out the connectors themselves, order their own wires, and assemble them themselves. ...
As far as we know, if teams want to have additional battery cables, there isn't a source for the complete cable assembly as was in the kit. Rather, teams do indeed need to purchase their own Anderson Connectors, cable, and terminal lugs.
For the red Anderson SB50 Connectors, we've had good success with "Helmar Parts," who sells these connectors for about half the price of any of the typical robotics suppliers: http://www.helmarparts.com/product_p/6331g1.htm
Who would have thought that lift trucks would use these connectors?
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 26-02-2007, 17:50
Duke_of_Hazard's Avatar
Duke_of_Hazard Duke_of_Hazard is offline
FD3S>Z28>All
FRC #0233 (The Pink Team)
Team Role: Driver
Duke_of_Hazard has a spectacular aura aboutDuke_of_Hazard has a spectacular aura about
there is a little reason for this = most teams put their battery in a different orientation to the "plug-in" point, with the positive and negative wires being of different length, so a standard battery wire assembly is usually not feasible.
"I drift not because it is a quicker way around a corner, but it is the most exciting way" - Keiichi Tsuchiya
"...and remember, don't be an Initial D-ouche, Drift Responsibly" - Me, after showing a few members Initial D
The next statement I make is true. The last statement I made was false.
Pink Team Awards (Click it, you know you want to)
Base Driver 2k7!
Attending : Krunch Off-Season?
Unread 26-02-2007, 18:40
DonRotolo's Avatar
Back to humble
FRC #0832
I think he means "where can I get the same thing as in the KOP", not looking for a standardized version.
Don
Unread 26-02-2007, 18:51
yodameister yodameister is offline
The Mad Chemist
FRC #2791
yodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant future
We ordered the anderson connectors themselves from Allied electronics. They ran about $3.50 each or so. And then you get in the mail (got it today) a shiny new Allied catalog.
Unread 26-02-2007, 21:02
FRC #1717
How are you guys attaching your 6 AWG wires to the MK battery terminals?
Unread 27-02-2007, 10:57
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
We use some copper screw connectors picked up for the local Home Depot. Typical connectors used to add heavy wire to power panels.
Unread 27-02-2007, 11:04
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
We get the red Anderson connectors from our local Grainger warehouse.
www.grainger.com
To ensure a secure connection, we crimp and solder; because the lugs & wire are so large, we often have a mentor do this with a torch.
To connect to the battery, you want something similar to:
http://www.foxelectricsupply.com/con...ctNo=BTC020 8
They sell similar connectors at Home Depot.
Unread 27-02-2007, 16:34
The 50 amp Anderson connectors are available through Terminal Supply as are a variety of connectors for the battery terminals. As pointed out, the copper screw down style is available at most home centers, be sure to get the ones sized for #6 wire. As a reminder for all teams, when attaching this style connector to the battery terminals, they should be positioned on the battery so that the clamp is turned to the inside of the battery to prevent damage. You may also bend the tab of the connector at right angles to help use the case of the battery as protection for the terminal and wire. After all is said and done, insulate the entire connection with tape or heat shrink. This style of terminal can be soldered using a large tipped iron. Be sure to feed solder from the end of the wire as it protudes from the terminal and don't add so much that it is visible under the wire insulation. This will harden the wire and make it more prone to breakage inside the insulation.
Unread 27-02-2007, 18:01
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
Oh god how I hate those things.
There may be some sort of benefit to using the screw down type of connector, but I personally prefer crimp connectors. They stick straight out, which is nice most of the time, the wires aren't horribly bent inside of them, and they tend to look nicer. The screw-down types tend to only hold by half of the strands (the other half stays to the side of the screw, and tends to cause problems.) In addition, your freshman electrical guys are a lot less likely to have strands of copper sticking out of the side of a crimp, and it's a lot easier to heat shrink over a crimp. It's also fairly easy to solder a crimp for extra strength.
Maybe we've just never done the screw terminals properly.
Real programmers use vim.
Unread 27-02-2007, 18:10
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
I think they come premade in the kit because do not have the resources to crimp their own cables.
I don't know if this is the case for sure, it is just an assumption.
Unread 28-02-2007, 10:25
AKA: Bud
That's not possible with the ones shown in my post. The screw doesn't make direct contact with the wire strands but is forcing a plate down against the back part of the connector. Wire strands cannot get around or to the side of the plate.
These connectors are bulky, but in my experience it takes a lot less expertise to screw down the connection properly than it does to crimp and/or solder correctly. We've had crimps fail due to not being done properly and we've had way too many cold solder joints on large cables. In addition, soldering results in a stiff to flexible boundary condition in the cable. Flexing at this joint can result in the strands breaking.
Unread 07-03-2007, 18:10
Yep, we've never done them correctly. Turns out I've been sticking the wire in on the wrong side of the clamp. Man, do I feel dumb now.
Unread 07-03-2007, 18:34
Meat,
(sorry, but I wish I knew your name)
It is good to learn. We should all work to learn one new thing each day. This is yours, for today.
Unread 04-04-2007, 15:52
copperhead47's Avatar
copperhead47 copperhead47 is offline
AKA: Grant "gunner" T.
FRC #1647 (Lenape Regional Iron Devils)
Team Role: Electrical
copperhead47 is an unknown quantity at this point
Send a message via AIM to copperhead47
hey can someone post the URL for Terminal supply company becasue for some reason i've had trouble finding them. And I myself am in need of Anderson Contacts. thanks guys and girls!
Main Battery Cables maclaren Electrical 14 26-07-2006 12:37
Anderson Connectors!!!! cdennisxlx2 Electrical 9 06-03-2006 19:20
Shipping w/ Anderson Connectors Sscamatt General Forum 2 20-02-2005 23:59
pre-made wheels Vivelation General Forum 13 20-01-2005 17:15
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
