Go to Post All battery terminals must be wrapped in tape or other insulating material AT ALL TIMES! - Al Skierkiewicz [more]
Unread 26-02-2007, 19:44
The Lucas's Avatar
CaMOElot, it is a silly place
Re: Shadow Register Problem
Originally Posted by Adam Y. View Post
Yes. This is exactly what Im thinking off. Thank you. It's exponentially much easier to read that than having two structures whose only difference is the name.
The two structures are going to be the same but both structures have multiple registers defined. So my macro is going to have the register defined and then the specific bit of the register.
#define writeShadow(S,R)   ECanaShadow.(S).bit.(R)
Unfortunately, its not working because the compiler is giving me an error that it's expecting a field name.
Macros are very literal, so try it without the ().
#define writeShadow(STRCT, BITN)   ECanaShadow.STRCT.bit.BITN
Generally you always use () since you are usually doing math with them and the () keep the order of ops correct. But in this case I think they are messing up the variable name (you might want to print out a macro to test it). Also shouldn’t there be more to your statement than
like
ECanaShadow.STRCT.bit.BITN =
ECanaRegs.STRCT.bit.BITN
Robot Inspector
Shadow of the Colossus - Absolutly Amazing Zero-Bee Chit-Chat 0 07-01-2006 13:35
pic: The Shadow Claw bradleym1559 Robot Showcase 8 27-02-2005 15:10
pic: 1241 Robot - Shadow CD47-Bot Robot Showcase 2 11-04-2004 13:16
Shadow? Jack Chit-Chat 9 03-02-2003 20:28
How to register Jeremy Roberts General Forum 0 02-10-2002 01:09
