Go to Post Most people who say "winning doesn't matter" have not won enough to have a balanced opinion on the issue. - T^2 [more]
Unread 26-02-2007, 19:52
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Re: Gyro PID User drive - How we did it
Originally Posted by Bongle View Post
255 can do some wierd stuff. Way back in 2003, I couldn't figure out why our robot wouldn't drive straight. Another team pointed out that 255 was some sort of null character. I changed it to 254, and the thing started driving perfectly.
I believe the limit today is actually 255. "Back in the day", when the user microprocessor was a BASIC stamp, instead of a PIC, it used the serial i/o from the stamp to communicate with the master processor. Each packet had a 0xFF 0xFF header (i.e. 255, 255). The PWM out values were interlaced with the relays and the digital outs, and we were told not to run PWMs above 254. If a PWM was run at 255, then being next to some other byte, which could be 255, it could look like a packet header, and throw things off. Now, however, with the use of a PIC instead of the BASIC stamp, the problem of getting this false header no longer exists, so it's safe to run PWM outs at 255. (Tangentially, I think the user and master processors now communicate via shared memory, but I'm not certain of the details.)
The difference in output between 255 and 254 is not going to be noticeable, and Victors have a small center deadband, so both 127 and 128 are going to give you a "full off" from the Victor, so it really doesn't matter which way you do it. Just don't try to use 256 as your "full on" value.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 26-02-2007, 20:09
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
Keep in mind that 2003 was a radically different RC than today's C-based controllers. The radio protocols changed as well in 2004, and so 255 doesn't have the stigma it used to. You may not see any difference between 255 and 254 in actual PWM output, but the only thing weird about 255 now is that 255+1 = 0.
Real programmers use vim.
Unread 26-02-2007, 20:16
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
The radio protocol really didn't change. There were minor changes but the protocol still uses (255, 255) as a synch code which is why PWMs aren't allowed to use 255.
PID cmd_drive can't drive straight? gnormhurst Programming 4 18-02-2005 01:54
Drive Straight C Code using Encoders without PID? Chris_Elston Programming 17 15-02-2005 23:41
How many drive motors did you use (per side) this year? Billfred Motors 19 16-10-2004 20:27
How did YOU drive your team nuts these six weeks? archiver 2001 10 24-06-2002 01:13
How did YOU drive your team nuts these past 6 weeks? Jessica Boucher Chit-Chat 35 16-03-2002 01:04
