Go to Post Ahh yes, the good old "let's dedicate all our resources to absolutely cheesing the opponent alliance" strategy - Jaci [more]
Unread 27-02-2007, 10:51
Calvin_1631's Avatar
Calvin_1631 Calvin_1631 is offline
AKA: Calvin
FRC #1631 (Cybernetic Cougars)
Team Role: Electrical
Calvin_1631 is an unknown quantity at this point
Worm Gear
Hello, I am new to gearboxes and everything associated with them. I was wondering if it is possible to take the big 3" CIM motor and make, well essentially, a worm gear to use on a pivot arm, allowing the arm to stay in the position it was rotated to.
Unread 27-02-2007, 11:12
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: Worm Gear
Quite easily, as long as ou have the worm and a worm gear. Bore out the worm to 8 mm and them fasten it somehow to the CIM shaft, either pins through or a key way. If the gear reduction still is not enouph, try a initial gear reduction with spur gears. Hope this helps.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 27-02-2007, 11:42
ShaneP's Avatar
ShaneP ShaneP is offline
Lead Mentor
FRC #0330 (The Beach Bots)
ShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to behold
Re: Worm Gear
Yes, it would work.
This isn't exactly a worm gear on another gear but a somewhat similar application:
Frog Force (Team 503) used this concept on the their robot in 2005 and said they were quite happy with it. It seemed to work really well. Take a look at this picture:
http://www.chiefdelphi.com/forums/sh...&highlight=503
You can see the black worm gear shaft going down to the base of their robot under the arm. The CIM motor was mounted on the arm and is visible towards the top of the mast.
Unread 27-02-2007, 12:49
technoL's Avatar
technoL technoL is offline
AKA: Noelle Manning
FRC #0108 (SigmaC@T)
technoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud of
Send a message via AIM to technoL
Re: Worm Gear
We used a worm gear on our shoulder for this year's robot. Although we used a globe motor instead of a CIM, the gearbox can easily be adapted to fit the shaft. Here's an Inventor rendering of it: http://static.sigmacat108.com/images...nsmission2.jpg
And the actual thing:
http://static.sigmacat108.com/images...mechanical.jpg
-No L
Team Leader | Mechanical | Driver | SOAP | Anything
2008: NJ GM Industrial Design Award, 4th Seed | FL Rockwell Automation Innovation in Control Award, 1st Seed, Semifinalists
2007: FL Finalists | LV Xerox Creativity Award, Quarterfinalists | Mission Mayhem Champs
2006: FL Delphi's Driving Tomorrow's Technology | Curie Quarterfinalists
Unread 27-02-2007, 14:40
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Worm Gear
And remember, the worm wheel induces an axial load on the worm screw and shaft, so, make sure to use bearings that can handle that sort of (axial/thrust) loading on the worm screw shaft.
Unread 27-02-2007, 17:10
Re: Worm Gear
As Sanddrag pointed out, the Chalupa motors cannot handle this kind of load without some help from external bearings. Side loads on these motors require significant (near stall) currents. The same thing can be said for unsupported sprockets and chains.
Unread 27-02-2007, 18:16
AKA: Calvin
Re: Worm Gear
so should I buy a worm gear from McMaster-Carr? We would be using it to turn an arm about 270 degrees and will way maybe 15 pounds. As I said, I'm new to this. Thanks.
Unread 28-02-2007, 01:08
run the trap!!!
Team Role: Human Player
Re: Worm Gear
Originally Posted by Gabe View Post
Quite easily, as long as ou have the worm and a worm gear...
Ha! Or not... Getting the necessary accuracy and tolerances will be very difficult and I would not recommend barreling into this project before doing some serious research.
We made a worm-gear drive this year out of a piece of 1/8" thick boxed aluminum and a bronze spur and stainless worm from Applied Technologies. I would NOT suggest buying from McMaster Carr. McMaster only sells cast iron worms, which will turn to dust after a few matches.
If I were you I would spare myself the grief and buy a contained unit such as these:
-http://www.applied.com/apps/commerce/catalog/catalog.do?e=2&c=1960
-http://www.chiefdelphi.com/forums/showthread.php?p=566568#post566568
-http://bostongear.com/products/enclosed/wgsr.html
If you have the resources to machine a gearbox I'm sure you have the resources to cheese-hole one that’s already made
(You can see the gearbox on the side of the T. REX's arm)
-Philip J. Fry
Unread 28-02-2007, 01:28
Gabe's Avatar
Re: Worm Gear
True, cast iron does wear very fast, so the next best thing is to get bronze worm gears and steel worms, both which you can get at SDP-SI
https://sdp-si.com/eStore/
They have both smaller nylon worm gears (perhaps too small), but larger bronze worm gears which I think would suit your application. If you do order from them, please order as soon as you can because our team has had some trouble with delayed shipping (in our case, gear stock).
Unread 06-03-2007, 10:19
AKA: Calvin
Re: Worm Gear
sorry to bring back a kinda dead topic. But would it be considered legal to buy a worm gear box from Boston Gear.
Unread 06-03-2007, 10:31
BRosser314's Avatar
BRosser314 BRosser314 is offline
Post-A-Holic
AKA: Brandon Rosser
FRC #0469 (Las Guerrillas)
BRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to behold
Send a message via AIM to BRosser314 Send a message via Yahoo to BRosser314
Re: Worm Gear
I dont believe it would be illleagal, I mean check the FIRST part flowchart in the Robot section of the manual. I believe the only probnlem you would have with the one you buy would be for weight and size constraints and also if your team is budgeted on there money.
Unread 06-03-2007, 10:39
Re: Worm Gear
Calvin,
The gearboxes shown are mostly for fractional horsepower motors but if you find one that you could use... They are restricted by the single part cost and must be accounted for in your BOM and max robot cost accounting.
Worm Gears FIRST JerseyKid Technical Discussion 13 18-01-2006 10:13
worm gear emergency ClicheCow Technical Discussion 5 21-02-2005 01:39
Van Door Motor Worm Gear Anthony Motors 5 14-02-2005 07:33
Worm Gear Gearbox dddriveman Technical Discussion 38 07-01-2005 14:43
Van Door Worm Gear Jim Giacchi Motors 4 16-12-2003 09:35
