Go to Post If you want to have other teams cheer for you all day long at competition, name your team "Robot Coming Through". - Gary Dillard [more]
Unread 25-02-2007, 21:12
Re: Team 869's Custom Controller
Rohit,
I know that this will not be a problem during competition since you will be using an IFI radio for the OI but the radios actually have an internal antenna that runs down the left side of the modem in your picture. Mounting this against a metal panel usually has a detrimiental affect on RF. the same goes for the RC side as well.
Unread 27-02-2007, 18:25
rohit's Avatar
rohit rohit is offline
Inventor Person
FRC #0617 (The Springers)
rohit has a spectacular aura aboutrohit has a spectacular aura about
Send a message via AIM to rohit
hmm.. ok. I have no clue what that means but ill show your post to the electrical person
Unread 27-02-2007, 19:06
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
What he means is that you have your OI radio modem mounted to what appears to be a metal plate. This metal plate is in between the OI modem and the robot, and will interfere with the communication. What he's suggesting is that you mount the modem so that it's above the metal or otherwise unattached to it. The silver antenna on the outside of the modem isn't the only one - there's also one inside the black case which is why just having the external antenna above the metal plate isn't good enough.
Unread 27-02-2007, 23:56
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Originally Posted by Rapt0r9 View Post
That is a very nice board. We were thinking of doing something like that this year, but were short on time. The guys who built ours decided that style was better than practicality, so they built it our of 80/20 and covered that with diamond plate. Although this year it should be slightly lighter because we have eliminated two joysticks and replaced them with the box, but our drivers hate carrying it.
That is nothing. I will see if i can post a picture of my team's OI. It is built from ITEM and Lexan and weights from ten to twenty pounds. The drivers only saw ours for a brief period of time and started complaining lol. I just hope they don't drop it when they actually have to pick it up on game day.
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 03-03-2007, 16:15
pyrr101's Avatar
pyrr101 pyrr101 is offline
AKA: Travis
FRC #0537 (Charger Robotics)
Team Role: Electrical
pyrr101 is an unknown quantity at this point
Send a message via AIM to pyrr101 Send a message via MSN to pyrr101 Send a message via Yahoo to pyrr101
Our contols were at one time too large to use on the field corectly, since there was not long enough cable between the zip ties and out competition port on the fields. We ended up haveing to remove 6" off each side to make it work. The box was so large it required a hing to make it easier to carry and wheels since it was 25 lbs. It was made out of item, and lexan with our joysticks top mounted, I will try to get a picture on her soon.
Team 537 Electrical Lead
Waukesha County Sheriff Department, SWAT 'BOT lead
Wisconsin, Buckeye, and Nationals here we come!
Wisconsin Regional:
  • Rockwell Automation Innovation in Control Award
  • Regional Engineering Inspiration Award
  • Regional Winner
pic: Team 617 Controller rohit Extra Discussion 1 21-02-2007 13:08
pic: Team 865 custom 2-speed gearbox geo Technical Discussion 2 20-04-2006 18:13
pic: Team 521 Custom Frame Steve P Extra Discussion 9 01-02-2005 11:19
Using Custom Inputs on the Controller Board schenkin Programming 10 27-01-2005 10:26
Custom Mod Controller. Josh Hambright Electrical 9 17-01-2003 08:05
