Go to Post The real world does not go together like an Erector set. FIRST robots should not either. - dlavery [more]
Unread 28-02-2007, 07:39
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
Re: pic: 379's transmission
Wow... 280 thats intense.... We are pushing around there, but in order to do so we had to do a serious friction increase project. Have you found out if you have any slipping going on or are you alright in that area? Other wise that is a SERIOUS gear system and looks great. We have a shifting mecognism that we think will really impress some people. But all in good time right . Other wise this looks like a great drivetrain that I am pretty sure will work very good. From experience I can say that being able to push 280 means pushing someone sideways wich translates into a HUGE advantage in the game. If you have designed this bot as a great bully bot then you did a great job! If you dident you still did a great job. One more question that I have to ask though is how fast does this drivetrain go? Usually with low gearing and not being able to shift you have high torque and low speed. Is the same true with your bot? Thanks, and I wish you and your team the best of luck at regionals.
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
pic: 2 Speed Transmission AustinSchuh Extra Discussion 20 30-12-2006 16:39
pic: 2 speed transmission 1 psyco_klown Extra Discussion 3 05-09-2006 19:03
pic: 2 speed transmission 2 psyco_klown Extra Discussion 0 22-05-2006 13:35
pic: 379's 2006 Robot Cat 7 Robocat1 Robot Showcase 16 05-03-2006 12:20
pic: 1141 gets under 379's skin CD47-Bot Extra Discussion 2 06-04-2004 09:27
