Go to Post Equally possible is that we're just providing some lunch-break entertainment for the people in the GDC. - wasayanwer97 [more]
Unread 01-03-2007, 00:01
AKA: Dr. Brooks
no team (WRRF)
Re: Team Update 15 - Very important
Originally Posted by Eldarion View Post
As an aside, I wonder why they used two different datapaths on different antennas? Did the old radios do that, or did the two datapaths use the same antenna?
Only the IFI engineers can say for sure, but if you have a transmitter
and a receiver close enough in frequency that the transmitter causes
the receiver interference problems, you can put them on different
antennas and position the antennas to minimize the coupling between
the transmitter and the receiver.
Given that there is an antenna out of sight in the radio modem case
it is very important that the modem be mounted well clear of any metal
structure on the robot. We mount our antenna on a piece of polycarbonate
a good distance away from metal structure on the robot and have not
had any problems with the radio, but we will be first in the line to upgrade
the radio firmware, and install V15 of the master code, at Portland.
Eugene
Unread 01-03-2007, 02:51
Dave K.'s Avatar
Dave K. Dave K. is offline
Engineer/Mentor
FRC #0930
Dave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to behold
T
The eWave design used an RF module made by Uniden for consumer cordless phones. The transmitter and receiver were duplex coupled onto a single antenna.
In both designs, the transmitters are constantly transmitting even when they are not conveying data. One radio transmits around 902MHz, the other around 928MHz.
To find other examples of full duplex operation on a single antenna, look no further than your nearest cordless or cell phone.
The principal is to provide enough isolation between the receiver and transmitter such that the phase noise from the transmitter at the co-located receiver's input doesn't affect the receiver's sensitivity. By isolating the receiver from the transmitter the impedance from one of the tx/rx ports at that ports desired pass frequency will provide a good match to the antenna's impedance and simultaneously provide a high impedance at the opposing tx/rx port. It can be accomplished with a pair of high pass and low pass filters, or could be done with a pass-notch type filter.
The physical seperation between the internal and external antenna provide little in the way of isolation compared to what filters would accomplish, so I suspect that there are still filters present on at least the transmitters, but maybe they felt it was easier than trying to match the the combined port to a single antenna.
IFI clearly had little time to design these radios, so probably took as little design risk as possible, and thus the dual antenna approach.
Clearly they've spent some additional time over these past few weeks working out some software changes, lets hope it resolves the problems some of the teams were experiencing.
--Dave
Unread 01-03-2007, 06:42
Dominicano0519's Avatar
Dominicano0519 Dominicano0519 is offline
My team is not competing this year
AKA: Demolition Man
FRC #0381 (Tornadoes)
Dominicano0519 will become famous soon enough
Send a message via MSN to Dominicano0519 Send a message via Yahoo to Dominicano0519
uggh i cant believe people are still arguing over the ringer over the station wall thing.
in the original rule it said that you may only put it through the chute. then in the update it said you may put it through the chute. Get it? May ONLY changed to MAY
Favorite Phrases:
1. I like your robot, no-homo
2. "It depends how you define alone" ( Bill Clinton when being questioned about Monica Lewinsky)
Unread 01-03-2007, 07:30
Duke_of_Hazard's Avatar
Duke_of_Hazard Duke_of_Hazard is offline
FD3S>Z28>All
FRC #0233 (The Pink Team)
Team Role: Driver
Duke_of_Hazard has a spectacular aura aboutDuke_of_Hazard has a spectacular aura about
When I read this I started humming the russian chant from Hunt for Red October....Cheers!
I'm happy that IFI is not like so many other distributors, those that even in the face of massive complaint, don't do near about anything. I would have hated to see a week of regionals go on where they went in thinking it was only a bug related to a few......only to find everyone was having problems, ruining that week of regionals.
"I drift not because it is a quicker way around a corner, but it is the most exciting way" - Keiichi Tsuchiya
"...and remember, don't be an Initial D-ouche, Drift Responsibly" - Me, after showing a few members Initial D
The next statement I make is true. The last statement I made was false.
Pink Team Awards (Click it, you know you want to)
Base Driver 2k7!
Attending : Krunch Off-Season?
**FIRST EMAIL**/Important Team Update Posted - could affect your build Damian Manda FIRST E-Mail Blast Archive 0 12-01-2007 22:54
New MS Patch.. very important. devicenull IT / Communications 0 05-01-2006 18:19
Very Important Rule Clarification!!! Mr. Mac OCCRA 0 17-10-2002 23:35
