Go to Post Though winning is not the end, that doesn't mean it's not important. - Michael Corsetto [more]
Unread 21-02-2007, 08:38
Slick Slick is offline
Slick is an unknown quantity at this point
Delay Function
Can someone show me a way to write a function that can delay the robot. I would like to write a function and put it in ‘user_routines.c’ and call it anywhere in my ‘user_routines_fast.c’ file. Simply I would like to:
pwm13 = 167;
pwm15 = 167;
delay = 100;
where ‘delay =’ would pause the robot for whatever time you gave it. Your help would be appreciated. What would the function look like? Thanks...
Unread 21-02-2007, 09:15
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: Delay Function
maybe somthing like this..
void delay(unsigned int seconds)
   unsigned int current = 0;
   while (current < (seconds * 1000) / 26.4) // Seconds * 1000 to get milliseconds and then / 26.4 millisecond loop
      getdata(); // forget what parameter getdata takes
      current++;
      putdata(); // forget what parameter putdata takes..
I have no idea if that will work but you can try it..
Unread 21-02-2007, 12:38
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Delay Function
"Stalling" execution is generally a bad idea. I would make a "loopcounter" variable, and increase the counter every time the function runs. After a certain number of loops, make it do the next thing.
For example, here's our pump code:
void pump_routine(void) {
	static unsigned int loops = 0;   <--- Loop Counter
	if(BTN_PUMP_DISABLE) {
		if(DIGIN_PUMP_PRESSURE_SWITCH && loops>10) { <-- If more than ten loops have passed
			RLY_PUMP_ON = 0;
		else if(DIGIN_PUMP_PRESSURE_SWITCH) {
			loops++; <-- Increase loop counter
			RLY_PUMP_ON = 1;
		else {
			loops = 0;
			RLY_PUMP_ON = 1;
	else {
		RLY_PUMP_ON = 0;
		loops = 0;
	RLY_PUMP_NUL = 0;
Unread 28-02-2007, 17:54
Anime-niac_2.9's Avatar
Anime-niac_2.9 Anime-niac_2.9 is offline
Japanese-crap freak(NOTE AVATAR)
AKA: Alex Abenoja, A-Squared, & Anime
FRC #0599 (Robodox)
Anime-niac_2.9 will become famous soon enough
Re: Delay Function
i've thought about it before, and it turns out something like bear24rw's idea.
int counter=0;
void User_Autonomous_Code(void)
  static unsigned int i;
  const float delay = 100;
  int counter, int limit=(delay*1000)*26.4;
  for(counter=0, counter<limit, counter++)
not necessarilly a function, but the interrupt code here (the for loop) should work. all you have to do if place the for loop whereever you want it
THE ROBODOX FORUM
Reading: Suzumiya Haruhi no Yuutsu by Tanigawa Nagaru
Religion: Haruhiism
Unread 01-03-2007, 02:15
Dave K.'s Avatar
Dave K. Dave K. is offline
Engineer/Mentor
FRC #0930
Dave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to behold
Re: Delay Function
pwm13 = 167;
pwm15 = 167;
delay = 100;
... for autonomous no doubt.
Perhaps you will find some insight in this recent thread
I'd suggest structuring your autonomous code to run every 26ms (off the SPI data updates), tuck some timers into that, and structure you code as a state machine.
--Dave
Unread 01-03-2007, 20:17
bear24rw's Avatar
AKA: Max T
FRC #0011 (MORT)
Re: Delay Function
int counter=0;
You need to be carefull with that loop, you need to call putdata and getdata every so often so the master processor doesnt shut down.. i forget what the actual timeout is but its not very long...
Unread 01-03-2007, 22:56
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Re: Delay Function
You do realize that the range for an int is -32,768 to +32,767?
Delay Help! waiakea2024 Programming 7 21-02-2007 12:41
VEX Ultrasonic Sensor delay P1h3r1e3d13 Programming 4 28-03-2006 13:45
NERDS Delay... Andy Grady General Forum 21 14-03-2006 21:52
Delay in autonomous mode SpeakerSilenced Programming 1 22-02-2005 10:58
Delay Gal Longin Programming 1 09-12-2004 10:37
