Go to Post The 3 probably stands for the number of years this season will take off your life - JohnSchneider [more]
Unread 28-02-2007, 20:04
run the trap!!!
Team Role: Human Player
Delayed Robot Reactions
Our team has built a practice bot this year and we are using a 2005 radio.
Sometimes the robot runs just fine, we drive it around... the battery runs down... we replace the battery... and then it starts "lagging"
It is still controllable, but everything is delayed. We ran a whole bunch of tests to diagnose the problem, and then for some mysterious reason it started functioning normally.
The robot also "lags" when tethered.
In my opinion the problem has something to do with changing the battery, since whenever we have done this the problem has returned.
I'm not the programmer, I'll get him to explain more...
-Philip J. Fry
Unread 01-03-2007, 09:19
Re: Delayed Robot Reactions
This sounds like one of the symptoms of the "8.2v bug" reported last year. Did you start with last year's default code? I think there was a change to the linker file that fixed it (or at least masked it).
Unread 01-03-2007, 09:46
Brandon Holley's Avatar
Same exact thing was happening to us...I honestly don't know what we did to fix it, we just kinda played around with stuff until it was running right.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 04-03-2007, 15:14
Stvn's Avatar
Stvn Stvn is offline
FIRST Competition Competer
AKA: Steven Rhodes
FRC #0100 (WHS/CHS - WildHats)
Stvn is an unknown quantity at this point
Send a message via AIM to Stvn
Unhappy Re: Delayed Robot Reactions
Here's some further information on our condition:
When you turn on the robot, it works fine. Over time, the problem gets progressively worse.
On Monday, it worked fine for an hour and a half.
On Tuesday, it worked fine for an hour.
On Wednesday, it worked fine for half an hour.
Today, on Sunday,it only worked fine for two minutes.
v11 firmware was downloaded - no difference.
The OI was switched from 2006 to 2005 - no difference.
Radios were switched from 2004 to 2005 - no difference.
The camera was disabled - no difference.
The terminal window works fine.
Currently, we are trying to switch the 2004 Robot Controller to 2005.
Unread 04-03-2007, 16:12
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Load the version 15 master code in the 05 controller. See if that helps, the master code is the same for 04-07 controllers.
FIRSTcast will be delayed Matt Krass General Forum 8 12-09-2005 12:07
Episode III reactions Shu Song Chit-Chat 1 19-05-2005 22:17
National Competition Reactions & Opinions archiver 1999 13 23-06-2002 22:40
Reactions archiver 1999 1 23-06-2002 22:40
Registration Delayed David Kelly General Forum 35 22-09-2001 23:30
