Go to Post It's not about which is better, it's about which is better for your team. - Karthik [more]
Unread 01-03-2007, 22:13
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: pic: 2007 FRC Team 548 Robostangs Robot Pic2
Buzz (FRC175) built a "kicker wheel" design in 2000, and used the Van Door motor to rotate a smaller, higher traction wheel downward to lift the main driving wheels (8" skyways) off the ground. This was only a 2wd system.
The Bobcats (FRC177) built a similar "kicker wheel" design in 2002, but used the old seat motors with their 2" lead screws to drive the smaller wheel down. This design used a swingarm, made of 1.5" box aluminum, to lower a similar smaller, higher traction wheel downward to lift the main driving wheels (12" custom) off the ground. Again, this was only a 2wd system.
The HOT Bot (FRC67) also used a smaller, higher traction wheel design in 2002. However, their design was more static in nature, in that their robot weight was shifted onto these rear wheels when it grabbed a goal. It looked sort-of like a tractor pull when the front end got lifted a good 6-12 inches off the ground.
Clearly, the use of pneumatics was not as prominent back in the day. Today, it's a bit easier to implement such a system with the pneumatics. Grady, when are you going to give us a FIRST 101 on the origins of 2-speed robots?
BEN
pic: 2007 FRC Robostangs Team 548 Robot robostangs548 Extra Discussion 1 02-03-2007 15:11
pic: 2007 FRC Team 548 Robostangs Robot Pic3 robostangs548 Extra Discussion 4 01-03-2007 21:53
pic: (Real) Robostangs Team 548 FRC 2007 Wheels & Sprockets robostangs548 Extra Discussion 6 03-02-2007 11:46
pic: Team 40 Mini FRC 2007: The Field (sans rack) Jessica Boucher Extra Discussion 2 22-01-2007 16:05
