Go to Post If poker is a sport, robotics is definitely a sport. - EricH [more]
Unread 02-03-2007, 15:56
Nawaid Ladak's Avatar
Nawaid Ladak Nawaid Ladak is offline
The Banana People Are Awsome!
AKA: Nawaid Ladak
FRC #0945 (Team Banana)
Team Role: Tactician
Nawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant future
Send a message via AIM to Nawaid Ladak Send a message via MSN to Nawaid Ladak Send a message via Yahoo to Nawaid Ladak
2007 Red Advantage
I know this was mentioned two years ago in "Triple Play" but i think it's back
just look at the match results
if i am correct, only red alliances have scored in triple digits.
anyone else notice this trend.
(i just saw 116 put up 108)
"When you make a mistake, admit it, correct it, and learn from it - immediately."-Stephen Covey
I can still learn from this quote, how about you?
Nawaid Ladak
2003-2006 FRC # 1402: Freedom Force. Scouting
2007 FRC # 1694: RoboWarriors. Mentor
2008-Present FRC # 945: Team Banana. Mentor
Contact me
E-mail: LadakN (at) GMail (dot) com
Twitter / Facebook / Youtube
Unread 02-03-2007, 16:24
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: 2007 Red Advantage
I will look at the numbers later tonight. So far, I have sort of noticed this trend too.
Unread 02-03-2007, 16:37
Joel J's Avatar
Joel J Joel J is offline
do you..
I don't know about any trends, but those red tubes really do stand out..
Joel Johnson
RAGE (173) Alumni, 1999-2003
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
The Red Advantage thread in 2005 referred to the fact that the Red Alliance was always the higher seeded teams in the elimination rounds. Assuming the qualification rounds are 100% random*, then the average score for both alliances should be the same. But as experience tells us, they are usually not.
Due to this fact, one team may be on a certain side of the field more often than if they were completely random. Because of the way the scores work in the game, the better you are (ringer-scoring wise) the exponentially higher your scores become. Going from 1 to 2 tubes is not nearly as much as an increase as going from 5 to 6 tubes, or from 7 to 8. So it is in these phenomenal tube scoring robots that "outlier" scores happen.
Because these outlier scores can drastically alter the average, and because of the fact that due to the altered randomosity of the match generation that teams may play on one alliance more than the other, these outlier scores will often end up on one alliance more than the other.
Using data from the first 51 matches at the NJ Regional, the average score the the red alliance was just north of 33 points, while the blue alliance lagged at about 14 points. In the data used, there are several outlier scores from the red alliance (260, 98, 128 and 236 pts). If we exclude these from the average, then the average drops to only 20 and change, which is much closer to the blue alliance's average score.
But also to note is the standard deviation of the scores. Because of the outliers in the red alliance, the standard deviation for scores in the red alliance was 51.7195 points, whereas the blue alliance was only 18.676, meaning that red has a much higher spread of data. But if we again exclude the outliers, then the standard deviation of the red alliance drops to 21.087 pts, which is much closer to the blue alliance.**
* The reason matches are not completely random is because of the algorithms used to "randomize" the matches. Although it may seem like random, adding little things like a minimum time span between a single team's consecutive matches alters the randomness of the results. Now the results are no longer 100% random, but rather the sort of "equally-spaced-out-data" random that people generally associate with randomness.
** These results of course only count for the blue alliance and not The Blue Alliance, as that always tops the lists.
Art Dutra IV
世上无难事,只怕有心人.
Unread 02-03-2007, 17:21
amos229's Avatar
amos229 amos229 is offline
Retired chicken man
AKA: amouse
FRC #0229 (Division By Zero)
amos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud of
Send a message via AIM to amos229 Send a message via Yahoo to amos229
At BAE it seemed to not only be blue in the triple digits but it seemed to always be bue winning the matches.
Govenors see innovation like judges see pornograpghy, they dont know exactly what it is but they know it when they see it, Dean Kamen, BAE Regional, 2007
229 alumni= lifetime of inspiration
Unread 04-03-2007, 01:18
LocknLoad's Avatar
LocknLoad LocknLoad is offline
Watch out for 501
AKA: Chris
FRC #0501 (The PowerKnights)
Team Role: Student
LocknLoad is on a distinguished road
Red Alliance won at GSR
Congratulations to team 501, 175, and 1824 for winning the Granite State Regional!
Also to team 190 for receiving the Chairmans award!
Unread 04-03-2007, 01:26
BrianR BrianR is offline
AKA: Brian Roehl
FRC #1525 (Warbots)
Team Role: Electrical
BrianR has a spectacular aura aboutBrianR has a spectacular aura about
Send a message via AIM to BrianR
I went through the qualification matches for data mining, and I noticed a couple of things. Unfortunately, I modified the document, and I didn't preserve the Red vs Blue scores, rather they are now Winner and Loser. In any case, when I did a quick sum of the Red scores vs. the Blue scores over the first four regionals (BAE wasn't posted), I noticed that Red had overall anywhere from slightly more to double as many points as Blue. This sure seems like a red advantage to me. The one regional where it was very clear was at VCU where Red literally demolished Blue.
Also, the other point that I found VERY interesting was that the number of teams that scored over 30 points and lost was very low. In fact, 98.515% of all losing teams had fewer than 30 points. This would seem to indicate that anyone who can score over 30 points (a 12" ramp) every match, should be well on their way to finals, if not one of the top seeds.
What do you think?
Oh yeah, this data constitutes 270 qualification matches, and none of the finals matches, as those are clearly a different caliber, and need to treated as a seperate type of match so as to prevent skewing the data.
Unread 04-03-2007, 02:00
Barry Bonzack's Avatar
Barry Bonzack Barry Bonzack is offline
Impossible to rain on my parade.
FRC #1902 (Exploding Bacon)
Barry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond repute
Send a message via AIM to Barry Bonzack
[/size]
Using this information we can say with confidence that 68% of red alliance matches from this regional will have a score between 12 - 54 points. 68% of blue matches would be between 0 - 34 points.
My guess is that on a 95% scale that there is not a large enough margin to say this is significant, but I would have to have the data in front of me...And its been a couple years since I took statistics.
Also, I tend to agree with Karthik and believe that this may be a rare instance where medians are more powerful than averages because of the way the game is scored.
Chair of Florida FIRST Alumni
Orlando Regional Planning Committee
FIRST Tech Challenge Florida Leadership Team
Program Planner on the Orion Spacecraft at the Kennedy Space Center
Twitter: @FL_FIRST_Alumni
Events I'm Emceeing/Game Announcing:
1/10/2015 FTC Jacksonville League Championship
1/11/2015 FTC Central FL Tesla League Championship
1/17/2015 FTC South Florida League Championship
1/24/2015 FTC Tampa/St. Pete League Championship
2/7/2015 FLL Orlando Regional
2/14/2015 FTC State Championship
2/26-2/28/15 FRC South Florida Regional
3/8/2015 FLL State Championship
3/12-3/14/15 FRC Orlando Regional
4/22-4/25/15 FIRST World Championship Event - FTC Franklin Field
Unread 04-03-2007, 08:44
aksimhal's Avatar
aksimhal aksimhal is offline
AKA: Anish
FRC #1123 (Autodidactic Intelligent Minors)
aksimhal is an unknown quantity at this point
Send a message via AIM to aksimhal
If all this about the red allience advantage is true, than what makes the red allience stronger?
Unread 04-03-2007, 10:56
Wedge34's Avatar
Wedge34 Wedge34 is offline
FRC #0868 (TechHOUNDS)
Team Role: Student
Wedge34 is an unknown quantity at this point
you can see red much better from the station, and in STL, you did not have meetool birgade screaming behind you
Unread 04-03-2007, 11:04
VanMan's Avatar
VanMan VanMan is offline
NCSU student
AKA: David VanLeeuwen
no team (Team Awkward Turtle)
VanMan will become famous soon enough
Send a message via AIM to VanMan
We never scored in triple digits and our opponents never scored in triple digits because we are so good at defense.
2010-present - NC State University Underwater Robotics Team
ncsurobotics.com
2007-2009 - FRC 2108
2006 - FRC 926
Unread 04-03-2007, 12:13
StephLee's Avatar
StephLee StephLee is offline
Deadlines? What are those?
AKA: Stephanie
FRC #0639 (Code Red Robotics)
StephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond repute
Send a message via AIM to StephLee
At VCU, the total score for the entire competition by color breaks down like this:
Qualifiers only:
Red - 1116; Blue - 1535
Red average: 12.7
Blue average: 17.4
Eliminations only:
Red - 665; Blue - 627
Red average: 36.9
Blue average: 34.8
All matches:
Red - 1781; Blue - 2162
Red average: 16.8
Blue average: 20.4
For VCU at least, the red side didn't seem to have an advantage when the matches were supposedly random. It makes some sense for the red side to score slightly higher in the eliminations since red is the higher seeded side.
Proud alum of FRC Team 1629 and mentor of FRC Team 639
Cornell Engineering class of 2012!!
Unread 04-03-2007, 12:17
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Anyone rememeber the discussion of the visability of the home zone tape? Did that reflect in any last second penalties for one side more then the other?
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 04-03-2007, 12:40
VanMan's Avatar
NCSU student
For some reason our team was normally on blue alliance. There were a few times only that we were on blue. And in eliminations we were always on blue. Seems kinda weird to me.
ncsurobotics.com
2006 - FRC 926
Unread 04-03-2007, 12:44
StephLee's Avatar
AKA: Stephanie
In elims the higher-seeded alliance is on red. Since you guys were 6th and never met up with the 7th or 8th alliances, you always played blue. For the regular matches, though...I guess that happens sometimes. With only 8 matches I guess it's not much of a statistical oddity to be on one side 6 times and the other only two, for example.
Red Advantage ? Krystine T. General Forum 90 16-06-2008 13:41
Advantage given by succesful autonomous mode DanDon Rules/Strategy 75 19-01-2007 08:32
The advantage of holonomic drivetrains KrazyRoadster Technical Discussion 28 12-04-2006 19:29
2006 Boilermaker red advantage? Alan Anderson Regional Competitions 16 19-03-2006 16:40
Which treads have an advantage? master Technical Discussion 15 15-12-2005 18:09
