Go to Post We fail to present a coherent picture of what we are if we aren't vigilant about our self-image. - Alan Anderson [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 02-03-2007, 20:26
d.courtney's Avatar
d.courtney d.courtney is offline
AKA: David
FRC #0781 (Kinetic Knights)
d.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud of
Re: "Random" match Schedules
These results are no different then the findings I had from Waterloo last year, mind you Waterloo is a very small regional, making it harder to mix up teams while still giving them a good enough break in between matches (was the reason given when I approached the issue). After approaching FIRST about this at a debriefing, I had the chance to see the code they used for Waterloo, it was in fact very well written. There was however a problem, this was that this program didn't "reset" the algorithm after breaks such as the end of day or lunches causing teams to almost stay in a loop of teams they play with every match introducing one team into those they last played with as it ranked having a longer break for the team more important then who they were playing against. I changed this in that code adding a set number of resets, and saw a far more "random" selection between the days, and even better adding 2 more breaks. These two extra breaks are very accomplishable, if FIRST was to say add two 10 min breaks in the day one before and one after lunch, these breaks would also be logical as to allow the volunteers a much needed short break, allow any syncing problems with scoring to be worked out, and a multitude of other practical reasons. I relayed back my solution to the one that made the software, hoping these minor changes could be made.
It could very well be that this "looping" effect where you see teams play with or against others many times, is simply because they don't have resets for the algorithm, or it could be because the algorithm was poorly designed, either way it is a problem FIRST knows about and I find it unfortunate for those teams who have been effected that they haven't solved it yet.
edit: mind you there never was a problem with teams playing against a team all the time... say if they were stuck in the "loop" with said team, a few would be with a few against
Unread 02-03-2007, 20:27
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Team 2021 plays against team 2028 in all of our matches I believe.
Unread 02-03-2007, 20:31
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Quote from artdutra:
* The reason matches are not completely random is because of the algorithms used to "randomize" the matches. Although it may seem like random, adding little things like a minimum time span between a single team's consecutive matches alters the randomness of the results. Now the results are no longer 100% random, but rather the sort of "equally-spaced-out-data" random that people generally associate with randomness.
It is not really completely random. You are more likely to play with the same people that you were competing with and against rather than someone else that is minutes out of your range due to the algorithm FIRST has in place.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 02-03-2007, 20:35
this is absolutely true of the scheduling. the so called randomizing is making the strong stronger and keeping the weak at that same level of performance. This is not helping gathering any significant data during scouting eith er. What are they going to do about this???
Unread 02-03-2007, 20:48
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
Well, it certainly makes scouting a little bit easier for every match.
401 plays against 405 EVERY SINGLE ROUND!!!! Strangely enough, I'm not really noticing this when I drive though. Then again, we're playing mostly defense right now.
Unread 02-03-2007, 20:54
ggoldman's Avatar
ggoldman ggoldman is offline
FRC #0401
ggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud of
Send a message via AIM to ggoldman
Every team in the pits is paired against the team directly next to them (not across the isle).
It is very ironic, because when 401 first got there, we helped repair what turned out to be our perpetual opponent.
I am glad that we could help out their team, but would appreciate more variation in the matching.
A little birdie from the higher ups told me they are working to fix it for the other regionals.
Gabriel Goldman
PhD Candidate
RoMeLa: Robotics and Mechanisms Laboratory
http://www.me.vt.edu/romela
Virginia Tech
Unread 02-03-2007, 21:16
BethMo BethMo is online now
FRC #0948 (NRG (Newport Robotics Group))
BethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to behold
Same problem at the Pacific Northwest regional. 948 vs 949 in every match. 272 vs 360 in every match. And several others whose numbers I've forgotten.
Several of the teams reported the problem to the staff as soon as the pairings were distributed. They said they were looking into it and might be redoing the pairings. We checked back a bit later, and they said that the official word from FIRST was that nothing could be changed.
We are very disappointed, even though this mess-up gave our team an advantage.
Unread 02-03-2007, 21:29
rocknthehawk's Avatar
rocknthehawk rocknthehawk is offline
AKA: Aaron
FRC #1768 (Robo Chiefs)
rocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to behold
Today at BAE, team 549 played team 562 all 7 matches of the day. Also, we played with a team, and then would play against them the next match, then pair with them later again.
Also, this terrible pairing system left teams wondering the capabilities of our robot, because they never got to even TRY and play. We practiced yesterday with many of the teams we played with today...
It was no fun to play with/against the same teams all day.Strategy turned to mush, because we were with and against the same teams all day.
Unread 02-03-2007, 21:36
Andrew Blair's Avatar
FRC #0306 (CRT)
Originally Posted by Richard
Sorry if I gave you the wrong impression, Dave. What FIRST actually told me is that this is the way the algorithm is supposed to generate matches, and there is no means to vary the match-ups. So the intent seems to be that low numbered teams will alternate playing each other. I was told this is not a defect in the system; matches come out that way because that is the algorithm that FIRST specified.
Several people who have been recognized as sources of inspiration to the FIRST community have told me that this match generation system seems unfair, and I concur. I understand that these feelings will be communicated in a respectful manner to the appropriate people at FIRST, probably within the next few days.
On a related note, the scoring system worked flawlessly today at St. Louis -- no crashes, no restarts, no lost data, no delays. We finished about four minutes ahead of schedule, and the only (relatively minor) problems encountered were due to human error.
From Richard's post in this thread, it seems that FIRST has spec'd out an algorithm that places similarly numbered teams in matches together. I suppose it could be an attempt to even the playing field for rookies. Sorry to spread around your post Richard, but this is an interesting and, I think, rather unfortunate change in direction.
We'll be against 291 for two entire regionals...
EDIT: Well, I think Richard's information is correct, based on the ten's of posts on here, from every regional, saying that they're paired up with the same people throughout. The question is, is there anything good about it, and if not, should we do anything to change it? Can we even change it?
-Sir Francis Bacon
-Albert Einstein
Unread 02-03-2007, 21:37
Scott Carpman's Avatar
Scott Carpman Scott Carpman is offline
FRC #1155 (SciBorgs)
Scott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud of
We've played Team 1089 all 5 matches today and we also have the problem with playin in match 9, 19, 29, etc.
RPI '12
Unread 02-03-2007, 21:45
Best Available Data
FRC #1778 (Chill Out!)
One more fun fact. At BAE we have 2 teams which need to play another round to get to 8 rounds per team. As such, 4 (or at least 3) extra rounds have been scheduled, giving 22 (or 16) teams an extra round of practice.
Unread 02-03-2007, 21:49
Sean Marks's Avatar
Sean Marks Sean Marks is offline
AutoCAD User
AKA: Sean Marks
FRC #2016 (Mu Mu Psi)
Team Role: Student
Sean Marks is a jewel in the roughSean Marks is a jewel in the roughSean Marks is a jewel in the rough
Send a message via AIM to Sean Marks
Yea, we have noticed this in the past 2 days. Team have been playing either with against each other for 2 or more matches. I feel it just doesnt show how you will compete with others. It's still a lot of fun though.
2008-NJ Semi-Finalist (Thanks 694 & 1279) / Chesapeake Winners (Thanks 1418 & 11) / Newton Finalists (Thanks 1574 & 141)
2007-NJ Rookie All-Star / Monty Madness Champs
Unread 02-03-2007, 21:50
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Originally Posted by Andrew Blair View Post
... Sorry to spread around your post Richard, but this is an interesting and, I think, rather unfortunate change in direction...
I don't mind you spreading it around.
I'd like to repeat here that the new field management system worked flawlessly in St. Louis today. Credit for that should go to FIRST engineering staff and the new contractors for great attention to the details, to Mark Koors of FRC45 (technical advisor) and Jerry Budd of FRC461 (scoring lead), and to several members of the local St. Louis volunteer corps for tirelessly testing and retesting the system on Wednesday and Thursday, before the fun started this morning. This system is a major improvement over last year.
As I said earlier, I will add my concurrence to the communication being prepared for FIRST regarding the match generation algorithm; however, to me it seems clear that this is a policy issue and not a defect in the field management system. Let's keep the discussion on this topic focussed on what can/should be done to improve match generation.
Richard Wallace
since 2003
Unread 02-03-2007, 21:55
Joel J's Avatar
Joel J Joel J is offline
do you..
I-- can't believe this is how they WANTED the match schedule to be!
What!?
Oh boy...
I hope this just gets redone, rather than rationalized into a "good thing."
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 02-03-2007, 22:01
Pavan Dave's Avatar
Busy in College
I see this as a good and a bad thing. Although I do not like the fact that you are against the same people over and over, I bet FIRST or someone can create an algorithm that can at least make the first half of the teams compete with only first half teams and second half teams only second half with a few inter lapped but I think that Rookies vs Rookies rather than Veterans vs Rookies is a great idea because Vets, no matter if they are rookies on the team, have a higher chance of winning because the team has had the experience compared to the Rookie teams.
I'm not 100% for it, but im not 100% against it either. I guess its a step in the right direction....Maybe a diagonal step, but forward nonetheless.
1745 - 118 - ΔΕΨ
"Live with Lucas" Mock Match Tomasz Bania General Forum 14 10-04-2006 09:50
"Random" Match List Generation Sean Schuff Regional Competitions 32 01-04-2006 21:26
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
"Random" pairings Ken Delaney General Forum 5 25-03-2002 00:38
