Go to Post Programmer says autonomous will work 100% perfectly...Great way to clear the room of all mechanicals and all but the boldest electricals - EricH [more]
Unread 02-03-2007, 20:46
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Anyone lost thier BaneBots Carrier pins?
During our last match today, we lost one side of our drivetrain, and were unable to drive around. When we took apart the BaneBots gearbox, all 5 of the pins in the carrier plate had come out of the carrier plate, so that the output shaft spun freely. This is with the new hardened carrier plates, in a 2-CIM 12:1 gearbox.
Has anyone else had this problem?
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 02-03-2007, 21:21
JoshD's Avatar
JoshD JoshD is offline
FRC #0975 (Synergy)
JoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to behold
Send a message via AIM to JoshD Send a message via MSN to JoshD
Re: Anyone lost thier BaneBots Carrier pins?
I did notice that when I put the new plates in that they were really just pins stuck inside a through hole, unlike the other plate which had pins in a partial hole. Thanks for getting this out, now it ours fails I'll know what's wrong with it.
Unread 02-03-2007, 21:26
Andrew Blair's Avatar
FRC #0306 (CRT)
Banebots, in a hurry to get these new carrier plates out, had to substitute a standard pin that they could easily obtain in place of their own, longer pin. Therefore, the pins are a bit shorter. I guess the lack of engagement inside the hole is allowing the pins to back out in operation.
I suppose teams should press the pins back out and use some press-fit loc-tite to retain them. That seems like the easiest solution. Any team with an arbor press should be able to take care of it in a few minutes.
-Sir Francis Bacon
-Albert Einstein
Unread 02-03-2007, 21:32
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
There was one report of this problem from a team at St. Louis. I believe the team was 525. Hopefully someone from that team will provide more details.
Richard Wallace
since 2003
Unread 02-03-2007, 23:25
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
From what I heard this happened to our team (I'm a programmer, but I think this is what happened.)
We have pictures of the carrier plate somewhere...
http://www.mikesorrenti.com/
Unread 03-03-2007, 19:20
AKA: Steven Bell
Re: Anyone lost their BaneBots Carrier pins?
I wasn't there when it happened, but we apparently lost the pins on the other side this morning. We had been playing a lot of defense. Unfortunately, there's no good way to check for the problem without taking apart the gearbox, and when it fails, it fails completely.
We had noticed difficulty making left turns sometimes, and backing up made the problem go away. This might be a warning sign, but we need more evidence to prove it.
Unread 04-03-2007, 22:17
Tapoore's Avatar
Tapoore Tapoore is offline
AKA: Tom Poore
FRC #1519 (Mechanical Mayhem)
Tapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of light
Yes. BOTH of the BB transmissions on our robot failed during the course of one regional. They failed in exactly the same way and likely cost us a qualification round. We had the second one fail on us during the QFs. Fortunately, because of good planning and an amazing display of teamwork, we were able to swap out and install an spare transmission assembly in between matches. Our drivetrain is a 6 wheel-drive using the KOP wheels with the center wheels lowered.
- www.mechanicalmayhem.org -
* 2015 Granite State District Event Champions
* 2013 Einstein Finalists
* 2006, 2010, 2011 Granite State Regional Champions, 2009 Chairman's Award
* 2012, 2013 North Carolina Champions
Unread 04-03-2007, 23:05
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Well, I guess we won't be using these transmissions next year.
We will pull them out and rebuild them for our next 2 competitions.
Does anyone know the precise diameter of the pins?
I think if we insert a short pin into the top of the planetary gear, this may prevent the longer pin from coming out, in addition of course to putting some thread locker on the ends of the long pins.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 04-03-2007, 23:08
Robo_Coyote's Avatar
Robo_Coyote Robo_Coyote is offline
Cheap_Shot
AKA: Chris Chandler
FRC #1323 (MadTown Robotics )
Robo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to behold
Team 1323 had one of our transmissions lock up. We were running the two CIM adapters to the kit banebot transmission with a new carrier plate and the spur gear in the center had pushed the inner carrier plate out and was making the Global Gears bind. Team 1778 in the pit next to us had this happen twice with two different Transmissions and they were only running one CIM to them. Anyone else have this problem
2005- Uc Davis Spirit Award
2006 nationals second highest score thanks to 233, and 1184
We need a longer highlight list....... sigh
"To invent all you need is imagination and a pile of junk" - Thomas Edison
Unread 04-03-2007, 23:14
Bruce Newendorp Bruce Newendorp is offline
Engineer
FRC #0525 (Swartdogs)
Bruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to behold
We had the same problem - the pins came out of the new carrier plates and one of the planet pinion gears stripped. I posted a long explantion on this Our Banebots Experience thread.
Unread 04-03-2007, 23:20
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We had this happen in testing. Locked up so bad couldn't turn it with a 5" wheel on it. Single CIM, 40lb bot, slippery surface. Took it apart, greased, put back together, ran like butter.
Unread 05-03-2007, 21:40
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Yes, it has happened to us, multiple times. Those carrier pins shoot out after less than an hour of driving on our robot- and we are simulating competition defense. This really is not good.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 06-03-2007, 05:28
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
Yes.... In NJ we took them to the machine shop and had them spot welded. That seemed to hold them for the rest of the regional. I don't know if that fix will last.
Unread 06-03-2007, 07:27
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
My biggest concern here is that we've replaced a predictable failure (increasing backlash until the double d fails) with an unpredictable failure (pins pulling out of the carrier plate). If this is the case we have made a bad situation worse and almost makes me want to consider keeping the weaker carrier plates.
Unread 06-03-2007, 10:30
Elgin Clock's Avatar
FRC #0237 (Black Magic)
I'll get them pics up tonight for all to see.
Basically in the high stress situations inside the transmissions, the pins holding the carrier plate to the gear array slipped right out of the plate. Slip fit pins anyone?
Not good.
That was our fix, and I'll post a pic of that as well for reference.
Rochester Democrat and Chronicle Gives Local FIRST Team Thier Own Spotlight Koko Ed FIRST In the News... 27 30-01-2008 11:51
pic: Carrier plate deathbycornchip Extra Discussion 2 18-02-2007 10:51
pic: Pins Pins and more pins CD47-Bot Extra Discussion 26 04-09-2005 23:07
who has combined PVC tubing for thier frame? Alex Cormier General Forum 8 12-12-2004 19:47
Drill Motors: Pins IN or Pins OUT Caleb Fulton Motors 28 03-02-2003 14:19
