Go to Post For a good time, call 1-800-GOFIRST - Wayne Doenges [more]
Unread 18-02-2007, 02:34
agriffchs08 agriffchs08 is offline
Team Captain/Head Programmer
AKA: Antonio
FRC #1827 (Center RoboJackets)
agriffchs08 is an unknown quantity at this point
Send a message via AIM to agriffchs08 Send a message via Yahoo to agriffchs08
Servo Tracking
I'm working in easyC and have got my teams camera to RECOGNIZE the green target light. However, whenever the program starts running the pan and tilt servos go to one specific set of coordinates and stay there. According to the terminal the camera is tracking the light but in actuality it reads it but does not move towards it...anybody know what I need to do to fix it? I've tried adding a Set Servo Tracking function block, but don't know where to place it.
Unread 03-03-2007, 21:35
cmptrgy412 cmptrgy412 is offline
Robohawks Programmer
AKA: Jacob G
FRC #1985 (Robohawks)
cmptrgy412 is an unknown quantity at this point
Re: Servo Tracking
I don't remember the global variable names exactly, but make sure that the pwms for your pan and tilt servos are set to the correct pwms. Are you using kickoff code or your own. If your own, some source would be appreciated.
Unread 05-03-2007, 13:50
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Servo Tracking
I'd recommend on clicking the help button on the "Set Servo Tracking" block and it will explain how to use it.
Then you just make two variables "unsigned char' call them pan and tilt persay and write data to them in the caputre tracking data panel. Then write those values to a PWM Output.
Quetion about servo tracking function in easyC pro itsme Programming 5 31-01-2007 11:30
Servo & Tracking Problems Team 849 Programming 4 28-01-2007 01:28
Servo tracking... pan reverse Terry Yiu Programming 2 23-01-2007 22:26
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Tracking beacon without servo Paul Marshall Technical Discussion 17 10-02-2004 20:58
