Go to Post the FIRST season is never over . . it just pauses a while so you can get some sleep. - Stuart [more]
Unread 04-03-2007, 00:15
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
Re: How to Hook up LCD
It sounds like you are trying to set up a system that connects to the OI dashboard, parses the data, and then prints it out onto a LCD.
If you are looking at just doing the current angle, why don't you use the 3 number display already on it?
if you still want to do the LCD, I would suggest using a 16f628 and decoding the dashboard data. The specs on the data packets are on IFI's website.
How to hook up a Police light on the Robot?? xur2007 Technical Discussion 4 13-11-2006 18:27
how to mount a lcd display onto a robot mechanicalbrain Electrical 9 07-09-2005 20:57
How do you hook up the camera? SpeakerSilenced Programming 18 16-02-2005 15:00
How do u hook up the digital input to the sensor's wires Fares Technical Discussion 2 14-02-2003 16:41
how do u hook up things through the fuse panel? chrisw Technical Discussion 9 12-01-2002 19:51
