Go to Post its not that I cant spell, I'm just being international. . . . I like it - Stuart [more]
Unread 04-03-2007, 00:36
Re: How to Hook up LCD
Originally Posted by magical hands View Post
Thanks Mark for clearing up. So with the help of "Backpack" I don't have to do anything, absolutely no wiring but simply attach that LCD to the serial port. Also for the coding I can simply use Mr. Kevin's code for serial driver.
What if I am also using a camera? How do I manage to use serial driver than?
The serial driver should take care of everything in the background. Just set where you want to send the data and go for it. The problem is not so much the serial driver (everything is done in printf's, there is no need to recieve or parse any data), but rather the code to drive the LCD itself. Serial is the established protocol for the LCD screen and you have something to stick to that protocol, but you still need to write code to make the LCD work.
What exactly do you plan to use this LCD for?
How to hook up a Police light on the Robot?? xur2007 Technical Discussion 4 13-11-2006 18:27
how to mount a lcd display onto a robot mechanicalbrain Electrical 9 07-09-2005 20:57
How do you hook up the camera? SpeakerSilenced Programming 18 16-02-2005 15:00
How do u hook up the digital input to the sensor's wires Fares Technical Discussion 2 14-02-2003 16:41
how do u hook up things through the fuse panel? chrisw Technical Discussion 9 12-01-2002 19:51
