Go to Post Now I'm off to see the wizard, the wonderful wizard of Cogs. - Matt Krass [more]
  #31   Spotlight this post!
Unread 03-03-2007, 17:07
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Keepers after autonomous
Originally Posted by Kevin Kolodziej View Post
Does anyone have any insight into this??
Yes. The legal justification is <G14>, and the practical justification is to prevent ringers from inadvertantly being scored during the switchover from autonomous to teleoperated, as happened during the elimination rounds in New Jersey today.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
  #32   Spotlight this post!
Unread 03-03-2007, 19:47
The Lucas's Avatar
CaMOElot, it is a silly place
All auto coders and operators should be careful that their gripper does not open as teleoperated mode starts after autonomous. The tube at NJ was scored at the start of teleoperated mode not in between auto and tele (the bot's program opened thier gripper). There is no good reason that the refs should have to wrestle with a gripped tube. They should only have to remove ones that were released and hang precariously without scoring. The team should be responsible for disposing of their keepers after auton.
FIRST should issue a warning via team update and reiterate it at the driver meeting. It is not the refs responsibility. Any team that doesn’t comply and scores a late keeper (even unintentionally) should be DQed for scoring the late keeper. Any team that can auto program, can program their bot to hold onto the keeper when user mode starts (operator may need to set a switch as well). First week should get a pass because it was unexpected (I never thought about it either).
Robot Inspector
  #33   Spotlight this post!
Unread 03-03-2007, 20:21
Kevin Kolodziej's Avatar
Kevin Kolodziej Kevin Kolodziej is offline
Operator in 100+ matches
AKA: Yngwie Kamen's roadie
Kevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond repute
Send a message via AIM to Kevin Kolodziej
G14 says that refs may remove ringers that are not hanging. Take them off the field...thats fine. But to go in and remove one from posession of a robot?? I disagree. I DO NOT want any ref coming on to the field and disturbing my robot, let alone forcing open a gribber that is not meant to be open when its not supposed to be open. The robot I saw the ref wrestle a ring from was not in scoring position and would have had no problem dropping the keeper as soon as the teleoperated mode started.
The case where the keeper was scored in the dead period is a gray area, but the practical solution, in my eyes, is just to say that that ring is on the rack but doesn't count and there is no penalty. Actually, a more appropriate ruling, I think, would be an update that is similar to last year (balls shot before the buzzer, but in flight when the buzzer sounds, still counted), allowing for keepers to count that were released before the buzzer (lets say I have a ringer above the third spider foot, I release, the buzzer goes off, and then it settles on to the rack). If my robot is touching the keeper before teleoperated mode (I scored it but didn't released, as was the case today, or I let go, but then my manipulator sags and touches it), that keeper is void. All there needs to be is a standard 5 second minimum delay for refs to verify scored, null, or nothing (obviously the longer delay is acceptable as well if they need to go on the field to look........but I still have my issues with that), and the problem is solved.
Team 71: 1999, 2000 (Driver), 2001-2002 (Driver, Animator) // Team 1064: 2003 (Co-founder, Coach), 2004 (Coach) // Team 1714: 2006-2007 (Mentor, Coach)
Team 1675: 2005-2007 (Mentor, Coach), 2008 (Mentor), 2009-2017 (Mentor, Coach)
FLL: '04 (Judge), '05 (Ref), '06 (Ref), '07 (Ref), '08 (Judge, Ref), '09 (Judge), '10 (Ref), '16 (Judge Advisor) // Ref: '05 (IN, IRI), '06 (IN, IRI), '07 (IN, IRI), '08 (WMR, Curie)
WI RPC: 2006 - 2016 // FRC Inspector: '07 (WI), '08 (WI, IL), '09 (WI, IL), '10 (WI, CMP), '11 (WI, IL, CMP), '12 (WI), '13 (Northern Lights)
2007 WI Woodie Flowers Award Finalist // 2011 Wisconsin Regional Outstanding Volunteer // 2011/2013 Midwest Regional Chairman's Award
  #34   Spotlight this post!
Unread 03-03-2007, 20:46
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer &amp; Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Originally Posted by T. Hoffman View Post
A robot actually hung the keeper after autonomous but BEFORE teleoperated period during one match at NJ. It seems the field control dudes can delay the start of the teleoperated period. After autonomous, the arm was disabled and drifted down from the middle row, dropping the keeper down to the lower row and scoring it. The refs stopped the match and forced a reset.
That head ref seemed rather agitated at having to go extract keepers from the robot death grips....
The scoring table has the ability to keep the tele - operated period from occuring for an unknown amount of time after autonomous period ends. Thats why some periods would run a few seconds quicker then others b/c the head ref can tell the scoring table when to start the next phase of the match. As for the head ref at NJ being agitated - I must agree he seem angered having to go out on the field after autonomous to remove any keepers from being accidentally scored as if someone was forcing him to do go out there and get the keeper out of the robots possession. I mean he was just tossing the keepers all over the place as well as rocking the robot around and forcing open motored and pneumatic grippers. I don't care if he's been head ref'ing for 20 yrs. One should take great care in handling someone else's property to ensure it doesn't get damaged while being handled. Teams should not have to spend more time on fixing there robots all b/c a ref decided to rip the keeper from the robot. Teams have already spent 6 wks in building now they may have to spend hours trying to fix that mistake.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
  #35   Spotlight this post!
Unread 03-03-2007, 21:45
dbell dbell is offline
Mentor for team#3937 (Breakaway!)
AKA: David Bell
FRC #1519 (Mechanical Mayhem)
dbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to behold
Re: keepers once the match has started
at the BAE GSR, after the autonomous mode the head ref would come out onto the field and take away the tubes that robots were holding. this might happen at other regionals too. you can't score a keeper in tele mode anyway so I don't know why he did that.
  #36   Spotlight this post!
Unread 03-03-2007, 22:10
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
The head ref from BAE removed any keepers from the grips of robots. If they were on the floor he left them.
In the first match, one team had a keeper in their gripper so tightly that the head ref took out a knife and completely destroyed the thing.
I think he did it as a "What a way to open the day!" kind of thing. It was kind of amusing.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
  #37   Spotlight this post!
Unread 04-03-2007, 07:40
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Something funny happened at the NJ regional. During autonomous, a robot went out towards the rack and was just getting ready to place the keeper when time ran out. When the teleoperated mode started he dropped the keeper and it fell onto the spider and scored. The refs left it there and continued play but the match was stopped. I don't know if it was because of the illegal keeper or another problem. When they replayed the match the same robot went out and still didn't drop before time ran out. Before the teleoperated mode started a ref came out and had to forcibly remove the keeper frome the robots grasp.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
  #38   Spotlight this post!
Unread 04-03-2007, 08:01
The Lucas's Avatar
The match was stopped due to the Late Keeper. I'll say here what I said in the other thread.
Programmers and operators : Do not let your robot drop the keeper as the first thing it does in teleoperated mode; before an operator even touches the controls.
This late keeper is grounds for disqualification!
Set your program and/or OI switches so that the robot keeps the keeper in its death grip until the operators can properly dispose of it.
Robot Inspector
  #39   Spotlight this post!
Unread 04-03-2007, 11:30
Spencer E.'s Avatar
Spencer E. Spencer E. is offline
Android junkie
FRC #1305 (NNSRI Ice3 (cubed))
Spencer E. has a spectacular aura aboutSpencer E. has a spectacular aura about
Send a message via MSN to Spencer E.
Okay. So does this mean that I have to program my autonomous to automatically let go of the tube right after the auton period is up? I don't need to drop it do I? Can I just release the grip and that can be the end of it? One last question if there are any programmers in here, do spikes automatically set themselves to 0 once disabled?
  #40   Spotlight this post!
Unread 04-03-2007, 11:41
The Lucas's Avatar
I think you program your bot to hold onto the Keeper (if you didn’t drop it in auton) and let your drivers place it on the floor. In the disabled period between auton and tele all spike outputs are 0 and pwm (victors) are 127. If you have a single solenoid it will return to its default state. You shouldn't worry about what your bot does when disabled (it is out of your control you will not be penalized and the keeper might count if you score it right after being disabled). Just focus on what it does when tele mode begins. Don’t release and score a Late keeper before the drivers can even touch the controls.
Robot Inspector
  #41   Spotlight this post!
Unread 04-03-2007, 13:07
dpraedan dpraedan is offline
AKA: Peggy
FRC #0190 (Gompei & the HERD)
dpraedan is an unknown quantity at this point
Send a message via AIM to dpraedan
The head ref at the UTC scrimmage did that several times as well. Doesn't seem right to me, as teams should be allowed to drop in the start of tele-op, but it's ultimately their call.
  #42   Spotlight this post!
Unread 04-03-2007, 13:14
VanMan's Avatar
VanMan VanMan is offline
NCSU student
AKA: David VanLeeuwen
no team (Team Awkward Turtle)
VanMan will become famous soon enough
Send a message via AIM to VanMan
Well that doesn't really make sense because at VCU one teams arm wasn't working properly ever so they always had the keeper in. I don't think they were penalized.
2010-present - NC State University Underwater Robotics Team
ncsurobotics.com
2007-2009 - FRC 2108
2006 - FRC 926
  #43   Spotlight this post!
Unread 04-03-2007, 13:39
Using knifes to slice keepers to remove them?????? What is going on here? There is no penalty for keeping a keeper in your possession after autonomous - just for scoring it. If I want to keep a keeper and use it so I have larger reach for defense, there is nothing that says that is not allowed! I am posting a Q/A question about this because I see absolutely no reason at all for refs to come on to the field to remove keepers from robots.
  #44   Spotlight this post!
Unread 05-03-2007, 11:26
Luke Luke is offline
None #0365 (Miracle Workerz)
Luke will become famous soon enough
When I watched that event happen my first thoughts was that the rules as stated meant the NJ ref should have DQ'ed the team instead restarting the match. Each new match the ref continued to prevent the DQ offense from happening by walking onto the field and wrestling the tube off the robot after autonomous. My thoughts were that this is not what the rules says. But wait am I going defend a rule which I believe is too harsh? What I believe now is, we were seeing the ref was trying not to DQ a team due to a rule which carries an undue and too harsh Penalty and needs updating.
Why should this carry a DQ penalty? This is the goal of the autonomous and if you just missed but accidentally put the keeper on after, why a DQ? Usually a DQ is due safety or equipment damage or unfair advantage; I do not see that here.
I think FIRST should rethink this harsh penalty. From the actions of the NJ refs, I believe, that they DID NOT wanted to make that DQ call either.
GOOD CALL NJ REFS!!!
  #45   Spotlight this post!
Unread 05-03-2007, 11:43
Spider-Man's Avatar
Spider-Man Spider-Man is offline
Curling Rocks
AKA: Adam Jacobson
FRC #0467 (DTB/Shrewsbury Colonials); #0034 (Rocket City Robotics)
Spider-Man has a spectacular aura aboutSpider-Man has a spectacular aura about
Here's a post I made about this in another thread about this. Basically, not only do the rules say nothing about removing keepers from robots that can possibly be dropped and not scored, but this issue was addressed very clearly in the Q&A forum.
Weight of game pieces (Ringers/Spoilers/Keepers) Setsanto Kit & Additional Hardware 16 15-01-2007 21:05
the countdown has started xzvrw2 Chit-Chat 2 12-07-2005 03:39
MARCH MADNESS -- has it already started??? wasabi824 Chit-Chat 13 22-03-2004 01:45
ONCE AGAIN, EVERYONE TELL ME THE ANSWER! =) archiver 2001 2 24-06-2002 02:42
has the new season started, or what? Brandon Martus Announcements 1 10-01-2002 02:42
