Go to Post and as you can see, all rumor threads lead to silly, loads of silly - JaneYoung [more]
Unread 04-03-2007, 11:47
magical hands magical hands is offline
Jigar Patel
AKA: Jigar Patel
FRC #2185 (Etobicoke CI)
magical hands is on a distinguished road
Re: How to Hook up LCD
Hey Dave thanks for sharing that info its really amazing. Thats exactly what I am planning on doing with my Tablet, I don't want to use the IFI's Dashboard. or infact use it but have more features to it example it shows ur gyro angle and GTS tooth count, camera values etc. So Dave would the process be still the same for tablet? the fact that I would have to create a cross platform between what Dashboard recevies and what info shows up on my tablet? and what programming language do you prefer this platform to be made in? V.B? C? C++?
Unread 04-03-2007, 12:28
Dave K.'s Avatar
Dave K. Dave K. is offline
Engineer/Mentor
FRC #0930
Dave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to behold
Originally Posted by magical hands View Post
Thank you very much everyone. This post has been really helpful to me. Thanks Mark for sharing your code. The purpose of this LCD is to check the flow of current in our robot, check robot's current angle and distance travelled which is monitored by Gear Tooth Sensor and Gyro. However, the LCD adds the cool factor to the control system. Since its difficult to attach this LCD to the Operator Interface. Now we are planning on attaching a tablet to the OI and have it setup up so the drivers can see all motor values, gyro value, gear tooth value and infact they can precisely control the robot by looking at these values. Also, it helps in troubleshooting our autonomous after every game because we will have record of what went wrong where. So ya!
Is it possible I can change between the two codes in my robot? for example a default code and camera code in robot without downloading back and forth? So I can have control over which code will be used during each game just by flicking some switches on and off?
If you have some unused Digital I/O inputs, configure one or more of them to control which 'code' runs.
unsigned char whichone = 0;
     if (rc_dig_in 14)  whichone |= 1;
     if (rc_dig_in 15)  whichone |= 2;
     if (rc_dig_in 16)  whichone |= 4;
     switch (whichone) {
         case 0:  {
              // run this code
         case 1:  {
             // or run this code
         case 2: {
            // and so on...
         default: {
            // just in case...
     } // switch
On the digital inputs just make up some jumpers, or install some switches between the digital input and ground. You might want to avoid using miniture switches that might be jarred during competition.
--Dave
Unread 04-03-2007, 12:53
Dave K.'s Avatar
Engineer/Mentor
FRC #0930
If you search a little here on CD you'll find previous discussions and pointers on dealing with the dashboard data. Included with IFI's dashboard download you should find their documentation on the serial protocol.
In short, each frame consists of 26 bytes, with the start of the frame consisting of 0xff 0xff. There are three frame types, and you need to look at bits within control bytes to figure out which frame of data you've just received.
The 'dashboard' port is simply the raw data from either the RC->OI OR the OI->RC, the shunt near the connector controls which half of the conversation you are monitoring. The bit rate is 19200.
Remember, this is the raw, unchecked data passing between the OI and RC. There are two "checksum" bytes in the middle of the packet that the RC and OI use to determine whether the packet was good or whether it was corrupted.
For some odd reason, IFI won't document the "checksum" works, and I guess once you know how it works, we aren't supposed to reveal their "secret".
I suppose for just displaying data, data from an errored packet will be quickly replaced by good data and any resulting 'glitch' will probably go un-noticed by the end user. If you use the 'user' bytes to multiplex more data at a slower speed, then understanding how the "checksum" works becomes more important.
As far as the language choice, VB, C, C++, Delphi, will all work fine. It is more a matter of which platform and compiler you are most comfortable and experienced working with.
--Dave
Unread 04-03-2007, 13:18
Jigar Patel
AKA: Jigar Patel
Thanks Dave that was really helpful! I hope I succeed in my mission.
How to hook up a Police light on the Robot?? xur2007 Technical Discussion 4 13-11-2006 18:27
how to mount a lcd display onto a robot mechanicalbrain Electrical 9 07-09-2005 20:57
How do you hook up the camera? SpeakerSilenced Programming 18 16-02-2005 15:00
How do u hook up the digital input to the sensor's wires Fares Technical Discussion 2 14-02-2003 16:41
how do u hook up things through the fuse panel? chrisw Technical Discussion 9 12-01-2002 19:51
