Go to Post Any metric you want to apply to Pink, they will pass with flying colors. Pun intended. - Lil' Lavery [more]
Unread 04-03-2007, 13:47
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
pic: FRC1341's 2007 Robot Fully Deployed
Unread 04-03-2007, 13:48
RoboMadi's Avatar
RoboMadi RoboMadi is offline
3 Fs..... Fun Friends FIRST!!
AKA: Imad
FRC #0612
RoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant future
Re: pic: FRC1341's 2007 Robot Fully Deployed
looking good!
psst.....are you guys planning to cover your electronics? Funky things can happen when another manipulator tries to dig in
Unread 04-03-2007, 13:50
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
So I see the 2006 bot in the back. Adam, fix your shoootteerrr!
Now for the 2007 robot.
1) do you have a FP motor directly attached to the shoulder for the bot?
2) How much does the whole thing weigh?
3) What are the ramps made out of?
4) Does your cam work? Planning on protecting it at all?
5) Do I have to come after you this year too saying, "Fix your ramps?" =)
Unread 04-03-2007, 13:55
RoboMadi's Avatar
AKA: Imad
FRC #0612
Ramp? i thought they are using the CAT forklift; pictured in back
Imad
Unread 04-03-2007, 21:48
I'm baaaaaaack.
Originally Posted by RoboMadi View Post
looking good!
We plan on doing that at the regional
1) Its actually a banebots motor attached to a 1:64 banebots gearbox attached to the second stage of the FP gearbox directly attached to the shoulder.
2) 110 (a little bit under)
3) Aluminum mesh
4) It works somewhat. We may nix it and then replace it at various times during the regional depending on the time our programmer has
5) Probably
Imad
I wish.
Unread 05-03-2007, 10:28
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
Definitely cover your camera if you plan on using it. We had a plastic box for it both last year and this year, which kept it (mostly) out of harm's way.
Another suggestion for the cam: they are HIGHLY sensitive to any type of static. We used some anti-static spray on the inside of our protective case (though not on the actual camera), as well as the wheels of our robot. I highly recommend doing this if you find static is a problem.
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
pic: 696 Circuit Breakers - Wings Deployed sanddrag Robot Showcase 15 08-04-2007 15:41
pic: 1429 Ramps deployed Pjohn1959 Robot Showcase 11 15-02-2007 15:09
pic: FRC488 Lift Mechanism Deployed Madison Extra Discussion 17 03-02-2007 23:17
pic: 498's Aircraft Carrier Deployed Donut Extra Discussion 18 19-01-2007 15:03
pic: 476 - wings deployed CD47-Bot Robot Showcase 8 02-04-2003 23:37
