pic: FRC1341's 2007 Robot Fully Deployed
Re: pic: FRC1341's 2007 Robot Fully Deployed
looking good!
psst.....are you guys planning to cover your electronics? Funky things can happen when another manipulator tries to dig in ![]() |
So I see the 2006 bot in the back. Adam, fix your shoootteerrr!
Now for the 2007 robot. 1) do you have a FP motor directly attached to the shoulder for the bot? 2) How much does the whole thing weigh? 3) What are the ramps made out of? 4) Does your cam work? Planning on protecting it at all? 5) Do I have to come after you this year too saying, "Fix your ramps?" =) |
![]() Imad |
2) 110 (a little bit under) 3) Aluminum mesh 4) It works somewhat. We may nix it and then replace it at various times during the regional depending on the time our programmer has 5) Probably Quote:
Definitely cover your camera if you plan on using it. We had a plastic box for it both last year and this year, which kept it (mostly) out of harm's way.
Another suggestion for the cam: they are HIGHLY sensitive to any type of static. We used some anti-static spray on the inside of our protective case (though not on the actual camera), as well as the wheels of our robot. I highly recommend doing this if you find static is a problem. |
| pic: 696 Circuit Breakers - Wings Deployed | sanddrag | Robot Showcase | 15 | 08-04-2007 15:41 |
| pic: 1429 Ramps deployed | Pjohn1959 | Robot Showcase | 11 | 15-02-2007 15:09 |
| pic: FRC488 Lift Mechanism Deployed | Madison | Extra Discussion | 17 | 03-02-2007 23:17 |
| pic: 498's Aircraft Carrier Deployed | Donut | Extra Discussion | 18 | 19-01-2007 15:03 |
| pic: 476 - wings deployed | CD47-Bot | Robot Showcase | 8 | 02-04-2003 23:37 |
