Go to Post Your robot is trying to talk to you, all you have to do is listen. - Al Skierkiewicz [more]
Unread 03-03-2007, 13:31
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
KOP Gyro seems to run-on after turn stops
Hi
I'm trying to implement a closed loop controller with the KOP Gyro, and it seems to have a major flaw !!!
The initial symptoms were that if you locked the current heading when the operator stoped turning the bot (joystic returns to detent), the controller would steer the robot BACK about 30 degrees.
I initially suspected my code, but finally I had to start looking at the actual Gyro input. By just wiring the Gyro to a stand-alone RC unit on analog channel 1, I could display the gyro angle whenever it changed.
If I spin the gyro, the heading starts changing immediatly, but when I stop it, the heading changes continue on for almost another SECOND. Once again I suspected my software (maybe overflowing the serial port), so I changed the input to a pot so I could simulate gyro input.
With the POT, the heading stopped as soon as I returned the put to neutral.
So, it really looks like the Gyro output doesn't go to zero (bias) quickly when the turning stops. I even tried widenning the deadband, but that didn't help either. Can anyone verify/disprove this from recent experience?
So, it seems to me that with such a long run-on, the gyro is next to useless for any sort of high speed control. The best I can expect is a drunken meander across the field.
Any suggestions would be greatly appreciated.
Phil.
Phil Malone
http://www.GEARSinc.org
Unread 03-03-2007, 21:17
Re: KOP Gyro seems to run-on after turn stops
I'd still suspect your code, but really the serial port buffer.
As a validation check you could bypass the serial port by adding a software check to turn on an OI LED whenever the gyro (or pot) output is not changing (significantly).
P.S. I accidentally cut out that the kit gyro tested alright for us.
Unread 03-03-2007, 22:13
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Also keep in mind that if you are printing to standard out, what you see can lag behind "real time", mainly if you are printing out every program loop. When outputting that fast, the buffer can't keep up. If you make it so that it only prints out every .1s or so, it will keep up better.
Unread 04-03-2007, 02:46
Rick-906's Avatar
Rick-906 Rick-906 is offline
inventor of the hoverbot-2006
AKA: Richard
FRC #0296 (Loyola Northern Knights)
Team Role: Communications
Rick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to behold
we have the same problem, we just use a button to disable the gyro untill we can fix it, it works fairly nicely
The knack of flying is learning how to throw yourself at the ground and miss.
--Hitchhikers Guide to the Galaxy
2006 Archimedes Divisional Champions
2006 Championship Winner
Unread 04-03-2007, 11:06
PhilBot's Avatar
AKA: Phil Malone
Yeah, I really did suspect the serial port, so I went out of my way to test that aspect..
I coded up a simple state machine so that the only thing that was printed was when the gyro stated moving and when it stopped. This way you could see exactly when the first and last change occured... typical output was:
Started 901
Stopped 1805
Started 1801
Stopped 908
This indicate two 90 degree rotation sequences (First CW then CCW, showing tenths of a degree). So no chance of overflowing any buffers etc..
What I find odd is that the angle appears correct although the "Stopped" value was printed a second after I actually stopped. (Despite trying dead-bands all the way from 4 to 20).
Also, for the record, if you output too fast using Printf's you just lose characters... they don't back up.
Has anyone actually looked at the output of one of the lastest KOP Gyros on a scope? Does the output cut off immediatley after a rapid rotation?
Phil.
Phil Malone
Unread 04-03-2007, 14:10
Rick-906's Avatar
AKA: Richard
if you guys are right i can tell our programmers to stop banging their heads against the wall.
we used a KOP gyro from a few years ago and it seemed to work better than this one. however at that point all we had was a drivetrain so i could be wrong
Unread 04-03-2007, 17:03
PhilBot's Avatar
AKA: Phil Malone
I'm having reasonable sucess using the Gyro to drive straight (for autonomous mode), but forget about using it after quick turns.
After a fast turn I need to wait for the gyro rate to drop to zero before locking in a new heading. This makes the robot look like it's having a momentary brainer... but then it takes off again, and drives straight.
Phil.
Phil Malone
Unread 04-03-2007, 18:22
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Phil.
The KOP gyro has a maximum number of degrees it can turn in one second before it 'overflows' and loses accuracy. To the best of my knowledge, this value is ~85 degrees in one second for the KOP gyro. If you try turning 180 degrees in one second, you will overflow the sensor and drastically lose accuracy. (This is the same as exceeding the +1G acceleration on the accelerometer.)
For use of the gyro with our drive-train on our robot this year, we purchased an additional gyro with a maximum turn-rate of 300 degrees in one second from Spark Fun Electronics. (Which has tons of great sensors, BTW.) Seeing how our drive-train this year is geared for 9 ft/sec at 85% of the CIM motor free speed, the increased turning-rate of this additional gyro was much appreciated.
Art Dutra IV
世上无难事,只怕有心人.
Unread 05-03-2007, 12:43
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Actually, this year's KOP gyro can handle 150 degrees/second of turning. In the past it could only handle the 85.
Camera Just stops!!! Robostang 548 Programming 17 05-02-2007 21:50
How to end an auto mode after gyro gets out of deadband kiettyyyy Programming 17 20-04-2006 07:59
KOP Gyro John Gutmann Programming 12 12-12-2005 21:59
Robot motion after the time has run out. Randy Ai Rules/Strategy 1 06-01-2003 17:17
#9 seed seems to be the spot to be.... archiver 2001 1 24-06-2002 03:00
