Go to Post Let's not speak without knowing the "facts." If you say something please have valid reasonings behind it. =) - Arefin Bari [more]
Unread 04-03-2007, 19:16
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Squishing the Spiders
Originally Posted by d.courtney View Post
I don't see ramps having that big of an advantage, I mean 80% of the teams I have seen so far will have trouble getting onto them (let alone staying on) all due to their clearance. The bots at a tremendous advantage are the ones that lift, where there is simply a 1 inch platform one climbs up and your lifted. (after seeing parts of VCU and New Jersey I am soo glad our team went that route)
The important thing is efficiency and ease of use. You could argue, depending on the setup, that a one inch lip is significantly harder to negotiate than a shallow ramp. And if your lift fails, mechanically or time wise, it fails. No points. If a ramp is well constructed, its the skill of the driver decides the points earned.
But, I will agree with you that the webcasts suggested lifts often proved more effective than ramps- generally because of the lack of side guards. Week two and on may be a different story.
-Sir Francis Bacon
-Albert Einstein
Unread 04-03-2007, 21:56
d.courtney's Avatar
d.courtney d.courtney is offline
AKA: David
FRC #0781 (Kinetic Knights)
d.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud of
Well it works both ways, I have seen teams with ramps that got caught as they lowered them rendering them useless. What I was referring to was between a well designed ramp and well designed lift (locks into place as to not fail after the match), then the lift will always be better, if only because a team with very little ground clearance can get on. Yes some like to drive up a gradual ramp rather then a 1 inch lip, which was the very reason we added a 8 inch gradual slop on our end of our platform. Time wise I would argue they are the same, the time it takes for a team to drive up a ramp successfully without falling of is about that of lifting two robots.
But as you said, only time will tell which are better and more reliable.
Unread 04-03-2007, 22:13
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
wow... its amazing to see that people think lifts are better. I remember at the beinging of the season people were all about the ramps, and that lifts were far to dagerous to be put to good use, but now they seem to have evened out on which is better. I still like the idea of the lift personally.
As for the topic of this thread, it does seem very smart to have an auto mode that rams the rack, ecspecially if your allies don't have autos, keep that as a extra option for your auto seems like a good idea, and should be kept in the bank for use when you need it (ie. if the other team has two or three working autos where you have only yourself). Also it seems some bots can deal with swinging, and some bots can't. I have watched a few matches and it seems some bots don't care at all that someone just rammed the rack, and they score anyways, whereas some bots completely lose it and can't score anything ever aain for the match (slight exaggration) it will really depend on how comfortable the drivers are I think.
Unread 04-03-2007, 22:21
Petey's Avatar
Petey Petey is offline
Strategy & Gaming
AKA: Chris Peterson
None #1073 (Team F.O.R.C.E.)
Petey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond repute
I wasn't just referring to autonomous mode either. Our alliances strategy in the finals (against the highest scoring alliance at BAE) was pretty much to disrupt their scoring capability by any means necessary, including slamming into the spider legs.
Bio:
Team 1073 alumnus, now Admissions Officer at MIT.
Thanks to all those who have helped me through FIRST over the years.
Unread 04-03-2007, 22:25
FRC #1360
only thing you have to watch out for is disrupting your teammates. That and squishing spiders make it rain, and you don't want your robot to rust up now do you?
Unread 04-03-2007, 23:04
d.courtney's Avatar
AKA: David
What I find smarter is backing up a foot after the tube is on before letting go....I still can't get over the sheer humour that would happen when team x caps nothing but air because team y held the legs a foot back with the tube and then let go and shaking away it went. I thought a lot of teams would catch on to this strategy for autonomous, as it almost eliminates the chance of any team after you scoring... as far as our counter to the fact that the spider may be turning, well we have three kicks at the can so to speak, our tube only comes off it brought to the floor or catches on something ie the spider leg... so start at the top drive the elevator down to the bottom, and chances are great that you will hit one of the legs... also any team that hold the ringer parallel to the floor seems to have a better chance when the spiders move like mad
Unread 05-03-2007, 19:00
FRC #1360
thats true I did notice that dropping the ringer on top on the leg seemed much easier then I thought it would be. Our design doesn't do that because we didn't think it would work all that well, but we have been proven wrong lol. Our robot instead likes to slam dunk the rings onto the legs, palming the ringer so to say, but I did like the over the top now that I can see it.
Ew, Spiders! Steve S. Chit-Chat 69 17-09-2007 22:19
What are spiders? GaryVoshol CD Forum Support 4 09-03-2006 00:47
spiders Anton CD Forum Support 1 08-02-2005 14:51
Spiders & Online Record.. Brandon Martus CD Forum Support 1 09-01-2004 16:44
Hampsters, spiders, and catepillars... oh my!!! archiver 2001 2 23-06-2002 23:41
