Go to Post "The compressor is half the temperature of a toasted Subway sandwich." - Ashley Hartley [more]
  #31   Spotlight this post!
Unread 20-02-2007, 13:14
Lavapicker's Avatar
Lavapicker Lavapicker is offline
FRC #1056 (Hot Rocks)
Lavapicker is just really niceLavapicker is just really niceLavapicker is just really niceLavapicker is just really nice
Re: Who has released the Magic Smoke!!!
But he does read the posts...magic smoke eh? I did see the wire that looked like insulation had been burnt off. Good job it didn't set off the fire alarms in the library! That would have been a great end to robotic season???
  #32   Spotlight this post!
Unread 20-02-2007, 14:35
Christian Christian is offline
FRC #0408 (RoboTicks)
Christian will become famous soon enoughChristian will become famous soon enough
Send a message via AIM to Christian
A couple of days ago, we magic smoked two rs-540s, it wasn't just wisps, it was complete smoke, almost flames (our arm was too heavy). Then there was the switch. The signal cut out, the switch caught on fire, and the robot went running and crashing into the practice rack, on fire.... it still gets pretty hot, maybe a defective switch... I don't know, but it was funny, sad and scary at the same time.
President/Programming/Mechanical/Electrical/Animation/Website
robots and cake are all you need, everything else like oxygen are considered bonuses.
  #33   Spotlight this post!
Unread 21-02-2007, 21:06
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Did you know that PWM cables contain a very LARGE amount of magic smoke? This is what they can look like after you let it out.
This happened when the PWM cable pulled out of the Victor it was attached to and the ground wire slipped into the +12 vdc connector feeding the Victor.
Name:	Small Smokie.jpg
  #34   Spotlight this post!
Unread 21-02-2007, 22:08
Dan_Karol Dan_Karol is offline
Mentor and Coach
AKA: Daniel Karol
FRC #0131 (CHAOS)
Dan_Karol has a spectacular aura aboutDan_Karol has a spectacular aura about
Send a message via AIM to Dan_Karol
We smoked our bane bots motor with attached gear box the day of ship .
we should have a replacement by our regional along with code to prevent it from happening again.
-Dan Karol
2004 - 2012: Team 1100
2013 - ????: Team 131
  #35   Spotlight this post!
Unread 21-02-2007, 22:23
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Originally Posted by NumBeast View Post
I was having troubles with our backup battery. The charger seemed to drain the battery when the robot was turned off and I had lost our last battery. I finally got tierd of it all and connected the main battery directly to the backup battery port, not realizing I was adding an extra 2.8 volts.
Wow the smoke was awesome. we made smoke signals to each other and had lots of fun with our no longer functioning RC
As a programmer I truly empathize with that RC.
http://www.mikesorrenti.com/
  #36   Spotlight this post!
Unread 21-02-2007, 22:49
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
We let out some magic smoke from one set of analog inputs on the RC after some excess winch cable shorted between some uninsulated spike terminals and some analog pins. Good thing we aren't using them all anyway!
  #37   Spotlight this post!
Unread 21-02-2007, 22:52
waiakea2024's Avatar
waiakea2024 waiakea2024 is offline
ZOMGWTHKTHXBAIBBQ!!!!
FRC #1056 (Kekoa o Haaheo)
waiakea2024 is a jewel in the roughwaiakea2024 is a jewel in the roughwaiakea2024 is a jewel in the rough
We finally have this past Monday. Luckily nothing was damaged. The wire that shorted looked really bad though.
  #38   Spotlight this post!
Unread 22-02-2007, 11:01
savage301's Avatar
savage301 savage301 is offline
FRC #3182 (Athena's Warriors)
savage301 has a spectacular aura aboutsavage301 has a spectacular aura about
We toasted both of our small banebot motors. We ended up not using them anyway. I like the Keyangs much better.
PROBOTS (Student) -> Gatorbots (Student) -> Rat Pack (Mentor)->
Athena's Warriors (Mentor)
  #39   Spotlight this post!
Unread 22-02-2007, 20:12
devaaki's Avatar
devaaki devaaki is offline
Rookie Captain
AKA: Jeff Lou
FRC #2052 (KnightKrawler)
devaaki is on a distinguished road
Cool, it's team 2024 in hawai'i... greetings from 2025 from Minnesota!!
I was hooking up the y-cable PWM to the camera when the other side of the y dropped onto the 120amp breaker nut and grouded out. The ground cable shot up a huge cloud of fetid yellow smoke.
Then a few days later an RS-540 fried itself because our arm dropped down past the limit of travel... turned the insides nice and charcoaly.
  #40   Spotlight this post!
Unread 23-02-2007, 01:00
Orominuialwen's Avatar
Orominuialwen Orominuialwen is offline
Co-Queen of BadgerBOTS Scouting
FRC #1306 (BadgerB.O.T.S. (Building On Talented Students))
Orominuialwen will become famous soon enough
Red face Re: Who has released the Magic Smoke!!!
I released the magic smoke for the first time in a very unusual way several weeks ago. A friend and I were drilling holes in spring steel (used for deploying our ramp & platform) with a block of wood clamped underneath it for stability. The spring steel and wood released the magic smoke on every single one of the eight or so holes we drilled, but fortunately spring steel can still function just fine without its magic smoke.
Unfortunately, spring steel also feeds on the blood of Mechanical Team members, which we can attest to by all of our sliced fingers. We actuallly ended up briefly running out of bandaids in our first aid kit, that spring steel was so hungry.
2004 Midwest Regional Rookie All-Star Award
2005 St. Louis Regional Quarter-Finals
2006 Wisconsin Regional Engneering Inspiration Award
2006 Nationals Participant!
2007 Wisconsin Regional Participant
2008 Wisconsin Regional Runner-up
I'm a FIRST graduate now serving as a long-distance mentor for my old team since I went off to college.
  #41   Spotlight this post!
Unread 23-02-2007, 10:17
FIRST Rocks's Avatar
FIRST Rocks FIRST Rocks is offline
AKA: Matthew Zagone
FRC #0494 (Goodrich Martians)
FIRST Rocks is just really niceFIRST Rocks is just really niceFIRST Rocks is just really niceFIRST Rocks is just really nice
About a week before ship day, I attached a PWM cable to the relay port on the RC so it would be ready to connect to the spike relay when it was mounted. I foolishly left the wire hanging loose. A few days later, the loose end slipped into the backup battery ground terminal. The wire was laying across the RC, so when the magic smoke came out of the wire (lots of it), I thought it was coming from the RC!
2009-Attending: Kettering District, Lansing District, Michigan State Championship, & Championship
2008-Attended: St. Louis Regional, West Michigan Regional, Great Lakes Regional, Championship, MARC, IRI, & Kettering Kickoff
2007-Great Lakes Regional Finalist, West Michigan Regional Winner, IRI Winner
2006-Buckeye Regional Winner, Wisconsin Regional Finalist
2005-Finger Lakes Regional Winner, Detroit Regional Finalist
2004-Archimedes Division Winner, Championship Winner
2003-Peachtree Regional Winner, Curie Division Winner, Championship Finalist
"There is no try. Only do, or do not." - Master Yoda
  #42   Spotlight this post!
Unread 23-02-2007, 19:12
foote stepped in
AKA: E. Foote
FRC #0868
Our old battery boy was the magician of all magic smokes. He set a record of producing it 3 times at competitions. (and we still won safety awards... makes me wonder what all the other teams were doing wrong)
While demonstrating the power of the big cim to our freshmen, our of our victors blew its magic smoke. an arc about 4 inches long, and a bunch of scared freshmen. Now they all believe in magic smoke...
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
  #43   Spotlight this post!
Unread 23-02-2007, 20:41
ChristinaC's Avatar
ChristinaC ChristinaC is offline
FRC #2135 (Presentation Invasion)
ChristinaC is an unknown quantity at this point
Send a message via AIM to ChristinaC
One of our victors released its magic smoke.
And I believe the RC did as well, but it still worked afterwards. Not bad...
  #44   Spotlight this post!
Unread 05-03-2007, 09:19
pogg pogg is offline
Alumnist Mentor
AKA: Kent Wininger
FRC #0540 (Talon)
pogg is on a distinguished road
Send a message via AIM to pogg
Team 540 has realesed the Magic Smoke one or twice during the build season.
  #45   Spotlight this post!
Unread 14-04-2007, 22:43
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Sorry Kyle - I couldn't resist.
One of our electrical team members this year decided to power one of the larger muffin fans directly from the battery.
He must have misread the amperage rating. mA != A.
It melted the positive wire in half, and spot-welded the free end of the wire to the battery. There were little pieces of charge wire everywhere on the floor.
I've never seen him move so fast....
The Magic Blue smoke Cody Carey Chit-Chat 4 17-03-2008 15:56
pic: Magic Smoke Mark McLeod Extra Discussion 15 04-05-2006 15:57
The Magic Smoke... BlueOrion Motors 17 30-03-2004 07:47
Anybody let the magic smoke out? Ryan M. Control System 17 11-02-2004 17:56
Software Magic Smoke Al Skierkiewicz General Forum 17 30-04-2003 12:28
