Go to Post HOSE CUTTER: A tool used to make hoses too short. . - dlavery [more]
Unread 05-03-2007, 02:04
brennerator brennerator is offline
brennerator is an unknown quantity at this point
Urgent help with a project;
So Im trying to put a turbine assembly on a car to generate electricity when slowing down ie. braking. This hwould allow a gas car to recoup some electricity when braking. Is there a way through CAD to simulate the energy generated by a turbine in a certain wind speed? Could I test out different turbines with this? Im sure there is some program to do this but I could not find one.
Unread 05-03-2007, 11:01
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Urgent help with a project;
I'm trying to imagine what you have in mind, and can't do it.....how about a sketch to help explain it?
It sounds like you're trying to make a hybrid gas/electric car, the hard way.
Unread 05-03-2007, 12:31
I doubt anyone makes a CAD program that also does CFD (computational fluid dynamics).
A wind turbine is probably one of the least efficient ways to recover energy from vehicle speed. You might consider connecting the input of a generator to a rubber wheel that can be pressed against one of the drive wheels as a dynamic brake.
Unread 05-03-2007, 13:40
mgreenley
Posts: n/a
Dassault Systemes makes two CAD suites that allow for CFD.
If you have the full version of Solidworks (link), you can use the COSMOSFloWorks add-in to preform a flow analysis on a part you've made in solidworks. The other Dassault product available is CATIA (link) . CATIA requires the Fluent (link) plugin, but provided that you have both, CATIA can also preform CFD.
Hope this helps,
Mike
URGENT! We need help with the accelerometer lkdjm Electrical 5 11-02-2005 16:42
URGENT! We need help with the accelerometer lkdjm Technical Discussion 0 08-02-2005 14:35
Need help with Data recovery [urgent] plutonium83 Chit-Chat 7 11-01-2005 10:35
help with simple project erikh98 Technical Discussion 8 27-08-2004 11:24
